Question about Curtis RCD333 AM/FM Stereo Tuner CD Boombox
Cd cover on curtis rcd333 won't close
The cover on the my curtis rcd333 will not stay closed. Appears that there is something wrong with the mechanical "lock" that keeps the cover closed when you want to play a cd. Is there anything that can be done to repair this unit?
  • 1 more comment
  • crackmaster Apr 12, 2008
    No information present for repair of this unit
  • rossen3 May 22, 2008
    the cd cover of my curtis rcd333 radio/cd player won't close and so it cannot play any cd's. what can i do?
  • Anonymous Nov 13, 2008
    LATCH CAME OFF OF CD PLAYER AND NOW CD COVER WILL NOT CLOSE
    New Friend:
  • 136 Answers
AUDIO.ManualsOnline.com
Posted on Apr 12, 2008
Hitachi ax-m71 cd door won't stay closed. Unable
if it opens back up when you close it the drawer mechanism is probably out of alignment. Most players have a slot on the bottom of the drawer that a pin must slide in. Look under the drawer and see if there is a pin sticking up that maybe should be in that slot.
Jul 09, 2013 | Audio Players & Recorders
The cd drawer won't stay closed
the cd drawer will probably use infra-red to sense when the drawer is open or closed or maybe just a gear mechanism, either way these must be clean, I'd take it apart and lean it all with cotton buds and isopropyl alcohol
Feb 07, 2013 | Audio Players & Recorders
Samsung CLX 6220
one reason the door cant close is precisely because there is a pastic piece on the door itself that prevents it from doing so, the reason is because the belt is most likely in the wrong position... it may need to have a lever moved to have it stay up and then closed. check the green handles and try turning them to different positions
Sep 11, 2012 | Samsung CLX 3160fn All-In-One Printer
Cd door on curtis rcd 869 will not stay close
From the description there is a small loading belt slipping when it cannot complete the cycle, it will close again, usually located under the loading bay.
Jul 06, 2012 | Curtis RCD843 CD Player
Bobbin cover will not close
if the bobbin cover won't fit easily over the bobbin the either it's the wrong bobbin for the machine, the bobbin is warped or there is something wrong with the bobbin case
Feb 09, 2012 | Kenmore Drop-In Bobbin 16231 Mechanical...
I have a Philips CDR820 CD recorder/3 CD changer. The CD tray won't stay in. I push the load/close button, but it closes and then immediately opens again. Won't stay closed. Not sure what to...
I have done this job. taking that think apart can be a pain.
There is probably a switch, that is pressed, and senses the closing or status of the tray,
and it keeps resetting. It could be a leaf switch, that would be lucky.
It could be an encased switch. You would need an exact replacement in that case.
The leaf switch could just need to be cleaned with a folded dollar bill.
Its perfect for cleaning a couple of contacts, and its not destructive.
Its a shame to throw something like that away, for such a small problem.
Maybe you could sell it at a garage sale to some kid after you tell 'em what the problem is.
Point being, taking that kind of thing apart, and putting it back together again, might not be worth the stress that goes with it. I've done it because I am POOR, and if I had money, I wouldn't go through that aggravation.
Aug 29, 2011 | Audio Players & Recorders
Front cover won't stay closed
There is a sensor .i think it is dirty having dust onit .just open back cover find sensor and clean it properly.it will bi closed.MIAN AKHLAQ
Nov 12, 2008 | Panasonic KX-FHD331 Plain Paper Thermal...
Cd tray not staying closed
gently push the cd door back in while pushing the door closed button , untill it closes if it still comes out then the cd laser mechanism is not lifting or something else has happened , then it will need to be tested to determine the exact cause
Oct 16, 2008 | Memorex MKS5001 Shelf System
CD Player
Thank you for your reply.
BeoSound 2000 - The CD won't even spin now. The cover closes, the Number 1 for the track appears in the display, then the cover immediately reopens showing what looks to be something like this [ ] in the display.
Nov 14, 2007 | Bang and Olufsen Beosound 2000 Shelf...
Curtis RCD333 AM/FM Stereo Tuner CD Boombox Logo
190 people viewed this question
Top Curtis Audio Players & Recorders Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
240cpa
Are you a Curtis Audio Player and Recorder Expert? Answer questions, earn points and help others
