MAYTAG TOP LOAD WASHER MODEL PAVT244AWW, STRING FROM A CURTAIN IS CAUGHT IN THE AGITATOR. HOW DO I REMOVE AGGITATOR TO GET STRING OUT?
    Genius:
  • 1,073 Answers
Remove the fabric despenser from the top of the agatator, under the despenser is a 1/2 inch bolt, a ratche with a 6 inch extention works well, remove the bolt and the agatator will lift up off the transmission shaft
Posted on Apr 12, 2008
String caught between the upper and ;ower half of the agitiator
Remove the agitator and clear the string. Agitators can be hard to remove, but they will come off. Usually have a nut under the top cap that holds them down then pushed down onto splines.
Jul 30, 2014 | Kenmore & Maytag Performance Washer Motor...
Trying to remove aggitator from maytag atlantis I removed fabric softener part need to get the shaft of aggitator off trying to clean my softener keeps leaking out after wash is done
i believe all you have to do is put your fingers underneath the bottom of the agitator and pull up and the whole agitator pops up to remove it out of the tub.
Apr 08, 2011 | Maytag Atlantis MAV6000 Top Load Washer
I have a Maytag Performa Washer, model number PAVT244AWW, that does not agitate. Everything else is working. It makes a loud noise during the wash and rinse cycles when the agitator is supposed to be...
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Sep 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Washer will not aggitate
LOOK AT THE LIDE SWITCH FIRST WILL IT FILL WITH WATER WILL IT DRAIN WILL IT SPIN IF THE ANSER IS NO TO ALL LID SWITCH IF ONLEY TO AGGITATE MAY BE A TIMER OR AGITATOR IT SELF
Apr 03, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Washer was filling but not aggitating,
remove the dispenser in the top of agit . under it is a bolt. remove bolt. it holds it down . if it won't pull by hand then we use a ( agi tamer. this is a split inner tube type/very flat with a split in it . slide under agit and add water and up it comes . 5 min. .. i don't think something is under the agit I belive the trans is failing . but you need to look . . agit needs to be removed to repl trans anyway ..mm
Dec 12, 2009 | Maytag PAV2300 Top Load Washer
Maytag Legacy Series Top Load Washer model SAV515DAWW splashing
the agitator dogs are likely broken.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Maytag Legacy Series Top Load Washer
Making an awful ratcheting noise during aggitation and spin cycles
Under the agitator there is a rachet mechanism that works the agitator. If it is stripped, it will skip until the next good tooth.. when it fails entirely the agitater will stop going back and forth. Its nylon and age along with overloading hastens its dearg.. If you can get the parts you can replace it yourself without difficulty. There is a single bolt in the center of the agitator top . Remove and loft agiyator straight up.
Jun 03, 2009 | Maytag Legacy Series Top Load Washer
Occasionally clothes are catching on the agitator where the corkscrew is attached to the base. When I washed sheer curtains last week some of them caught and snagged. They are ruined. I can't feel...
without a make and model it is hard to say but I would say there must be a small protrution or maybe a cut in the aggitator that is catching them feel around again slow and carefully if you still can't feel anything give the edges of the agitator a slight sand with some very fine sandpaper hopefully this will fix the problem. Make sure your agitator isn't loose on it's mount maybe they are catching under the agitator.
Jul 21, 2008 | Maytag Washing Machines
you don't say which model you have. one version uses two belts accesible by just tipping the machine back. Another version you must remove the front panel, and drop the pump and you'll be able to replace the one belt.
Jul 03, 2007 | Maytag Atlantis MAV7260B Top Load Washer
Washing Machines Logo
286 people viewed this question
Top Washing Machines Experts
