Question about Dryers
Hooking up a 4 prong plug to dryer Maytag Neptune MDE5500AY Electric Dryer Solution by: Krazytech (172 solutions) two PLease show solutions, with diagram if available
    President:
  • Dryers Master
  • 2,651 Answers
Easy enough, black and red go to either end of the terminal block behind dryer(makes no difference which), the white MUST go to the center terminal, and the green ground must be hoooked to the ground strap, probalby already a green wire screwed there already as well
Posted on Apr 12, 2008
Maytag neptune endeavor 3 prong electrical cord conversion
Yes this can be done but this is removing the ground wire in the plug which if you have a thunderstorm and a purge comes threw it may blow the board now this is a maybe so it will have to be hooked up L1Black L2 red And white. on the back of the dryer instead of L1 L2 Common and ground. They have operated this way for 20 years. Please rate my solution and leave testimonial it is how i earn my achievements thanks in advance.
Apr 23, 2012 | Maytag Neptune MDE5500AY Electric Dryer
How do you change a 3 prong cord to 4 prong power cord on a maytag neptunre MDE4000ayw
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Aug 03, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Switching from a 3 x prong connector to a 4 x prong connector. How and where do I ground the 4th extra prong to the dryer?
heatman101
Oct 13, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Change 3 prong to 4 prong plug
Hi
Thanks for using FixYa. Please check this picture which will sort out everything for you:
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 04, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer loses power
YOU NEED TO HAVE AN ELECTRICIAN,OR SOME ONE WITH KNOWLEDGE AND A METER TO CHECK YOUR VOLTAGE..PLEASE DO NOTING ELSE! YOUR ASKING FOR A FIRE..I KNOW THIS ISN''T THE ANSWER YOUR LOOKING FOR BUT IT MAY SAVE YOUR LIFE...RDS
Apr 23, 2010 | Maytag Neptune MDE5500AY Electric Dryer
WHEN I MOVED MY NEPTUNE DRYER TO OUR MANUFACTURED HOME I HAD TO CHANGE THE PLUG FROM A THREE PRONG TO A FOUR PRONG AND CODE 88 IS ON, I WONDER IF I HAVE TO HOOK THE GROUND UP DIFFERENT?
There is a jumper in between the neutral and ground terminals. In order hook up the 4 prong plug correctly you need to remove that jumper to separate the ground and neutral terminals.
Nov 12, 2009 | Maytag Neptune MDE5500AY Electric Dryer
easy enough, black and red go to either end terminal behind dryer(makes no difference which, the white MUST go to the center terminal, and teh sreen ground must be hoooked to the ground strap, probalby already a green wire screwed there already as well
Apr 05, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
91 people viewed this question
Top Dryers Experts
