Question about Sewing Machines
Cording foot bought a kenmore machine.....manual does not give instructions on how to use the quilting bar or coring foot...
A quilting bar attaches to one of the feet usually in the back and is attached by a little set screw. it is used as a guide to ride a long a previous line of stitching or a design to keep lines of stitches the same distance apart.
I'm familiar with 2 different types of cording feet. one looks like a zipper foot... very narrow and a notch on the side of the foot instead in the middle. to make cording ...fold a narrow piece of fabric in half and place yarn or cord along the inside of the place folded fabric with yarn inside under presser foot. but up the foot next to the yarn bump on the top side of folded fabric and stitch as close as possible. the second kind has a groove on the underside of the foot and the yarn bump follows this groove stitching is also done close to the yarn. some concideration in needle placement is needed depending on the thickness of the yarn or cord. always hand turn the needle up down the first few stitches to make sure the needle does not hit the foot.adjust if needed.
Posted on Apr 30, 2008
Can you use quilting bar with walying foot that came with si ger 9960
The info I found has no mention of the quilting bar for the Siinger 9960 walking foot. Most machine with that functionality include the quilting bar with the walking foot. There also needs to be a hole through the walking foot and a method to attach the bar to the foot which doesn't seem possible with what I located. However, you may be able to attach a bar or a guide of some sort using something like masking tape that can be used as a guide.
On a straight-line quilting tutorial I saw recently, the quilter laid down strips painter's tape to mark the lines on the quilt before doing any stitching. Then she simply stitched next to to painter's tape to get straight lines.
Feb 08, 2018 | Sewing Machines
How to lower the feed dogs for free motion sewing on model # 16782
There are most likely some numbers missing from the model number you provided. Usually, there is a 3-digit beginning number, ie 115, 385, 401...
I am unable to find model information based on your number, but you can most likely get a user's manual through Sears or try searching the internet (Make Model manual), ie:
Kenmore Sewing Machine Manuals Instruction and Repair Manuals
Sewing machines generally have two ways to disable feed dogs. One way is a lever or knob on the machine itself that physically "drops" the feed dogs so they are below the needleplate. The feed dogs will continue to operate but since they are below the sewing surface, they will not have an effect on the fabric movement. The other way is an accessory that attaches to the needleplate which covers the feed dogs and creates a flat sewing surface.
Another item that is important for free motion quilting is a darning foot or free motion foot. These presser feet are physically shorter in height than a standard presser foot. This means the darning foot, when lowered, does not apply "pressure" to the fabric when it is lowered. It, instead, provides leeway between the presser foot and the fabric so there is room to manually maneuver the fabric while stitching.
You'll just need to CONFIRM that the presser foot shank is correct for your machine (low shank, high shank, slant shank).
There are probably a multitude of designs available for your machine, either Kenmore or generic brands. Once you've determined your machine's shank, it would be a personal decision as to the design you'd prefer, which could be metal or plastic, closed, open, or clear see-thru as well as various shapes, round, oval, etc. There are also some feet that are spring-loaded so they "hop" while you stitch, or feet that are solid.
These are examples of different darning/free motion presser feet.
Darning Foot Low Shank 4021
Nancy Notions Trusted by sewing enthusiasts for more than 3 decades
Amazon com Tinksky Sewing Machine Open Toe Metal Quilting Embroidery...
Free motion Darning Quilting Sewing Machine Presser Foot Fits All Low...
Nov 27, 2016 | Kenmore Sewing Machines
How do I attach the quilting bar to the walking foot on my Simplicity Quilters Classic? The manual doesn't show how to do it
There should be a hole across the back of the walking foot (penetrates the walking foot usually from right to left, although some feet will have 2 guides--one for left to right, the other left to right) where the bar mounts and a screw to tighten and hold it in place.
Quilting Bar Attachment
Oct 06, 2016 | Simplicity Quilter's Classic SW240...
Bernina 630 pressure foot won't stay up. What do I do?
Make certain that the foot is firmly attached to the bar. If that is the problem (it won't stay in place on the bar) you may need a new or different foot.
Feb 07, 2018 | Sewing Machines
Using a walking foot on my Necchi 3537
Hi JoEllen,
The walking foot replaces the normal pressure foot on your machine. There is a screw on the left-hand side of the pressure shaft that holds the ankle (if your Necchi uses snap-on feet) on the shaft. Loosen this screw until the pressure foot (or the pressure foot/ankle combination) comes off. Now slip the walking foot on where the other foot came off and tighten that screw. You're ready to go!
Jun 05, 2010 | Necchi 3537 Mechanical Sewing Machine
How to attach a quilt guide
You have to unscrew the screw for the presser foot first. The walking foot will then fit. Use the same screw to attach the walking foot. Before you insert the screw, take the white handle on the walking foot and slide it on the screw arm for the needle. Now tighten the screw.
Mar 21, 2010 | Singer Sewing Machines
How do I install my darning foot?
First, raise the presser bar, remove the presser foot, the presser foot holder and screw.
Turn the handwheel to bring the needle to its highest position.
Place the darning foot on the presser bar and make sure that the metal bar of the darning foot is above the needle clamp and put the screw back on and tighten.
As the needle bar raises and lowers, the foot will hop up and down slightly.
Make sure that you always lower the presser bar when using this foot. Lower the feed dogs also if your machine has this feature.
Aug 20, 2009 | Kenmore 15343
Machine quilting
To stipple ,remove the ankle and foot, lower the feed dogs and, most importantly, lower the presser foot lever.
You can also buy a LOW SHANK darning foot which will help prevent skipped stitches. It must be screwed onto the machine instead of snapping on.
Oct 29, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
How you you attach the quilting foot?
If you don't have a manual to show you, you might phone your local Brother Dealer where you bought the machine & foot and they can guide you over the phone, or arrange a time for you to pop in and be shown........if this is not convenient, Brother HQ in your country should be able to assist or give guidance as to where to find a solution.
May 12, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
142 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
