Question about Smeg KS9XSE Stainless Steel Kitchen Hood
Smeg P580 Range hood will not switch off, fan goes from 1>4 but not 0 > 4 ?
  • Anonymous Mar 21, 2014
    How do I remove and replace the light/fan switch assembly from a SMEG rangehood?
  • Anonymous Mar 30, 2014
    KWCU205HSS-0
Hold the fan button down for a couple of seconds and it will turn off.
Posted on May 07, 2008
How do I turn off a Smeg Classic591Ss range hood.
Unplug it for now and then try and find a new switch pad.
Sep 28, 2016 | Smeg Kitchen Ranges
Whirlpool accubake
follow this steps with VOM and fix it. God bless you
1. No power to the range hood
Make sure there's power getting to the range hood. Check for a tripped circuit breaker or a blown fuse. Check the wall socket (unless the hood is hard wired) for power with a voltmeter or by plugging something else in.
2. Fan switch
If your range hood only has a fan and no light or any other features, it won't start with a broken fan switch. Replace the switch if found defective.
3. Fan motor
If your range hood only has a fan and no light or any other features, it won't start with a broken fan motor. Replace the motor if found defective.
Read more: http://www.appliancepartspros.com/repair-help/rangehood-repair-help.html#ixzz2aSy5FKwN
Jul 29, 2013 | Kitchen Ranges
The fan in my has not stopped working in a few weeks now.what can I do to make it stop blowing air
test this steps and fix it. God bless you
2. Fan switch
3. Fan motor
Exhaust fan and lights do not work
see this steps and fix it. God bless you
Switch If the range vent hood fan and light are not working the switch might be defective. Watch our video on switch testing and test this switch for continuity.
Selector Switch If the range vent hood fan and light are not working the selector switch might be defective. Watch our video on switch testing and test this switch for continuity.
Rotary Switch If the range vent hood fan and light are not working the rotary switch might be defective. Watch our video on switch testing and test this switch for continuity.
Rocker Switch If the range vent hood fan and light are not working the rocker switch might be defective. Watch our video on switch testing and test this switch for continuity.
Switch Kit If the range vent hood fan and light are not working the switch kit might be defective. Watch our video on switch testing and test this switch for continuity.
Micro Switch If the range vent hood fan and light are not working the micro switch might not have continuity. The best way to test the switch is with an Ohm meter. See our switch testing videos for help testing this micro switch.
Thermal Fuse If the range vent hood fan and light are not working the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Main Control Board If the range vent hood fan and light are not working the main control board may be defective.
User Control and Display Board If the range vent hood fan and light are not working the user control and display board may be defective. Check other causes before ordering this board.
Oct 02, 2012 | Dacor Millennia DHI602 Kitchen Hood
Lights don't work on my smeg kseiv95x
Did you find a solution to this? I have the same problem. Thanks.
Jul 19, 2012 | Kitchen Ranges
Smeg KSE1V950X fan lights flash? Is this a filter cleaning issue and how do I reset it?
Yes this is a sign to clean the filters. Once they have been cleaned, it can be reset by pushing 2 buttons together at the same time - I just tried several combinations until they stopped flashing.
Sep 05, 2011 | Smeg KS9XSE Stainless Steel Kitchen Hood
Smeg KS9XSE Stainless Steel Kitchen Hood Logo
944 people viewed this question
Top Smeg Kitchen Ranges Experts
ashburton
Joseph Mueller
Joseph Mueller
Your Consultant
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
