Question about Motorola Talkabout FRS 250 (14 Channels) 2-Way Radio
Fr50 beep How do you stop the fr50 from beeping every time you press a button? motorola talkabout 250 how do you stop the beeping every time you push the button
  • mtnrvr Apr 16, 2008
    The problem was low batteries after we changed them it quit beeping.
    Sergeant:
  • 250 Answers
Hello mtnrvr,
The Motorola TalkAbout radios, especially the FR50 and FR60, are notorious for making a variety of beeps when you push buttons and activate various functions of the radio.
The beeps can be helpful when you are trying to operate the radio in low-light situations. But they can also be mildly irritating.
Sadly most models of TalkAbout do not provide any way to disable the beeps. I'd suggest not using this particular radio for covert surveillance missions.
Best Regards,
Agent Ken
Go Ahead. Use Us.
Posted on Apr 16, 2008
How do you stop the beeps after pushing PTT button?
We have been unable to locate a manual for the TalkAbout 250, but have one for the T280, which is one generation newer. Here is a link: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T280_User_Manual.pdf
The instructions say to hold the monitor button in while turning on the radio to turn the Alert Tones on/off.
Best regards.
Apr 05, 2013 | Motorola Talkabout FRS 250 (14 Channels)...
When I press the push to talk button on my Motorola talkabout 250 there is a constant beeping noise and I cannot transmit
Generally a constant beep is the sign of a low or bad battery. However, it is noted the TalkAbout 250 is operated with AA batteries, and it is likely you have considered this and changed batteries. You might check your battery contacts, and clean them with a pencil eraser to assure they are making good connection. Otherwise, you may have a failing radio.
Best regards.
Nov 02, 2010 | Motorola Talkabout FRS 250 (14 Channels)...
Have Talkabout 250 and want to turn off the beeping. any ideas
The following instructions are for the T289, which is very similar to the T250. It is possible they will work to turn off your beeps.
Alert Tones
The Alert Tones (beeps) on the Talkabout radios are set at a fixed volume
level and cannot be lowered. However, Alert Tones can be disabled. When
Alert Tones are disabled, the radio will receive messages at the volume
setting you've selected, but you will not hear beeps when you press control
buttons.
Disabling Alert Tones:
1. Hold down the Monitor button while you turn radio on.
2. To re-activate Alert Tones, turn the radio off, then on again while holding
the Monitor button down.
Here is a link to the user guide: http://www.motorola.com/mdirect/manuals/T289_User_Manual.pdf
Oct 20, 2010 | Motorola Talkabout FRS 250 (14 Channels)...
Motorola talkabout 250 beeps when the talk button is pushed
The radio has possibly been damp or wet. Take the battery pack out of the radio and allow the radio to dry, or to speed the process try using a blow dryer on a low setting.
Check your programming and be certain your large and small numbers match one another when you get ready to try the radio again.
Here is a manual which most closely matches your radio type: http://www.usersmanualguide.com/motorola/2-way_radio/t280
Nov 17, 2008 | Motorola Talkabout FRS 250 (14 Channels)...
Shutting the beep sound off when you turn on talkabout T7150
Button Beeps
Every time you press a button on the front of your radio, it beeps unless you turn
Button Beeps Off. To turn Button Beeps Off, turn your radio On while you press and
hold the minus (-). To turn Button Beeps back On, turn the radio Off and then back On again
while you press and hold the minus (-) . On is the Default setting.
http://www.motorola.com/mdirect/manuals/T7100_UserGuide.pdf
Nov 15, 2008 | Motorola Talkabout T7150 Two Pack 2-Way...
Motorola radius sp50 "roger beep"
The radio will need to be reprogrammed using the radio service software for the SP50 radio.
Jul 05, 2008 | Motorola Talkabout FR50 (14 Channels)...
Fr50 beep
Sorry but on this model, you cannot.
Kind regards.
Jan 11, 2008 | Motorola Talkabout FR50 (14 Channels)...
Motorola t5100
In most Motorola T5XXX series/models, pressing the + button while powering on enables/disables the roger beep (release of PTT button).
Good luck and kind regards.
Nov 03, 2007 | Motorola Talkabout T5100 (14 Channels)...
Neither radio will receive or send
The radio probably needs reprogrammed to match the other units. Check your owners manual for instructions.
Oct 18, 2007 | Motorola Talkabout FR50 (14 Channels)...
Motorola Talkabout FRS 250 (14 Channels) 2-Way Radio Logo
325 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Iron
Iron
OBHighflyer
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
