Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
Lamp reset Recently replaced bulb and tried to reset the lamp but it is still showing a total lamp use time of 5137 and the picture is still dark.
    New Friend:
  • 60 Answers
The correct way to reset the lamp timer on that unit is to hold the menu key on the remote and push the enter key on the front of the TV at the same time. Hold them (it's about 9 or 10 seconds) and then a screen comes up asking if you would like to reset the lamp timer. That will reset the time but if your problem is a dark picture that's probably not going to fix that.
Posted on Apr 21, 2008
Screen keeps going black
It is possible but the only way to know is to try that.
Lamps have about a 2000 hour life span which works out to about 2 years for the average user.
Usually in this model just before the lamp fails the picture either comes on somewhat darker than usual or gets dark just before the picture goes out.
The set will detect lamp is not bright enough etc and blank the screen.
The lamp light (I have seen this) sometimes will not come on even if the lamp has a total failure----no picture at all.
You might also check with a local shop or someone with the same model so you can swap lamps to see what the problem is.
Let me know what happens.
Dec 17, 2011 | Sony KDS-50A2000 50" HDTV
I have a sony kds-r50xbr1 when turn-ed on the stand by light flashes for about a min the goes solid and picture comes on but very dark. replaced lamp . there is no sound from any input and the controls...
Sir try to reset the lamp timer. you should press the "display" button on the remote then "5" then the "volume up key" and power "on" you should do this while the tv is in standby mode. Then press "Jump" 3 times to enter the DE service menu. Your tv will display the total lamp hours. Reset the lamp time by pressing channel 3, then mute, then enter. this will make your lamp hour timer to zero. Good day and best regards.
Aug 21, 2011 | Mitsubishi VS-50609 50" Rear Projection...
Sony KDF-E50A10/4 dark picture
Dark picture is indication that tv needs new lamp.
Replace lamp in tv get bright picture, please buy Sony original lamp for good picture in tv.
Jun 17, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Sony DLP has Dark Screen
Techman007 is correct here. Lamps have "lifetimes" of a certain number of hours. The lamp indicator is there to let you know that the lamp is likely to fail soon as it has reached its expected lifetime. That does not mean that there aren't lamps that will fail sooner. In your case, the lamp is not producing the amount of light required for a good picture. This is normal for lamps as they age. The light output for all lamps decreases with use. Normally this does not occur in such drastic ways however.
Since you are getting light from the lamp, the ballast is working as expected. The ballast is similar in function to the ballast for a flourescent light, it either works or doesn't.
One other thing that can be checked is the fan area and any glass surfaces for dust and dirt. Again this will effect hte overall light output, but not in such a drastic way. When you next change the lamp, carefully clen any glass surfaces as well as the fan area. Please note that any access to the lamp area should be done after the lamp has had time to cool. These lamps are burn hazards.
Dan
Apr 30, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Dark picture on lg dlp tv
Did you use a generic replacement? Many TVs have a dark picture after replacing the original lamp with a generic. The other issue I've encountered are TVs that have been exposed to cigarette smoke will develop a dark, discolored picture over a relatively short time.
michtech
Feb 19, 2009 | Samsung HL-R5668W 56" HDTV
Picture quality of my LG Projection TV is very poor
Bad Light engine call UED for price on rebuilt one if they have it!1-800-648-6657
Dec 19, 2008 | LG RU-52SZ51D 52" Rear Projection...
Lamp reset.
there are 2 clocks 1 for lamp and 1 for total, the total you cant change. dark picture, make sure your got same wattage lamp for replacement, I find original Philips lamps the best. if it continues follow manufacture instructions on cleaning mirror and lens.
Apr 12, 2008 | Zenith E44W46LCD 44" Rear Projection...
The picture shows dark
Hi there
Take out the Projector's lamp and check for any black marks ( almost looks like veins ) on the inside of the bulb.
If you spot anything on the lamp , your lamp will need replacement.
If you can't see anything - then you might be in for a new Mainboard.
Very expensive exercise !
Mar 11, 2008 | NEC VT47 Multimedia Projector
Sony WEGA KDF-55WF655
What you need is the owners manual my friend. In here it will show you where to get to the lamp and how to change the lamp. Go to http://esupport.sony.com/US/perl/model-documents.pl?mdl=KDF55WF655&LOC=3
to get a free copy of the OWNERS manual. Page 16 tells you how to do this. Good Luck
Jan 13, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
180 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
