Question about Panasonic Audio Players & Recorders
Message f61 appears in window
Unit will not stay powered up.
  • Anonymous May 27, 2008
    powers down all of a sudden
Panasonic Surround Sound F61 code appears...can this be fixed?
Posted on Feb 09, 2009
F61 is either a speaker unhooked or a "sticky" fan. Turn off at mains.........Make sure all speaker connections are sound and blow compressed air (available in a can) into the fan. (Do not try and lubricate the fan spindal as this will make it worse). This should fix it. Turn back on at mains and all should be OK.
Posted on Jan 03, 2010
The song is playing and running suddenly the song stops and the error msg when i restart my dvd. The error msg is F61 displays in Dvd's display. Please give a rply.
Hi ahamedfaisal,
Does F61 appear after a minute of playing or shuts down immediately after you power on the unit?
Jdvillanueva
Mar 16, 2011 | Panasonic Audio Players & Recorders
At power on, displays F61 code and switches off
F61 is an error code.
It will automatically shuts down your unit.
This is very common on your unit.
Try to checked if the fan is working or not.
I have repaired some unit before, this is the caused why f61 appeared.
The symptom is shutting down the unit after a few minute.
If the fan is not working it will shuts off automatically to avoid further damaged to your output I.C. from overheating.
If confirmed that the fan is working then I've suspect that your output I.C./pre-amplifier circuit is faulty.
This is quit technical and need to send to repair shop to isolate the faulty parts.
The output IC of your unit is RSN series and quite expensive.
Pls rate my help.
Thaks for using fixya...
Jan 21, 2011 | Panasonic SC-HT75 System
What does f61 mean?
If confirmed that the fan is working then I've suspect that your output I.C. is shorted.
Pls rate my help.
Jan 16, 2011 | Panasonic SC-AK18 CD Shelf System
AFTER A FEW SECONDS MY SYSTEM SHUT DOWN AND SHOWS ME F61 ON THE SCREEM
  1. AFTER A FEW SECONDS MY SISTEM SHUT DOWN AND SHOW ME F61 ON THE SCREEN
Oct 25, 2010 | Panasonic SC-AK300 CD Shelf System
When turning on the Panasonic DVD player the unit stays on for 3 seconds and reads "Hello", then reads F61 and turns off. What causes this and how can it be resolved?
The abnormalities an output or power supply circuit of POWER AMP.
In normal operation, when DCDET2 goes to "L" (Low) (Not during POWER OFF condition), F61 appears on FL Display and PCONT goes to "L" (Low).
This is due to speaker output has DC voltage or fan is not working.
May 18, 2010 | Televison & Video
F61 error message
F61 IS THE ERROR CODE FOR A FAULT IN THE AMPLIFIER STAGE OF THE UNIT, if the power fan or supply is okay then THE MOST LIKELY CULPRIT IS THE AUDIO OUTPUT IC, WHICH IS A MULTI LEGGED DEVICE SCREWED TO A PIECE OF METAL USED TO COOL IT, IN PANASONICS ITS PREFIX WILL PROBABLY BE "RSN" BUT IT COULD BE "STK", MAKE A NOTE OF THE NUMBER AND SEARCH ON LINE, DONT FORGET TO CLEAN OFF THE OLD HEATSINK COMPOUND ON THE HEATSINK AND REPLACE WITH FRESH.f61 means theres is a fault with audio output ic, usually there is dc on one of the speaker output rails, replacing the audio output ic will usually cure this but check speakers and leads for shorts before reconnecting to the unit
Sep 28, 2009 | Panasonic Televison & Video
F61 appears on my setero when i push play
my dear friend. this error message means something is broke on the audio power.
the unit give that message when the chipset find fix current or signal on any audio channel.
the most common means you have to change the audio amplifier unit. sorry but i know is the true.
Jun 15, 2009 | Panasonic SC-HT830V System
Panasonic stereo SA-PM28 displays fault code F61 then switches off
Hi dearnley1
The error code your unit is presenting relates to either a speaker cabling fault or a fault speaker. Sometimes, it is neither, and may be a fault inside the unit. Needless to say the unit is in protection moe to prevent more damage occurring. Check you speaker wiring for any short circuits or frayed wires. If all appears to be ok, disconnect the wires from the unit and see if it turns on and stays on then. If it still presents f61 with speakers and cable disconnected, then I am afraid that you may need to take the unit to a Kenwood service center near to you for an inspection . Good luck
regards
Graeme
Apr 06, 2008 | Audio Players & Recorders
F61 error
Hello....
Isolate problem by disconnecting Amplifier ic (RSN),if f61 still appeares after disconnection of RSN ic ,than check voltage supply rails ,may be one of them has irregularities.
Gopali
Dec 14, 2007 | Panasonic SC-AK300 CD Shelf System
Error F61
I have just struck this problem on a friends unit and here is what I did
Disconnect DVD player and all accessories and connections
Problem still occurs
Open machine ( remove three screws from back and slide top cover off. inspection of the inside top cover shows a black patch just above the fan unit
manually spin fan
power up unit and f61 no longer shows up
I think this miaght be a problem with the fan not spinning up at start and the machine then shuting down
I will fit a new fan and see what happens
Dec 05, 2007 | Samsung HT-DS610 System
710 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
