Question about Coby MP-C7085 MP3 Player
HELP ME PLEASE!!!
The mp3 player will not hold charge once you unplug it from the wall..Can you change the battery in these it seems to be hooked to the chip board? as long as the mp3 player is hooked into the wall charging it will work, but when you unplug it it won't hold charge
  • teaser72 Feb 26, 2009
    my mp3 won't hold a charge when unplugged from the wall, but will work when plugged in. I want to be able to charge it and would like the best way to do so. I try to charge it by plugging it into the wall, not the computer.
My colby MP3 is not leting me listen to my music.I like need help
Posted on Apr 13, 2008
Ghfbhb
Posted on Apr 12, 2008
I plug into the computer and i also tried to charge it with my ihome. both times i unplugged it, it just shut off and i couldnt turn it back on without plugging it back into the comeputer! Please help.
Seems to be a charging/discharging issue for the battery. Try using the wall adapter only for charging and wait for it to fully charge before connecting to the computer or any other devices.
Mar 08, 2011 | Apple iPod nano MP3 Player
Model#1825 it wont charge or turn on
Hello :
It seems that the battery is dead [ can't be recharged anymore ] . You need new battery . If you replaced the battery with new one and the device still can't be recharged , then I recommend you to take your player to the service .
You may also check the power transformer or power cord .
good luck .
please rate
Mar 30, 2010 | Toymax Impecca MP-1825 MP3 Player
My 120G zune wont charge....it wont even turn on. ive left it hooked up to my computer and wall-charger for days. and the reset methods dont work. help!!
Hello :
It seems that the battery is dead [ can't be recharged anymore ] . You need new battery . If you replaced the battery with new one and the device still can't recharged , then I recommend you to take your player to the service .
good luck .
please rate !
Mar 30, 2010 | Microsoft Zune JS8-00001 Digital Media...
2g black mp3 player not holding charge. Red light comes on but when unplugged mp3 not charged even when left charging overnight.
Your mp3 player seems to be malfunctioned or damaged from inside give it for repairing it will help alot..!
Thankyou. :)
Jan 08, 2010 | SanDisk Sansa Clip MP3 Player
My iPod wont start. Couldit be the battery?
The first thing you should try is hooking the unit up to a wall socket, not to your computer. Once the unit is hooked into the wall, try reseting the unit. This can be done by holding down the menu button and the center button at the same time. Hold the buttons for several seconds, and this should reset the unit. If this does not fix your unit, then yes it can be your battery, or your main board of the ipod. Look on the bottom of your unit and make sure there are no signs of corrosion(liquid damage). Also see if you see any bent pins at the bottom this can cause your unit to not charge also. If you have any other questions feel free to contact www.wiredextreme.com.
Nov 20, 2009 | Apple iPod nano 2nd Generation MP3 Player
My Mambo- Mano MP4-MP3 does no charge
it does not seems to charge / or turn ON either from the computer or when plugged to an electrical outlet to the wall. Red light is still ON after the whole night . What's wrong ?? Can you please HELP - CODY STELLER MINE IS A 4 GIGA BITE MP4 PLEASE HELP ONLY
Sep 01, 2008 | Kaser Corporation Mambo Mano Digital Media...
The songs on my mp3 will not play. They appear on the screen but no sound. THere seems to be trouble with the battery.
Make sure the hold switch if off. Reset the player. Try a different USB port on same computer. Try a different computer with the same OS (to prevent formatting-related errors)  Here's some general info about the problem:  “My Mp3 player won’t turn on” or “My Mp3 player won’t hold a charge.” (POWER SUPPLY ISSUE) The tricky part about these issues is that there are several possible causes – it could be software or it could be hardware.  Before you try anything else, make sure the mp3 player’s “hold” or “lock” switch is not engaged.  See your user’s manual for location of switch/ instructions (available from manufacturer’s website).  If the hold is engaged, the mp3 player will not charge, and it will not turn on.  Then, make sure the player is plugged into a compatible computer with a USB 2.0 port.  Manylaptops and older desktops lack sufficient power resources to properly power/charge/utilize an mp3 player.  Next, try resetting your mp3 player.  If that still fails, try your device’s “recovery” button. There is a specific button that triggers the recovery mode – volume + for most players, REC button for others, play for others, and skip forward for still others.  The general formula goes something like this, although you may have to substitute another button for “volume +”: disconnect the player from the computer, turn it off even if you have to reset the player to turn it off (if it is dead, this won’t be a problem), hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player (even if it is completely dead) - it will pop up a window that says Found New Hardware Wizard. Make sure that your mp3 player is not designed for a country other than your own – this information can be obtained from the manufacturer in most cases.  European and some Asian current systems are different than in the U.S., Canada, and Mexico.  If you plug a United States mp3 player into a European wall outlet, you will fry the player.  If you plug a German mp3 player into a US outlet, it will have insufficient power to power the player.  There are transformers available that can correct for this issue. If you have lost the original charger for your mp3 player, try to obtain the original charger.  If the original is no longer available, check your product specs to get EXACTLY the correct voltage.  It may seem harmless to use a 5V charger on a 4.5V mp3 player, but in many cases you will damage the mp3 player by doing this. Also, never unplug an mp3 player while it is transferring music/files/performing a firmware upgrade (and also, never perform these activities when your player is not at least 75% charged).  This is a sure way to kill most mp3 players.  As a safety rule, always check and use the “safely remove hardware” option if it is available on your computer – lower right hand corner (green arrow pointing to chip) in most Windows taskbars.  If it is not available, wait one full minute after your last file transfer to unplug the mp3 player – even if your mp3 player says “OK to disconnect.” If your mp3 player uses AA, AAA, or any type of user-removable battery, you must take extra steps to prevent equipment damage when replacing batteries (most product manufacturers do not know this tip).  Before removing the batteries, power the player off and let it sit for one minute or longer.  Run your hand along the side of your computer tower to dissipate static electricity (or use any other method available to dissipate static electricity).  Use only and exactly the replacement battery recommended by the manufacturer.  Carefully remove the old battery.  Hold and gently squeeze the new battery for a few seconds to dissipate static.  Hold the mp3 player case in one hand, and carefully insert the new battery.  One single static spark, and your mp3 player could be history.  Also, check your product documentation beforehand to see if removing the battery will result in your song’s being erased/data being lost.  Many, if not most, mp3 players do not have replaceable batteries – the manufacturers do not have them, and popping open your mp3 player more often than not causes damage to additional components. If the solutions above do not work, and you have gone through troubleshooting with the manufacturer, you may have hardware damage and the player will need to be replaced. -Tha Mp3 Doctor
Jun 03, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
Help with Sansa 2gb MP3 Player
Get firmware update and then restart your computer:
Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Mar 09, 2008 | SanDisk Sansa Clip MP3 Player
It turns off as soon as you unplug it from charging.
maybe it could be the battery.. you might need to go purchase a new battery
Jan 06, 2007 | SanDisk Sansa e250 MP3 Player
Coby MP-C7085 MP3 Player Logo
113 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
