Question about Kicker 06ZX750.1 Car Audio Amplifier
Kicker ZX 750.1
My amp goes into red light mode when the bass hits @ higher volumes. I went to adjust the gain and now the amp goes into the same mode even with the gain all the way down as soon as you turn the HU up to 3/4 power????
The amp is not hot waht so ever...barely warm.
Worked fine for 4 months???
  • john wasson
    john wasson May 11, 2010
    is it bridged?
  • Anonymous Mar 23, 2014
    I have a 08 kicker zx1500.1 amp powering a 08 kicker L7 12" 4ohm with a 15 frad hybrid soundstream compasitor and proper kicker 0 gauge wiring kit. When I turn my gain, bass bost and x-over freq. up past 1/2 the amp cuts of goes into protection mode than turns back on once I turn amp down.
I figured it out!!! Thank yopu for responding though. I had a weak graound signal:)
Posted on Apr 21, 2008
Kenwood kac-6295 shuts off then turns back on at high volumes
Did you wire the speakers in series or parallel? 4 ohm speakers in parallel actually come out to equal 2 ohms wich most amps would see as a short causing protection issues. 4 ohm speakers in series equals 8 ohms which should be fine for your amp. been there : expert-tech / SAM
Mar 27, 2012 | Car Audio & Video
How do I tune my KICKER 08ZX1000? I have the amp running to alpine type r 12 inchs at 2 ohms but I don't know where the bass boost , gain, and crossover knobs should be pointing or what one to turn up...
To start, turn the gains on your amp all the way down. Bass boost should be off (this us used if you listen to your subs at low volume, the boost will heat your amp up quick if you use at high volume). Then turn the volume on your headunit up to 3/4 full. Make sure the filter on your amp is on low pass. The crossover point should be at it's lowest too. With all these in place, you can begin turning up the gain. You will have to decide at what point to move the crossover point. Since there are different styles of music, you will have to listen to where you feel notes are "dropping off" from the music. Adjust the crossover point to your liking, but remember that subs were made to reproduce low frequencies. Hope this helps
Aug 20, 2011 | Kicker Car Audio & Video
I have a kicker dx 500.1 amp and a kicker cvr12 sub. When I first hooked up worked perfect for a few minuted. Adjusted settings ont the side and it went out. Now When I power on it the protection light...
check the fuse on the power wire (+) not the ground wire .. i had a kicker 1500.1 on 2 l7 15\'s and when the bass would hit hard the fuse would vibrate and cause the amp to go into safe mode.. after re wireing the whole truck i then found out it was the 150amp fuse holder
Aug 07, 2011 | Kicker Car Audio & Video
When my RCAs are hooked up to my amp, my subs start hitting without any volume turned on
1. Check Grounding system (Player and Power Amp).
2. Ensure your RCA cable is OK
3. You might adjust volume or bass volume on power amp to maximum, just set all to 50% while you are tuning.
Mar 28, 2010 | Kicker CVR12 Car Subwoofer
Subs hit without volume on
4. Check the speaker out cables might contact the ground/ chassis
Mar 28, 2010 | Kicker CompVR 05CVR84 Car Subwoofer
Gain makes subs go crazy when turned up
HI DUDE UR AMP IS TO POWERFULL FOR THE SUB ... .... LOWER DOWN BASS IN UR PLAYER ... AND AMP .... TRY ADJUST BACK THE TUNE ... IT WILL B FINE ....
Apr 14, 2009 | Kicker KX800.2 Car Audio Amplifier
Green light turns red on hard notes with kicker 750 mono amp
First off, never, ever replace a blown fuse with a bigger one (especially one that is almost twice as big) unless it's an absolute emergency. Most of the time, the reason a fuse blows is because of a problem with the device (in this case, the amp). By installing a larger fuse, there's a very good chance the problem will become permanent (i.e. busted amp).
The amp could be going into an overcurrent mode when the bass hits and power cycling itself to try and reset the problem. If this is the case, take it to a local electronics repair shop and see what they can do.
It's also possible the input voltage to the amp is dropping too low during the bass hit, making the amp restart. Try putting a 1.0F or higher capacitor on the battery to buffer the power during the bass hits.
Mar 16, 2009 | Kicker (ZX750.1) Car Audio Amplifier
Kicker zx1000 only plays at low volume
how high did you turn the gain up and or the freq. mode most soun good at 90to 120hz. any higher some amps trip, and your speakers may not be able to handel the amp.
Jul 20, 2008 | Kicker ZX10001 Car Audio Amplifier
Amp cuts out when turned up
that amp cutting out like that means that its probably shot and it time to start looking for a new one
Apr 09, 2008 | Directed D800 Car Audio Amplifier
Peavey Bass amp 115
HI Subicbay,
ADjust your Gain setting to limit just enough so the amp does not go into Protect mode. Turn your Gain all the way down, then crank up the bass from your system. GRadually turn up the gain until you trip on protect. Turn the gain back a notch and your set for no more protect.
Oct 27, 2007 | Jensen XA4150 Car Audio Amplifier
Kicker 06ZX750.1 Car Audio Amplifier Logo
241 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
