Question about GPS
Tomtom dosent hold charge and wont turn on - GPS
  • Mish Mash Jul 16, 2008
    My One XL won't turn on, what the ..... Lights on, tried to reset, nope doesn't work. I called tech support, still doesn't work : ( - Help?
  • t_magnanelli Jan 02, 2009
    I have the same problem
Have you tried to reset by pressing the reset button with a paper clip?
Posted on Apr 12, 2008
My tomtom gps wont come on
If you are sure the battery is fully charged, Press and hold the power button till it turns on!
Oct 24, 2014 | Tomtom GPS
I push start button and hold this more than 2 seconds but the starting screen is not opening i also connect to battery charger from car and then pushing again to start but no reaction i have tomtom...
The issue could be a low power in the Tomtom and that is the reason it is not switching on. Now here the problem could be with the charging cable/wire from the car charger which might not be giving power to the GPS. Check for the fuse at the connector.
If the fuse is blown off the power wont goes into the GPS and it wont get charged and wont swich on. Look at the tip of the connector which has that spring like contact. You will be able to turn that to open it and find a fuse. Replace it with the right "amp" as the existing one. You will get one from Radioshack.
If you have already checked it and sure it is charging could be issue with Tomtom itself..Good luckKris..
Jun 18, 2011 | Tomtom ONE XL GPS
Put on charge for two hours still wont turn on
make soft reset make sure batt is full hold on/off button for more then 15 seconds your tomtom will start again.
Feb 15, 2010 | Tomtom XL V2 GPS Receiver
My tom tom go920 wont hold a charge. from the car or cpu
Try recharging the battery in the car, and also at home with the USB cable.
If you see that it does not hold charge in both case, then you may conclude that the battery is defective. You should compare the TomTom claims with the actual result.
If battery is defective, you should be able tp replace it. Go to the TomTom onlibe store.
Jan 24, 2010 | Tomtom GO 920 GPS Receiver
Tomtom wont come on, tryed the reset still wont work, it has been chargeing for three hours
You battery is dead. Even though it is saying charging, your battery is not accepting the charge.
Nov 26, 2009 | Tomtom ONE GPS Receiver
Tom tom xl does not turn on. been on charge all night and using car charger still makes no difference
try the usb cable to your. this is the recommended method to charge a tomtom when it wont power on. for reasons unexplained by tomtom they do not recommend the car or house charges.
plug it in via the usb cable to your computer for a few hours(make sure the green light is on and nice and bright) then press and hold the power button(this could take up to 20 seconds)
bill
Oct 15, 2009 | Tomtom ONE GPS Receiver
My tomtom won't turn on when I've charged it for several hours in the car and now at my computer. The green light is on but I still can't get it to turn on.
try the usb cable to your. this is the recommended method to charge a tomtom2.gif when it wont power on. for reasons unexplained by tomtom they do not recommend the car or house charges.
bill
Oct 15, 2009 | Tomtom GO 700 GPS Receiver
Tomtom 720GO wont turn on
The problem was solved as described in my posting of Aug.15,2009
Aug 15, 2009 | Tomtom GO 720 GPS Receiver
Hi my tomtom 910 go wont switch on ], but when useing the charger the little green light lights up and will stil not switch on ive tries the hard resetting and does not work
I've had a similar problem on 2 TomTom 910s.
First, try holding in the reset button while holding the power switch down for 5 seconds.
If that doesn't work, let it charge for 12 hours and while it's still charging, hold the power switch down for 5 seconds.
It worked for me on both
Good luck
Jun 07, 2009 | Tomtom GO 910 GPS Receiver
Tomtom GO 910
Check your battery symbol.
On mine, the battery is dead (or mechanically disconneced inside).
You need to reset the unit by pressing the tiny button on the back.
Problem is that when you remove the unit from the charging stand, the dead battery does not allow you to press the reset button. (Pressing the reset button with no battery cannot reset the unit)
IF you could press the reset button while plugged into the charger, you could get you unit working again. But..alas, the design of the unit prohibits you from doing so.
Chances are if you fix the battery problem, you will have a usable unit again.
Aug 19, 2008 | Tomtom GO 910 GPS Receiver
GPS Logo
564 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
