Question about Philips 60P8342 60" Rear Projection Television
Phillips DPTV 335 troubleshoot
Having problems with the screen. The colors are out of alignment. I've been doing some research & I have seen "multiple" suggestions on replacing the convergence "chips" P/N: STK392-120. Would this be a valid troubleshoot? If so, where can I get these "Convergence" chips & what price ranges? Can they be purchased at Radio Shack, Best Buy or Circuit City?
I need some help with this!!! I'm missing out on NFL Network, Basketball and soon maybe even the NFL Draft.
Please Help me.
Luis
Ecollier2012
  • 3459 Answers
SOURCE: MY PHILIPS DPTV 335 HAS
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Posted on May 01, 2011
TVtechmaniac
  • 140 Answers
SOURCE: Phillips 60PP9202 Convergence Problems
The two convergence IC's are generic part# STK392-120 (Philips original part# 932212344682) The two resistors are sitting side by side (6.8 ohm 2 watt)
Posted on Sep 16, 2007
ctf1800
  • 4402 Answers
SOURCE: PHILLIPS MAGNAVOX 60 BIG SCREEN 9P6040C101
no this is what you need...
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
or send it in for repair here
Posted on Feb 07, 2008
SOURCE: 55pp935217 Way too much blue
what and where are ic sounds like whats wrong with mine
Posted on Sep 11, 2008
daniel719
  • 240 Answers
SOURCE: phillips model 51pw9363 Convergence Problem
lets see.
you have an up grade for this unit.
replace original ICs with STK 392-120
if you can soldier and clean heat sink of and replace heat sink you can replace thes parts no problem.
serch for them on line cost is from 14$ to 30 each.
hope this helps you
and please give me a godd rating for this advice.
i pay $160 a month for my info and this sigt pays nothing.
thanks.
daniel.
Posted on Jan 13, 2009
I have an phillips dptv 33 O the red blue & green are out of alignment
The tv have a problems known a convergence picture problems,it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead.The tv convergence board must have it components parts replaced like 2 STK convergece ICS and some or all of resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 11, 2011 | Philips 55PW9363 55" Rear Projection...
MY PHILIPS DPTV 335 HAS A GOOD PICTURE BUT ITS GOT A HEAVY RED TINT NO MATTER HOW MUCH I ADJUST IT.
  • Screen looks 3D
69189a5.pngSOLUTION
May 01, 2011 | Philips 55PW9363 55" Rear Projection...
COLOR PROBLEM
you have a miss aligned convergence. try to aligned it first.
Aug 06, 2009 | Philips 55PP9363 55" Rear Projection...
My color convergence is out of focus
heres a kit to repair that it contains both ICs and the 12 resistors plus has step by step instructions with pictures so you can do the repair yourself.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
Jun 17, 2009 | Philips Magnavox 51MP392H Rear Projection...
Problems with convergence
the convergence Ics have failed. You can get the repair kit for your model which has both ICs and the 12 feed resistors plus step by step instructions on how to do the repair. Heres a link to the repair kit for your model.
May 29, 2009 | Philips Magnavox 51MP392H Rear Projection...
Need to replace conversion chip or small signal board
You can get the repair kitfor that issue for your model at the following link which contains both convergence ICs, the 12 feed resistors and free step by step instructions with pictures on how to do the repair.
May 22, 2009 | Philips Magnavox 51MP392H Rear Projection...
Red is way off
The two STK392-120 Convergence ICs needs to be replaced and also some of the 6.8 ohm 1watt resistors will usually need replacement when the ICs fail. You can get the kit for your model which includes both ICs and all 12 of the 6.8 ohm resistors plus step by step detailed instructions for your model. Heres a link to the repoair kit for your model.
Mar 29, 2009 | Philips 60PP9352 60" Rear Projection...
Philips 60pw9363 convergence issue
there is a convergence repair kit for ypour model which has both convergence ICs and all 12 Feed resistors at the following link. They also include step by step instructions with pictures of how to do the repair. Heres the kit for your model.
Feb 03, 2009 | Philips 60PW9363 60" Rear Projection...
Phillips 60pw9363 Which IC is red and which is blue
Thats the DPTV 335 series chassis when the IC blows it will usually take out 1 or 2 6.8 ohm resistors along with it. Look at the resistors right next to the ICs you will notice 1 or 2 with a little discoloration in the middle replace those and your set should be back to working just fine. Let me know if you need more help. These resistors are easy to spoy they all look alike and shouldnt have any bands on them they will be stamped 6R8 ohm 1W J
Apr 12, 2008 | Televison & Video
Philips 60P8342 60" Rear Projection Television Logo
297 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
