Question about GE Profile WPSR3120WWW
Front panel removal
How do i remove the front panel on my GE WPSR3120WWW
  • 1 more comment
  • Anonymous Mar 26, 2014
    how do i remove the front panel
  • Anonymous Mar 28, 2014
    how to remove front panel and door
  • Anonymous Mar 29, 2014
    How do I take front panel off of dryer? GE - DVLR223EG1WW
    Genius:
  • 1,073 Answers
Use a small putty knife move in 4-5inches from each edge of the frount push in the putty knife to the top release clip . it will feel springy when you have found the clip. push in the putty knife and pull out on the side of the panel, do the same process on the other side and it is loose
Posted on Apr 12, 2008
Remove front panel ge spacemaker dryer
Here's the trick: The Spacemaker dryer is the same as many other GE dryers but is upside down!
1. Unplug the dryer.
2. Flip the dryer upside down so the white panel is now on top and the unfinished steel panel is on the bottom.
3. Remove the 2 screws that connect the bottom, white panel from the back and lift up to remove.
4. Pull off the Settings and Fabric knobs on the front of the dryer. Take off the front control panel (remove the 2 screws).
5. Remove the 2 screws that attach the front panel (located behind the control panel you just removed). Hold the dryer drum by the top edge and pull the front panel away (note that the panel will be hooked to the rest of the dryer at the bottom corners). DO NOT PULL AWAY ENTIRELY!
6. Disconnect the wiring that is attached to the front panel (these come apart easily by hand but you might want to mark the wiring so you know where to connect it when reassembling).
Apr 05, 2012 | GE Spacemaker DSKS433EB Electric Dryer
How to remove the agitator on a GE ProfileWPSR3120W0WW? The utube video (describing a bolt at the bottom) does not describe accurately what we have. Softener dispenser removal only yields a clear plastic...
Your washer is close to the one in the video but as you know not exact..that agitator coupler shown in the video bolts down under the agaitator. To remove your agaitator which locks into teh agaitator as shown just pulls off....so to remove your just grab the bottom of it and pull straight up and off of the agottaor coupler.
GENE
Sep 07, 2011 | GE Profile WPSR3120WWW
Need to know how to remove agitator
To remove the agitator on a GE washer you reach down in and just pull it up to get it off. Sometimes they are stuck a little so it is hard to get to move. I hope this helps.
Mar 20, 2010 | GE Profile WPSR3120WWW
How do you remove the agitator from ge profile washer wpsr3100w0ww
If you take your washing pot out of the centre consol then underneath that a little way down is a plug with little handles on it. Pull at this and it will come free then underneath that is a bolt i think it's a 10mil unscrew this and the agitator will come out.
Hope this makes sense and helps
My GE washer won't pump. It clicks at that part of the timer. It does agitate so the motor is good. Is it the timer?
I bet you have strings or coin in the pump impeller.. Remove the front panel remove the pump. Take it apart and clean it out.Easy fix.
MANUAL
Sep 09, 2009 | GE Profile WPSR3120WWW
Ge wpsq3120t2ww I have a broken control knob, how do i replace this?
Knob(s) on left side of machine just pull off. Make sure the metal D clip comes off too. Push new knob on.
Timer knob: Pull knob out and remove nylon clip off back side of knob. (use a thin screwdriver to push it off, or a thin needle nose plier to pull if off) then knob pulls off easy. Push new knob on with clip already in place. Easy.
Jul 08, 2009 | GE Profile WPSR3120WWW
Ge washer
remove top cover by 3 screws on rear then 3 screws in plastic control panel back. remove screws holding console on, lift up to remove, screw in dispenser area as well. remove lower kick panel and lower front panel screws. remove door lock screws and wire clip around boot. remove 2 upper front panel screws. there is another wire clip around boot at tub.
Apr 22, 2009 | GE WBVH6240F Front Load Washer
Won't agitate during wash cycle, makes noise w/o movement
If you are able to tilt the machine back and check to see if the belt has fallen off.
<a href="http://tclaundryrepair.com/">St Paul Appliance Repair</a>
Feb 25, 2009 | GE Profile WPSR3120WWW
WPSR3120 agitator wont spin
just pull up very hard with a hard ****
May 11, 2008 | GE Profile WPSR3120WWW
Wash machine
Yes you can remove the front panel by putting a puddy knife between the top and front panel there are clips that you can push on after you remove the front panel you will see screws to remove the top, you will see 4 black rubber pieces that are on the 4 corners off the top of the tank one or more may have snapped they are very easy to replace. always make sure you have the washer unplugged first.
Dec 21, 2007 | GE Profile WPSR3120WWW
Washing Machines Logo
131 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
