Question about Toshiba Tecra A3 Notebook
Screen won't start
The computer screen won't turn on,
you hear the computer starting up then nothing happens
  • thomasbaldry Apr 12, 2008
    na the ram was not compatable thanks alot anyway
Solution #3 Guest, same problem with my laptop. When I turn on the laptop and if I see the toshiba screen in the beginning the laptop starts well. If i dont see the toshiba screen, the computer turns to on, but monitor wont. However, i dont hear the Operating system sound as well. I even tried with external monitor, same thing. And at last as Guest told he bangs, I even do that stuff to make it open lol. Any idea how to fix this problem? Probably some connection?
Posted on Jun 16, 2009
The back light to the monitor of my laptop went out. is it better for me to get a new laptop or get the monitor fixed
Posted on Jun 24, 2008
I'm having the same problem with my Toshiba Tecra A3. Sometimes the monitor is on, most of the time after reboot I dont see anything happens. I shutdown and bang the computer lol and sometime it starts to open.
Quote:
"The most direct way to do that is to connect an external monitor to the laptop (there is most likely a monitor connection on the back or a side of the laptop.)."
I tried this one as well, no sign, same problem and same solution.
Posted on Jun 13, 2008
    Sergeant:
  • 202 Answers
Hi tomasbaldry
My 1st (Routine) Question is:
(01) Do you have *ANY* other information *at all* regarding this issue?
For example:
(A) Research that might have already been done on this issue
(B) Things that might have been tried to determine or to correct the issue
(C) *Any* other issues w/ your computer - particularly any issues that corresponded w/ the onset of this issue.
(D) Something someone else might have told you, suggested or recommended regarding this issue (including contact w/ the manufacturer).
I guarantee you, you cannot give us too much information. The more we know about this issue, the faster and more accurately we can get it diagnosed for you. :)
NEXT:
We'll need to determine if the problem is w/ your computer's LCD panel (monitor).
(02) Connect a *known working* monitor to the laptop's external monitor connection.
(03) Turn the monitor power on.
IF you can do the following w/ the laptop monitor in the closed position, please, do so.
(04) Turn the laptop power on. (Make sure the A/C adapter is connected. (We don't want to confuse the issue w/ a low or dead battery.)
(05) Quickly but gently, (right after pressing the power on button) place the laptop's monitor in the closed position.
(06) If the laptop's LCD panel has failed, we would expect you to be able to see your laptop's display now on the external monitor.
If that is the case then the monitor either needs to be repaired or replaced.
That is the 1st phase of the trouble-shooting process for this type of issue.
(07) Please, post back here w/ the results of your test and answers to Questions (01/A-D). Please, include questions, observations, etc as well.
** Please, don't rate the experts' solutions
** yet. Instead, wait until this issue has
** been resolved or diagnosed and you don't
** have any further questions for us. Once
** you enter ratings for the experts' feed-
** back ("solutions"), the problem will be
** closed automatically. We won't be able to
** continue to assist you.
** As long as the problem remains open, we
** WILL continue to work w/ you on it until
** it is resolved or diagnosed.
Thank you,
BJ @:)
Posted on Apr 12, 2008
  • B Joan Rapier
    B Joan Rapier Apr 12, 2008
    Ahhhhhh! That would apply to my Question (01) Part (C).
    Recent changes to your computer that coincided w/ or precipitated the issue.
    Upgrading or replacing RAM would certainly fit for that one.
    Hopefully, that is what helped you to pin down the problem.
    In any case, incompatible RAM is a hec of a lot better (cheaper to fix) than a monitor that's gone south! :)
    I'm really glad you got it sorted out.
    Thank you for using FixYa. Please do, come back anytime you have a question that needs answered or a problem that needs to be solved. We're happy to help.
    Thank you, too, for the FixYa rating! @:)
    Have a beautiful day,
    BJ @:)
MY GE front loader washer won't fill with water or spin. I hear a hum when I turn it on and it sounds as if it's about to start a cycle but nothing happens.
It sounds as if your water valve is either clogged or the solenoid is stuck and not letting any water in. Here is a checklist of things you should do to help isolate the problem:
1) check to make sure the water is on
2) turn the water off and remove the water lines and verify that both the lines and the screens on the valve are clear of debris, calcium, etc.
3) take the top off the machine where you can actually see the valve, turn the machine on and see if the vavle is the humming noise that you are hearing. If so and no water is coming out then the valve is bad.
May 19, 2012 | GE Washing Machines
2000 Pontiac Sunfire won't start
Try checking the oil, the low oil sensor will disable the ignition
May 29, 2017 | 2000 Pontiac Sunfire
I turned off the touchpad on My Toshiba Satellite m55-s329 laptop which disable the mouse and keys to function. So I had to hard start my laptop. When it turned back on my screen was blank (black). The...
Please connect a USB Mouse and keyboard then power on your laptop it will boot your win xp then re enable your touchpad by going to device manager. It will work.
Sep 13, 2017 | Toshiba Satellite M55-S329 Notebook
Screen won't appear upon start up and I get 3 beeps but no screen
what you are hearing is a beep code, if its 3 short beeps then its the memory which has developed a fault and it may need to be replaced
Nov 16, 2008 | Acer Aspire 5100 Notebook
Computer won`t start
Hello there my friend
There is a easy check, it sometimes MEMORY PROBLEMS, or VIDEO , check your RAMs, and take out one module, if has more than one, and restart the PC, I know you will write me back! :)
tell me!
Open Sky
Sep 19, 2008 | Everex GA3400 Refurbished AMD Desktop...
Toshiba Tecra A3 Notebook Logo
169 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
