Question about Refrigerators
Ice maker not producing anymore ice cubes - Refrigerators
  • robert reed Apr 12, 2008
    REFRIGERATOR MAYTAG PLUS MODEL MSD2756DEW
    FIRST: WOULD NOT MAKE ICE.
    SECOND: LIGHTS ON CONTROL PANEL LOCKED UP. WOULD NOT DO ANYTHING...NO WATER, ICE, ETC.
    THIRD: THAT NIGHT IT SHOT WATER ON THE FLOOR. WE HAD TO DISCONNECT THE WATER LINE IN BACK OF FRIDGE.
    FORTH: REPAIRMAN CAME AND SAID A WIRE WAS LOOSE. HE CONNECTER IT. IT MADE ONE TRAY OF ICE AND QUIT AGAIN.
    FIFTH: REPAIRMAN SAID A SOLENID WAS BAD AND REPLACED IT.....AND STILL DID NOT WORK.
    SIXTH: REPAIRMAN SAID IT NEEDED NEW CONTROL BOARD. THE NEW BOARD THEN BURNED OUT DURING THE REPAIR. REPAIRMAN SAID THAT THE SOLDER ON THE BOARD
    STUCK UP TOO HIGH AND CAUSED IT TO SHORT OUT.
    SEVENTH: THE NEXT BOARD BURNED OUT DURING THE REPAIR.
    EIGHTH: REPAIRMAN LEFT AND WILL NOT COME BACK??
    NINTH: PLEASE HELP.
  • Anonymous Oct 19, 2008
    I have same problem, no ice cubes. there is humming and clicking but no ice cubes. Thisis the worst refrigerator I've ever bought. The Maytag companyis rude and there is no help. I am looking to file a suit as this is horrible service for such an expensive fridge.
Get a new fridge
Posted on Apr 24, 2008
Ice maker quit making Ice cubes
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 12, 2010 | Maytag MFC2061HES Stainless Steel French...
The ice maker is not working
There is a way of testing the ice maker.
Diagnostics for ice maker starts on page 27
Apr 01, 2010 | Samsung RF265AA Bottom Freezer French Door...
Ice maker only produces 30 cubes per day (24 hrs) since new.
You probably need more water pressure going to the frig. check that first.!!
Mar 22, 2010 | LG LRSC26980 Refrigerator
Ice maker quit producing ice, cubes were not solid before,either.
shelling:
Jan 01, 2010 | Frigidaire Refrigerators
Ice maker stopped working. The cubes gradually got smaller until it just stopped producing cubes
Here is a tip that I wrote about the reasons why ice makers do not work.
heatman101
iot47
Oct 05, 2009 | LG LFX25960ST Stainless Steel French Door...
Ice maker stopped making ice
Hi
If the ice maker has completely stopped producing ice then check to see whether the ice maker has been turned off. For this you need to look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahrenheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary. If the ice maker is producing ice poorly i.e. if it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
The ice maker does not make anymore ice.It looks like the ice tray position upside down.I need help.
Hi
If the ice maker has completely stopped producing ice, then check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 05, 2009 | Samsung Refrigerators
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
Will not dispence ice, crushed or solid cubes, will dispence h2o
Hi
If the ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
and if the ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
Please do rate the solution as "FixYa" and revert for further assistance.
Thanks
Rylee
Apr 09, 2009 | GE Energy Star 22.0 Cu. Ft. Side-By-Side...
Ice maker doesn't make enough ice to supply two senior citizens. This is the 2nd refrigerator we have had installed this month. What can we do to increase the amount of ice it puts out. The ice bin has...
Found in the FAQ section on Samsung.com:
Samsung refrigerator freezers produce about 120 cubes per day, which is in line with most manufacturer specifications.
Empty the ice tray and let the unit run for 24 hours.
If fewer than 50 cubes are produced during the 24-hour test, then your refrigerator requires service. Please contact Samsung Service at 1-800-SAMSUNG to schedule a service appointment.
If your freezer is producing 50 to 90 cubes per day, try the following:
  • Set the freezer temperature display to a lower setting. Freezer temperature must be 5 degrees Fahrenheit or less for the ice maker to work properly.
  • Make sure that the water valve on the refrigerator water supply line is completely open. You can find the water valve where the refrigerator water supply line taps into your house water line.
  • If you have a water filter in your refrigerator, change the filter cartridge. For instructions, see your Users Manual.
If you want your freezer to produce more than 120 ice cubes in a day, try the following:
  • An ice maker typically makes 1 tray of ice every 90 minutes. To shorten the amount of time the freezer takes to produce a tray of ice, set the freezer temperature display to a lower setting.
  • If your refrigerator has a Power Freeze function, press the Power Freeze button to speed up the ice making process. In the Power Freeze mode, both the compressor and the freezer fan run for 10 hours continuously. The ice making interval is reduced from 90 minutes to 55 minutes. If the ice bucket fills in less than 10 hours, Power Freeze stops automatically.
NOTE: If you have just installed your refrigerator, it will take 6 to 12 hours for the refrigerator to produce ice.
You should throw away the first three batches of ice cubes that the ice maker produces (approximately 30 cubes) to ensure the ice maker is making ice from clean water.
Feb 06, 2008 | Samsung RM255LASH Side by Side...
Refrigerators Logo
646 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
