Question about Linksys Wireless-G Broadband Router
Linksys Wireless-G 2.4GHz Broadband Router
Have just purchased an Ipod Touch but cannot connect to my wireless internet because I have forgotten my password for the above router. Can the password be re-set. If so, how? Do I need a tech person to do it or can I do it myself? Thanks for any assistance.
  • 3 more comments
  • Anonymous Jun 12, 2008
    forgot password
  • Anonymous Jun 15, 2008
    I have the same problem it's just that I don't have a button at the back that say reset for 30 sec. Please help me reset my password.
  • dlbaisch Dec 20, 2008
    it wont let me connect to this router says the security key does not match the networks
  • Chris M
    Chris M May 11, 2010
    http://www.tech-faq.com/setup-linksys-ro...
    http://forums.linksys.com/linksys/board/...
  • Anonymous Mar 14, 2014
    How do I connect my ipod to my wireless router. I don't know my password.
I am unable to reset my password. Do I have a reset button on the back of my linksys wireless g2.4
Posted on Aug 30, 2008
    Sergeant:
    Champion:
  • 427 Answers
If you press and hold the button o the back of the router that says reset for 30 seconds, the router will restore factory defaults. Then, your routers password will be reset to "admin"
Posted on Apr 12, 2008
How to change password?
Posted on Oct 02, 2012
How can I get the router IP of my Linksys 2.4GHz broadband router?
The Linksys G router gives you both wired and wireless connections over a broadband Internet connect to create a local area network. The Linksys router is compatible with wireless G and B devices, through the 2.4-GHz wireless band. The wireless speed is at 54 megabytes per second and you can get 100 megabytes per second with a wired connection. You have to set up the wireless configuration on the Linksys before using it on your network.
Plug the router's power cable into an electrical outlet. Attach an Ethernet cable into the Internet port on the back of the router. Connect the other end into your broadband modem. Connect your computer to the Linksys G using another Ethernet cable. This Ethernet cable can go into any of the wired router ports. Open your Internet browser. Type "192.168.1.1" in the address bar and hit "Enter." This is your router's IP address and the home of its Web configuration page. Click "Wireless." Click "Manual." Alter your SSID, also known as your network name. You can change this name to any value that you want. You can also change the wireless channel if you are in an area with many wireless connections that may interfere. Click "Save Changes." Click "Wireless Security." Choose an encryption method to encrypt your wireless transmissions. WPA or WPA2 are common security protocols you can use in wireless networks. Input a network key, also known as the network password. Click "Save Changes."
Setting Up WPA Wireless Security on a Linksys Wireless Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=3696 Wireless G-Broadband Router support http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G b> b> Changing the Wireless Network's Name (SSID) on a Linksys Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=4037
Mar 27, 2013 | Linksys Wireless-G Broadband Router
I pod touch wont connect to linsky's wireless g do i have to configure something?
yes you have to configure the ssid in you ipod
i assume you have an ipod touch use this guide
http://www.wikihow.com/Configure-Ipod-Touch-Wifi
please rate my solution ....big help
Apr 11, 2010 | Linksys Wireless-G Broadband Router
I cant get my ipod hooked up to my roter and wii
This is first assuming you are talking about an IPOD Touch. You first have to have wireless connectivity. Once you have wifi go to:
1. Touch Settings
2. Touch Wifi
3. Turn your Wifi ON
4. Select a Wifi network
5. Enter the WEP Key you have created on your router (assuming you have secured your network).
6. Hit Connect
Jan 20, 2010 | Linksys Wireless-G Broadband Router
WIFI not working with Linksys wireless-g broadband router/Comcast
Unplugging the wireless router and connecting it again should not have altered the wireless connection/configuration. You have connected the cables correctly because the Internet works when you connect a LAN cable to the router.
The Linksys wireless configuration or the wireless card configuration in the computer was changed it to lose the wireless connection. The wireless card configuration needs to be changed to match the wireless router's settings or change the Linksys with new configuration settings and configure the wireless card accordingly.
To secure your router with a login password and wireless security, please follow my instructions - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Should you need further assistance, please leave me a comment.
Dec 25, 2009 | Linksys Wireless-G Broadband Router
How can i reset my Linksys Wireless-G2.4GHZ Broadband Router settings
Try to reset the router. This should resolve your problem. That model has a small hole were you must press with some a paper clip for exemple for a few seconds. This will reset the router to its original state.
Nov 07, 2008 | Linksys Wireless-G WRT54G Router
How to set up the wireless-G 2.4 ghz 54mbps LINKSYS
I have moved and lost my CD to my Cisco "Linksys" wireless-G model WRT54GS please tell me how I can download the disk from somewhere???
Joyce
Jul 11, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G Broadband Router Logo
2,353 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
