Tip & How-To about Video Game Consoles & Games
If you have the 3 rings of Death (3 Flashing Red Lights) on your xbox 360 console, all you need to do is to contact Xbox Support and report this issue with them. The Console has a 3 year warranty for the 3 flashing red lights. Just make sure you did the following first:
1. Power Cycle your Console (Turn it off, unplug the power adapter from the wall outlet, wait for 30 seconds, turn it back on)**This is the best solution and it usually works!!
2. If still persist, Turn it off, remove any accessories connected to it (Hard Drive, Controllers, etc.) turn it back on without those accessories. **These accessories sometimes causes the problem.
3. If removing these accessories removed the 3 flashing lights, attach the accessories one at a time, every time turning it off and attaching one and turning it back on checking each time if the red lights (any lights) appeared. It will tell you what is causing the error.
4. If all else fails, again CONTACT XBOX TECH SUPPORT on their Toll free number. Make sure that you tell the tech that you have done those things above so they can create a report for the issue. They love the 3 flashing red lights issue. I should know, I am formerly one of them. :)
Red Ring of Death: Red Flashing XBOX 360 Lights Explained
Common Xbox 360 Red Ring Errors
The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error,
follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
