Question about Toshiba 65H82 65" Rear Projection Television
TOSHIBA 65H82 MY BIG SCREEN TV STARTED TO FLICKER WEN YOU FIRST TURNED IT ON, AND WOULD TAKE A FEW MINUTES TO CORRECT ITSELF, WOULD ONLY HAPPEN ON INITIAL START UP AND WOULD BE FINE AFTER, NOW IT SEEMS THAT THE COLORS (GREEN,BLUE,RED) ARE NOT ALIGNED IVE TRIED FIXING IT WITH TV MENUS, I AM UNABLE TO ALIGNE THE RED CROSS HAIRS, IT SEEMS TO HAVE MOVED FROM ITS ORIGINAL POSITION, AND IT IS WARPED IN SOME SECTION, GREEN AND BLUE ALIGN FINE, TV SCREEN LOOKS LIKE A 3D MOVIE TOP AND BOTTOM OF SCREEN SHOW THE RED COLOR CON-CAVED FROM TOP TO BOTTOM , ANY HELP WOULD BE APPRECIATED
  • 3 more comments
  • mpfrustrated Mar 18, 2009
    toshiba 65H82 first the flickering, then the convergense problem. the red cross hairs don't line up nor can get corrected because the red ones don't move. the blue is fine and the green is correct. how do I fix this. and is it a simple fix?
  • jandtsunshin May 11, 2010
    I have gone to Servicemanuals.vstore.ca/ and cannot locate installation instructions including pictures or tec support on the link. Ihave purchased the items you mentioned through pay pal. On the pay pay invoice it states Under instructions to merchants, " you havn't entered any instructions " What does this mean
    Yankeegurt; I have ordered 2 convergence IC's# stk392-110 as you requested and paid it through PayPal invoice number 4098 @ a total cost of $39.98 ( $19.99 each) But on the pay pal receipt it states instructions for merchabts have not been entered. What does this mean? Please advise
    Yankeegurl; Is there a manual that I can refer to to locate the 2- convergence ic's #stk392-110 that are attached to the 2 big heat sinksand identified as q-751 & q-751. I am not sure how to obtain the installation instructions including pictures. I went ro the link and all I saw was an order form, How do I obtain the installation instructions and pictures. Your advise is greatly appreciated.
  • Anonymous Mar 16, 2014
    My screen has a 3d look to it. Red, blue, and green. How do I fix this?
  • 121 Answers
You need to replace your 2-convergence ic's #STK392-110 you need to replace both ,,they are attached to 2 big heat sinks and identified as q-751 & q-752 you can get the ic's you need plus free tec support and installation instructions including pictures at the link I gave you.
http://servicemanuals.vstore.ca/
Posted on Apr 12, 2008
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
Aug 23, 2013 | Televison & Video
My Mitsubishi WD-65638 turns on then flickers and turns off?
Flickering must be due to the fault to lamp itself. If you wish to get more details, check this link.
Mar 03, 2013 | Mitsubishi WD-65638 65" DLP HDTV
Rear projection tv colors flickering
Two types or more of sets: regular TV sets with a picture Tube, big rear projection sets, Plasma, LCD, DLP
A model number would allow me to give you the answer--I suspect you have a set with a picture tube(regular tv)
Let me know which so I can try to give correct answer.
Mar 28, 2012 | Televison & Video
I have an RCA/ Thomson 32" CRT TV that I bought in October 2005. It recently started turning on and off by itself when just plugged in. It has no set order or time as it happens at random. sometimes it...
Ur high voltage,not good,resolder the FBT,the big block of plastic with a red wire with a cap hook to a CRT.Still happen must replace the FBT,the flyback transformer.
Oct 14, 2009 | Televison & Video
42HP95 TV screen flickers off/on
Can be either one of three things 1) logic board, power supply, or unfortunately most likely is your panel. But if I were you I'd get a hold of Toshiba warranty center to diagnose because then they could check voltages with toshiba tech support.
Aug 23, 2009 | Toshiba 42HP95 Television
36 inch tube tv - Screen flickers
my problem is don't sound in my mobile LG CE 0168 please help me.
Aug 17, 2009 | Toshiba Televison & Video
Slight convergence problem after changing convergence circuits
My experience has been that the resistors have fallen out of range. These aren't expensive and neither are the caps that surround this area. If you're pulling the board out to change the resistors, might as well change the caps, too. If you're strapped for cash, but have a multi-meter, you can test the caps and the resistors after they've been taken out of circuit to save a little green. Let me know if you need any help testing them; I'd be glad to help.
May 22, 2009 | Toshiba 65H82 65" Rear Projection...
Picture often flickers and image distorts every few minutes
The trouble is most likely in the Video processor. If the trouble looks like its tearing the video only from side to side it may be the line doubler circuit. Some of these boards are no longer available but a good TV tech may be able to componnent level repair it for you.
Apr 15, 2009 | Toshiba TP50H95 50" Rear Projection...
Toshiba 65H82 65" Rear Projection Television Logo
319 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
