Question about Cameras
Tdc 15 mini cam 100k
I need to find installation disk 2 for the cam to work can u help
  • 556 Answers
SOURCE: my new cam destroyed the harddisk
This is more of a corporate backup standard taht follows -- in my case used when the restoration was to occur 1/2 way around the world and I wanted to miminize problems. The question for you is can you restore the machine if the backup fails meaning you are willing to assume more risk concerning the backup.
Norton Ghost is a backup product that when I last used it allowed creation of backup CDs the first or last of which was self booting that could be used to restore your system as it was before the backup. This is an effective means of backing your entire computer up periodically to simplify recovery when you have issues like you have had. PS a backup such as this can be wortless if you do not know how to restore it and if possible have tested the restoration to a different machine (but similar) or a different drive placed in the same machine. Both of these strategies to test the backup and assure the restore may not be available to you but it is a greater risk not to have a tested restore procedure as well as testing the CD's to assure they will actually restore.
There are instances where manufacturer supplied software has had viruses. Generally as the CD's get older so do the viruses and it is more likely and up to date anti-virus program would catch them.
Downloads are also risky but one means to minimize that is to get downloads from the manufacturer's site instead of other sites.
SO if you have a tested backup and
your anti-virus is up to date and
your sources software to add to your machine is considered reliable, it would be reasonable to try again.
But this time you will be so much better off with the backup.
If you are interested you may be able to download files from the manufacturer here.
here are two links -- for DSB-C100 clear and white
they have driver links and manuals -- if you can match a manual you should be able to download your driver
DSB-C100 clear
http://support.dlink.ca/products/view.asp?productid=DSB%2DC100Clear
DSB-C100 white
http://support.dlink.ca/products/view.asp?productid=DSB%2DC100White
White does not seem to have drivers -- I would read the manual to assure they are needed.
Posted on Dec 24, 2007
  • 10 Answers
SOURCE: timing zx2 escort TDC ?
The cams have a notch in the back of them (facing driver's side) in which fits a flat piece of steel to lock the cams in place. The notches are not exactly centered on the camshaft, meaning that it's impossible to set them 180 degrees out, because then the flat piece of steel that is supposed to be inserted to lock the cams in place simply won't fit because the top of the cylinder head will get in the way. I highly recommend getting a Hayne's or Chiltons manual if you don't already have one. It should explain this process under the Timing Belt Replacement instructions. The cam lock tool (that flat piece of steel) can be purchased at ZXturner.com:
http://zxtuner.com/product.sc?categoryId=23&productId=191
Posted on Jun 29, 2008
pushpdeep17
  • 47 Answers
SOURCE: i lost my install disk, please help!! anyone! please help!
well happy to help u .u just have to long on to ur products web site and go to driver and support coloumn and ur problem will be solved.if u can tell me the make and model and ur location i can also provide u the link. pleasure helping u .
Posted on Oct 29, 2008
jyackle5
  • 8197 Answers
SOURCE: Need a driver for a webcam, Sky dude PC Camera
Go to this website and find your camrea. http://www.geniusnet.com/geniusOnline/online.portal?_nfpb=true&productPortlet_actionOverride=%2Fportlets%2FproductArea%2Fcategory%2FgetSubCategory&_windowLabel=productPortlet&productPortletcmd=all&productPortletcategoryId=30843&_pageLabel=productPage&test=portlet-action Once you find it click on the more button by it. It will take you to another page above the camera you will see a tab that says download click that to load the software.
