Question about Magnum 257 CB Radio
257 Talkback I have been trying for months to find a way to add talkback to my 257. I've tried grounding the ext sp jack to ground. I've tried pin 2 of the mic plug to the negative side of the speaker. Any ideas on how to add talkback?
Use a talk back ext. speaker.
Posted on Apr 24, 2008
Install a utb-1 talkback board in a uniden pc 78 xl+
why,just jump the pa and ext speaker outputs and you have instant talkback.
Feb 25, 2015 | Uniden Radio Communications
I have the ROADPRO RPPS-550 4 Noise Cancelling CB Extension Speaker with Talkback, why is there 2 male plugs and where do they get plugged in at. One obviously to the CB radio. The other ???
Both should go to the CB radio. One would be for "audio out" from the radio, the other should be for "audio in" to the radio to handle the "Talkback" feature. I doubt that most CB radios will support this. Your best bet is to determine which plug provides output to the speaker (so you have better audio output from your CB - if that's actually possible) and disregard the 2nd plug if your radio doesn't support it. Hope this helps.
Jul 09, 2014 | RoadPro RPPS-550 CB Ext.spkr Noise...
I Want To Add Talk Back Mod To CB Radio
there is what is known as the Quick and Dirty way, to add talkback to almost any CB radio. You will need a 130 Ohm 1/4 watt resistor. Open the radio and find the two mounting points for the external speaker jack and PA audio jack, you will want to solder the resistor across from the Positive connection of the PA jack to the Ground connection for the External speaker jack. This will give you talkback, and eliminate any feedback when the microphone is held at a normal operating distance away, Just remember, (This could potentially damage your radio if done improperly, I will not be held liable for anything that you do to your radio.) However, when done correctly this is a perfectly safe modification, and will allow you to monitor your output audio, as it is being transmitted. You can adjust the size of the resistor to your liking, however, I do not recommend anything lower than 100 Ohm, as there will be more potetial for squealing/feedback.
Feb 20, 2014 | Midland Radio Midland 9001Z Citizen Band...
I want talkback on cobra 18 WX ST
Probably to Chassis Ground. You may want to experiment with the resistor value if you use a power mic. A 100 Ohm resister may be too low a value and cause audio feedback if you do use a power mic.
Aug 13, 2012 | Cobra 18 Wx St Ii Mobile Cb Radio
Want to get talkback in a cobra 29
When you key up the mic ungrounds the speaker so you don't hear anything through it, so to get talkback you're putting a 100 ohm 1, or 2 watt resistor between the switched side of the speaker and ground, now when unkeyed the mic grounds the speaker as usual, but when you key the resistor allows a bit of audio from the audio amplifier, not decoded RF, to still get through. I think the pa/ext spkr. jacks are a convenient place to connect it. You may decide to control talkback by running the circut thru a switch like brite / dim switch . Want less talkback, use more resistance, 150 ohm . Too much talkback can become feedback . I hope this helps, J
Nov 25, 2009 | Cobra 29 LTD CB Radio
Hi, I have a connex 4600 turbo and I have a problem with the talkback on/off switch wiring. Can you tell me were the white wire attaches to from the switch? Thanks
The white wire coming from the Talkback switch goes to The middle of TR30. This location is towrd the back of the radio on the right hand side by the transformer with the radio facing at you!!
Jun 06, 2009 | Magnum 257 CB Radio
I want talkback on my cobra 29ltd classic radio how do i do this myself
Open the case on your radio. Solder a 100 ohm resistor between the pa jack and ext speaker jack. You can add a switch if you like to turn it on and off. The lower the resistance, the louder the talkback.
Mar 30, 2009 | Cobra 29 LTD CB Radio
ADD TALKBACK TO A UNIDEN 510 WITHOUT A PA JACK
In theory you could locate the AUDIO pin from the back of the mic jack, and add a resistor from there to the center pin of the ext speaker jack in the same manner as you would a PA jack.  But look into more before you do as I have never done it that way and Unidens sometimes have a funky way of wiring their boards.  If I had one laying around I would try it out but I don't.  best of luck!
Jan 22, 2009 | Cobra 150 GTL DX Base CB Radio
WANT TO ADD TALKBACK IN A RADIO
A 200 ohm 1-watt resistor across pins 1 & 4 of the mic jack will make some talkback. More or less resistance will make less or more talkback. Note the association of less and more.
Radio Communications Logo
130 people viewed this question
Top Magnum Radio Communications Experts
John Porter
Jim Goldsmith
Jim Goldsmith
Are you a Magnum Radio Communication Expert? Answer questions, earn points and help others
