Question about Samsung LN-T3253H 32 in. LCD Television
Picture Size problem with Samsung Flat panel LN-T3253H
My problem involves the picture size on my Samsung TV model LN-T3253H. I'm having trouble getting the picture to fit the dimensions of my screen, regardless of whether I choose 16"9, 4:3, Wide Fit or Just Scan. In all cases, the picture appears too large for my screen. For example, when watching a hockey game, the scoreboard graphic at the top is outside my view. This is the case for HD channels and non-HD channels.
  • jonnylynch19 Feb 28, 2009
    My trigger happy inlaws have been to stay. OVernight they ahve destroyed my TV settings, adn now I cant get a full screen picture anymore, despite putting the TV sizin on 16:9 ratio. All I get now is a reduced screen size with black envelopes left and right. Works fine with DVD though.
    Any suggestions for a quick fix. I just cant see what I can do after following all the manual instructions.
  • Anonymous Mar 22, 2014
    How do you change the picture size to "screen fit".
  • Samsung Master
  • 1,689 Answers
You should contact Samsung service to know if the internal setup for the picture sizing was not adjusted properly at the factory.
Take care that some of these sets have a user zoom mode. Maybe it is in the zoom mode. Check in your instruction manual before calling for service support.
Jerry G.
Posted on Apr 12, 2008
  • StormCrow
    StormCrow Nov 10, 2011
    Does sound like a zoom mode issue. Keep in mind that this option for adjusting picture size is usually available not only on your TV itself, but also on your converter box (if you are using one), and/or on your set top box from your service provider.
    If you are not recieving over-the-air broadcast.
    Adjusting one will affect how the picture is displayed and interact with the other.
Power but no sound and no picture
it means the power supply is working well so check the power inveter which could be left or right sided or both it means no back lighting or diflectig light to displ and some other TV's the t-com card is involved to switch those inveters and make sure all fuses are leading contunitive 0000 buzzing
Mar 17, 2014 | Samsung LN-T3253H 32 in. LCD Television
Have a T3253H Samsung TV not picture but sound. Tried replacing the power board, but still have the problem.
Please describe the problem in detail so that I can advice as to what the problem is and how to fix it.
Sep 16, 2011 | Samsung LN-T3253H 32 in. LCD Television
The image on the screen looks like everything is in slow motion, the the color is messed up. I have already tried adjusting contrast, brightness, etc. Is this a fixable problem, or should I just buy a...
I know the colors are all messed up.But the tv LCD screen panel light it is bright enough to see the screen picture,and the tv LCD screen panel are clear,no purples,reds marks or bruses to the tv LCD screen panel itself?Yes,to all of these.The tv can be fixed.The tv Tuner signal board,that the board where the incomming broadcasting signal wire plug into it.The tv Tuner signal board it is dying and the problems to causes this.U have some basic mechanicals skills like take things aparts and putting it back together again?Yes,tries websites like, to buy a whole new refurbish tv Tuner signal board for the replacement.Will fixed this tv and get tv this to be working normal again.
Aug 20, 2011 | Samsung LN-T3253H 32 in. LCD Television
Hello. My Samsung LCD model # LN-T3253H 60"/61"
It sounds like your LCD panel or your T-con board is bad . Panels are expensive so I would replace the T-con board first. You have to open the TV and get the part number from the actual board in order to find the correct one. You can find parts at
Jun 03, 2011 | Samsung LN-T3253H 32 in. LCD Television
Please what is the factory reset for samsung tv.Modle Cs-21z58ml.
samsung tv MODEL picture and low brightness problem has been re solved by replace the crt .if you found 4voltage for heater 190volt for scren still no picture you have to replace crt.but some times might be the micro chip on the circuit that its not pushing up the RGB's colors but most and common problem is CRT board.if you'll try to replace the transistors or will not change any guys letme know if you fixed it at thanks
Mar 07, 2011 | Samsung LN-T3253H 32 in. LCD Television
Black screen on lcd
Probably need a Main Board. Take it to an Authorized Samsung repair shop for troubleshooting. T-con would be another possibility and I've even seen the LCD Panel bad on this model
May 12, 2010 | Samsung LN-T3253H 32 in. LCD Television
Continuous crackling from TV speakers
I'm sure you have figured this one out. TV itself is causing the problems.
The circuit board that produces the audio signal seems to be the problem.
Before you call the repairman, go to the web site just to get an idea of what the parts will cost. That way he doesn't rip you off.
I hope I answered your question correctly. Please rate me. :)
Feb 26, 2009 | Samsung LN-T3253H 32 in. LCD Television
Picture Size
Also, try adjusting the settings on your cable box, not on the TV. The usually solves the problem and will then allow you to adjust the size of the picture.
Mar 03, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
LN-T3253H issue with camcorder
Samsungs will not switch to an input that has no signal going into it. Try putting the cables into the TV, then hit play, then switch to the correct camcorder input.
Dec 24, 2007 | Samsung LN-T3253H 32 in. LCD Television
Samsung LN-T3253H 32 in. LCD Television Logo
1,104 people viewed this question
Jerry Greenberg
Jerry Greenberg