Good Luck
Posted on Dec 28, 2008
ta_mcguire
  • 125 Answers
SOURCE: my mini webcam driver disk for sakar concepts web
yes go to manufacture web site and you can download all the drivers
Posted on Jul 13, 2009
Cams wont turn after replacing headgasket
you need to start over with the timing process the valves are hitting the pistons because the cams are not in time rotate the pistons off tdc by about 90 degrees counterclockwise and reset the cams then turn the engine to tdc and put it together rotate by hand after installation to be sure it turns freely 2 full revolutions of the crank and all the marks should line back up
Dec 10, 2012 | 2004 Suzuki Forenza
How do you change a timing belt in a 2008 Chevy aveo?
place engine at TDC, remove timing cover, remover belt, install new belt, be sure cam timing marks align and engine stays at TDC, i recomend buying a service manual, they cost about 15 bucks and save alot of headaches for begginers
Mar 13, 2012 | 2008 Chevrolet Aveo
How do i set the valve timing if i cant see the timing marks on a VW 1.8 20valve golf cylinder head timing chain , i can only find the one on the belt side i have put the cam on TDC for the ex-valve but...
The 2 cams are linked with a chain at the rear of the cylinder head.
The cams need to be set so the slots on the chain sprockets line up with the cam tower caps with 16 links between cam caps.
You cannot see the front crank pulley tdc mark so you need to lock the engine at tdc with a screwdriver jammed into the timing hole on the bell housing after setting engine at tdc or use a DTI
to check to tdc in the #1 spark plug hole.
If the cams have not been disturbed you only need to set the belt cam sprocket to the mark and crank to tdc.....all this means pulling the core support into the service position so the belt tensioner can be locked down and/or doing a complete belt job along with a coolant pump if over 70,000 miles..
Aug 20, 2011 | Volkswagen Golf Cars & Trucks
I took engin apart now need to no how to set the timing on my drz 250 2002
Since you have taken apart the engine I am going to assume you have some basic mechanical knowledge.
If I recall correctly, the camshaft sprockets have #'s 1,2,and 3 on them with lines or arrows.
With the piston set on TDC, the marks on the flywheel and cover should line up.
Install the exhaust cam with the #1 pointing forward lining up with the cylinder head surface. The #2 on the same cam should be pointing upward.
The #2 arrow or line should be pointing at a pin in the cam chain. This is pin #1. The intake cam should be installed so that the #3 arrow is pointing to pin #15.
I do not have the manual with me, but to the best of my recollection, this was the procedure.
Good luck.
Jun 28, 2010 | 2002 Suzuki DR-Z 250
WOULD LIKE TO INSTALL A MINI WEB CAM THAT MY CD
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Oct 04, 2009 | SNK IC Gear Mini Webcam
How to align timing sprocks on a 1997 z24 chevrole cavalier
You will need 2 5/16 drill bits. There is a 5/16 hole in each cam gear. With the crankshaft 1/8 turn off TDC, turn the cam gears so the hole is down. Insert the drill bit into the hole and move the gear slow until the bits slides into a hole in the rear timing cover. Do this to both cam pulleys. When you have both bits installed, this will lock the cams. Don't turn the cams with the crank at TDC, It will bend valves. Once you have the cams locked, turn the crank 1/8 of a turn back to TDC. Don't go the other way. The TDC mark on the crank should be a dot on the gear and a arrow on the rear timing cover. Then after everything is lined up, Install the chain,guides and tensioner. After everything is installed, Turn the crank two revolutions, and line the crank back up to TDC. If the timing is right, you should be able to insert the drill bits in each cam gear. Hope this helps.
Mar 11, 2009 | Daewoo Leganza Cars & Trucks
Mini webcam driver disk
please help me.....!. i have a webcam there is no driver. "EXE" that all the clue, type on the hardware.
Jul 13, 2008 | Sakar Mini WebCam 69352
Driver
Download webcam creative labs - model PD1001 - telechargers
Apr 18, 2008 | Creative Labs Creative Webcam
Need xp drivers for JVC GR-D70U cam corder
try some of the XP drivers on here although which one will work is trial and error as your cam is quite old and unlisted, but one of them must work for you, fingers crossed!! http://www.jvc-victor.co.jp/english/download/camcorder/about_winxp.html
Sep 06, 2007 | JVC Cybercam GR-D70 Mini DV Digital...
Cameras Logo
299 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
