Question about Panasonic Palmcorder PV-GS9 Mini DV Digital Camcorder
Camera keeps saying to push the reset button
The camera keeps saying to push the reset button, it doesn't do anything once I do. It appears to reset itself but then goes right back to the same thing? What can I do to get it out of this?
  • 1 more comment
  • forbes1 Apr 29, 2008
    my camera's tape compartment is down with the door open and will not return up so i can close the compartment
  • Anonymous May 26, 2008
    I can't use the camera, as soon as I turn it on "Press the reset button" is displayed. If I press the reset button, the camera reset itself, but I after resetting itself, I get the same "Press the reset button" message..
  • lauchd Jul 14, 2008
    I've the same problem and have tried using a recharged battery.
3 Suggested Answers
  • 848 Answers
SOURCE: PV GS9
replace a new battery ......because the battery has to supply power to display , flash ,motor etc..........
Posted on Jun 23, 2008
  • 4 Answers
SOURCE: NEED HELP
G'day,
I also have the same problem and after almost buying a replacement I thought I would try one time to get it to go.
What I did was start the cam without a tape in it, let it bring up the little red icon indicating no tape inserted, (it hadn't started flashing "PLEASE RE-OPERATE AFTER PUSHING RESET BUTTON" at this stage) then I inserted my tape. Hey presto, it works although for how long I don't know. I'll immediately start burn my tapes to disc while the going is good.
Hope this helps someone
Posted on Feb 21, 2009
  • 4234 Answers
SOURCE: push the reset switch
The means that the powerup self test is not completing successfully. If there is no error indication in the viewfinder, this unit will need to see a Panasonic servicer for repair.
Dan
Posted on Oct 19, 2009
My IBM computer doesn't recognize when I plug in the usb camera patch cord and even the display goes blank on the camera. So do I need a new driver or camera
Welcome to Fixya
Did you accidentally dropped the camera? You should be able to see options when you plug in the camera to your computer. Try to reset the camera first to factory state as part of our initial troubleshooting.See procedure below:
Select reset settings icon Press set button Reset setting screen should appear then press YES Press the SET button Camera setting should be reset then test the issue again
Thank you for using Fixya!
Jun 10, 2011 | Sanyo VPC-C5 Digital Camera
HTC touch HD camera problem
If you done, all what is possible. Now try do next:
Push camera button and wait until camera frame will loaded. Dont release camera button. Now push hard reset key. And during restart keep camera button. Whan system will loaded, you can try use camera.
Mar 06, 2009 | HTC Touch HD Smartphone
I am not able to use front camera on my nokia 3120 classic .
hey this camera is not for viewing or capturing photos.
This camera is used for viedo confrencing or for viedo call.
u cant use it until u have the 3G technology in ur city..
so hav patience u will use it very soon as 3G technology has started in India
and will reach ur city soon.
till then have fun with ur 2megapixel camera located behind ur phone..
Jan 11, 2009 | Nokia 3120 Cellular Phone
Samsung l730 camera
take out your memory card, check the left side that says lock with the arrow down the very side with small white button to unlock slide the up or push the button up to unlock your card.
hope it works.
Oct 19, 2008 | Samsung Digimax L730 Digital Camera
Faulty d40x
I would start by looking at all of the push buttons on the camera. One may be stuck down.
Jul 23, 2008 | Nikon D40x Digital Camera
My camera won't turn on
Hey GClooney,
Most cameras come with a 1 year manufacturers warranty so the first camera is most likely covered by this and I would have it looked at by an authorized service technician. If you dropped you Polaroid a300 camera then there is most likely internal damage and that should also be addressed by an authorized service technician. I will say that digital camera repairs often exceed the value of the camera, but the first camera repair would most likely be covered by its warranty. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 17, 2008 | Polaroid a300 Digital Camera
PUSH THE RESET SWITCH PROBLEM
hmm...maybe:
You need to know in which position was camera turned of.
So try turning it on in RECORD OR PLAY position.
It will work then...
May 04, 2008 | Panasonic NV-GS15 Mini DV Digital...
Press the reset switch
Same "Push the reset button problem in panasonic gs 200 camera. i turned it upside down but it didnt worked out. its an expensive camera please please please tel me how to fix "Press the reset switch" problem
Dec 26, 2007 | Panasonic NV-GS11B Mini DV Digital...
Camera keeps resetting the settings when turned off
Possible solution?
PROCEDURE
1. Initialize the system.
a) Enter the TEST mode.
b) Select "3:ROM UPDATE" and press SET button.
c) Next, select "5:SYSTEM INITIAL" and press SET button.
d) The following message appears.
SYSTEM INITIALIZE
START ...
PUSH OK KEY?
e) Press SET button and System is initialized.
"SUCCESS !" appears on the monitor.
2. Write firmware.
Update the firmware version"
Write the firmware.
If the TEST mode boots automatically, change "USB TCC ON" to "USB TCC OFF".
Nov 06, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Panasonic Palmcorder PV-GS9 Mini DV Digital Camcorder Logo
108 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
