Question about Dewalt 18 Volt Compact Drill Kit
Dewalt dw997 drill clutch stuck
Drill still operates but can no longer adjust clutch. It is stuck between level 5 and drill mode.
  • 4 more comments
  • dewalthome Apr 21, 2008
    same problem. clutch is stuck in the drill mode.
  • leatherman19 May 24, 2008
    Same thing here too.... speed changes, but clutch stuck in drill mode and cannot move it....
    The older version of this same drill gave me issues like this, but it was usually going from drill to hammer or from hammer to drill... but i was always able to force it to change with my hands. This new one that has not even drilled 30 times, is locked in drill mode. Really sad for a $300 tool.
  • Retrofit47 May 25, 2008
    Drill has unlocked and is adjustable now. BTW it has happened a couple times since. Seems to recur when wratcheting down chuck with bit and then trying to change slip clutch. When this happens try loosening chuck and see if clutch then frees up.
  • asjackson Oct 06, 2008
    I have the same problem.
    The drill still operates, but it will not adjust to the smaller settings. It stops half way.
  • Anonymous Nov 30, 2008
    I have the same problem. What a shame for a great tool otherwise. Mine is stuck in the hammer drill mode. Model DC988
  • Anonymous Apr 22, 2009
    Drill motor runs OK but chuck does not engage.Can you help please?
I found the solution. The craftsman drill bit I used, basically unscrewed the center chuck screw inside the chuck. That screw has a 6-way screw head. When I opened the chuck all the way, I saw that the center screw had made its way up and into the chuck itself. I got a 6 way screwdriver, and drill the screw back into the base of the chuck. Done. Buy a quik change head, and stay away from putting those smaller circle drill bits in your DeWalt. Try that and see
Posted on Oct 23, 2008
Buy Makita from now on
    Champion:
  • 313 Answers
Your drill required trans assy & clutch assy for $132.00 plus tax canadian max repair/
thanx
Posted on May 24, 2008
Chuck stuck open on my psb700 re
not much can be done as the chuck is not specifically designed to handle hammer drill operations (they crack the scroll thread adjuster inside )
best get a new chuck and if you do a lot of hammering get a proper hammer drill that has a push in operation not an ordinary electrical drill with a hammer capability
Sep 09, 2016 | Bosch Drills
Dewalt hammer drill chuck won't turn model DCD985
Make sure the speed selector lever on the top of the tool is all the way in gear, and the dial selector on the tool is in drill or hammer drill mode. If in screw mode make sure it's set to a level that it won't "clutch" out.
Feb 17, 2015 | Dewalt Drills
Broken clutch on Hilti TE-75?
The clutch mechanism needs replacement
Aug 25, 2017 | Drills
My drill slips under high torque
check clutch adjust,put it in drilling mode
check if speed selector is in right position
after that if it slip aggain,you need a gearbox
Nov 04, 2012 | Milwaukee Tool Milwaukee 18V 1/2 In Hammer...
The clutch is slipping how do i fix
If its clutching out in drill mode the clutch pin is worn. This part is 635718-00 its only a couple bucks. not hard to repair either bout 5 min.
Sep 07, 2011 | Dewalt DC988kar XRP 3 - speed 1/2" 18v...
How the cordless drill works in drill mode, especially how the clutch works in drill mode, please give the clear explanation with diagrams
the basic operation for the drill working in the drill only mode is you tighten the clutch up which puts more pressure on the spring not allowing the clutch to ratchet like it would in another position therefore bypassing the clutch completely. Give me the brand and model number and I will try and find a parts explosion for you.
Dec 31, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
How is a driver different from a drill? What
Hello, W/D here.
A very good question......A drill holds a bit and rotates it at a given speed. This speed can be variable, allowing the speed of the drill bit to be better matched to the material being drilled. The output from the drill motor goes directly to the chuck, and the power is directly applied to the drill bit. Some drills can generate a tremendous amount of direct torque, due to the nature of their gearing. Most of the better drills have planetary gears in them.
A driver rotates like a drill, but is designed to apply torque to a driving bit, and cause a fastener to be placed by the driver. The main difference between a drill and a driver is that a driver has an adjustable clutch, allowing the amount of torque being applied to a fitting to be preset. A good example of this would be for driving wood screws. You would dial in the torque setting that you want the driver to quit driving the screw. You don't want to drive the screw to China, you want to drive it flush. A maximum torque setting "locks" the clutch, and the fitting will be driven as far as it can go (This is about as close to being called a drill as a driver will ever get). A clutch setting midway might be just right for driving the same fitting into oak, and a setting at less than that might be just right for pine. The torque clutch effectively sets a kick out torque for the driver. When the torque applied matches the torque set on the driver, the clutch "slips", and no further driving action can occur.
Most modern battery powered drills incorporate a torque clutch between the motor and the chuck so that the tool can be operated as a drill (with the torque setting at "max") or as a driver (with the torque setting at less than max) some electric tools are configured as both, but usually they are different. For the money, a good battery powered drill/driver with a clutch offers more versatility, in my opinion.
Best regards, --W/D--
Aug 19, 2009 | Dewalt Home Fencing
Stays in the lowest setting
if clutch type ,sure clutch is in an acceptable level
Nov 29, 2008 | Dewalt 18 Volt Compact Drill Kit
Dewalt DC925 Clutch Ring Jammed
if your in hurry & away from the service center all you need to do is just loosen the 4 screw that holds the clutch housing & set it # 1 & back to drill mode couple of times. do not remove clutch if your not sure co'z its got tiny needle bearing on front of the transmission.this is just a temporary fix . it may happened again.
Jul 03, 2008 | Dewalt 18 Volt Compact Drill Kit
Clutch and speed selector problems
drill needs transmission and switch probably co'z it's loosing the varaible speed.
Jan 19, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt 18 Volt Compact Drill Kit Logo
3,300 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
