Question about Dishwashers
Problem with conia cdw1211 dishwasher
The 3 and 4th light on the dishwasher start to blink half way through wash, it does not complete wash cycle. Last time this happened the serviceman tipped the machine and drained water from base, we have tried this but its not helping. I have a CONIA cdw1211.
  • 2 more comments
  • hilaryw Sep 11, 2008
    Sounds about right as the water does not heat at all. I would never buy this brand in anything again. I have a 2 year warranty, first year part and labour, second year which I am in only parts covered. Get this, $104 call out fee and then $27 every 15 minutes after for tech. I may as well wait four months till the extended warranty kicks in and parts and labour are then covered.
  • thundercats0 Nov 22, 2008
    Hi, we have a conia dishwasher cdw1211 and the 3rd and 4th lights are flashing and beep beep beeping............ It just stops towards the end of the wash cycle when this happens. I cant find my instruction manual to try to solve this problem. Thanks.
  • matt850 Jan 12, 2009
    I have just had the same problem, i think it relates to the rinse aid being empty, but on refilling it worked once then still the light flash again.
    Any assistance on fixing be most appreciated
    Cheers
  • zetec-lucind May 18, 2009
    We rent a house and it has the conia cdw1211 and has the same problem as listed above, because we rent we didnt have a manual, thats why I came online, to try and find out what the problem was, and I'm glad I did because now I know it is not just ours that is doing the 3rd and 4th lights flashing thing and beep beep beeping thing. Thanks for that. Lucinda
Had same problem - was advised by service centre to remove secondary filter (round mesh cylinder in main filter on floor of machine) & discard it as it became coated with oil & caused the sensors to malfunction. Fixed the problem immediately.
Posted on Aug 14, 2009
If the filters aren't cleaned, the waterflow out is disrupted and triggers a cut off. Clean filters. Turn machine off, tilt it to empty out all the water. You may have to undo the outlet hose to pull the machine out. Put it back...turn it on and cross your fingers.
Posted on Jun 13, 2012
I wrote a long solution that works. However the site did not. If you want help email: endorphinoveride@yahoo.com
I am not a spammer, It just took a long time to write so I'm not doing it here again.
Cheers Matty
Posted on Apr 18, 2009
We have the same it says the heater elemet or temperature sensor is malfunctioning !
Posted on Sep 09, 2008
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
How do I download a workshop manual and/or a wiring circuit for a Conia dishwasher model CDW1211/1212S
There should be a wiring diagram under the control panel cover in a little envelope!
Oct 19, 2014 | Dishwashers
Dishwasher started up....didn't notice it quit running overnight...dishes seem only half clean. The "clean" green light is blinking. Tried opening and closing and then re-starting it. Can't get...
Greetings,
there is a temp related problem..this could be in the wash cycle not letting water get hot enough or a heater failure....remove your kickplate..there is a tech sheet..it explains how to reset this blinking light.....Bruce Denton
Jan 18, 2011 | Whirlpool Dishwashers
After the wash cycle dishwasher beeps
Hello, welcome to FixYa. While I don't have access to my PC files at the moment as I am on my iphone, I believe this is the procedure for most B/S/H/ built dishwashers ( that means Bosch, Thermador, Siemens and Gaggenau ). To Enable or Disable the Cycle Completion Signal... 1. Open the door, hold down the ?Quick Wash? button and simultaneously turn the Dishwasher on. The ?Quick Wash? light will blink (program mode). 2. While the light is still blinking, push the ?Quick Wash? button. ? If the machine beeps, then the Cycle Completion Signal has been enabled. ? When you push the button again and it doesn?t beep, it means that the Cycle Completion Signal has been disabled. 3. Turn the Dishwasher off to take it out of program mode. I hope this answer's your question. Thank you for choosing "fixya". Please rate the solution favorably if indeed it was helpful, if not please let me know. Good luck. macmarkus :)
Jul 13, 2010 | Bosch 24 in. SHV4303 Built-in Dishwasher
Beep's incessantly after cycle is complete. How can we re-program it to turn off after one or two beeps?
Hello, welcome to fixya.
1. Open the door, hold down the “Quick Wash”
The “Quick Wash” light will blink (program mode).
2. While the light is still blinking, push the “Quick
Wash” button.
• If the machine beeps, then the Cycle
• When you push the button again and it
doesn’t beep, it means that the Cycle
program mode.
Good luck.
macmarkus :)
Jun 28, 2010 | Bosch SHU9915UC Dishwasher
CONIA DISHWASHER CDW1211 -Thelittle door that
i find it hard to get parts for these because the are imported from china.it may be better to replace the dishwasher
Jun 08, 2010 | Dishwashers
My Ariston LI 700 I dishwasher doesn't complete wash cycle
dear customer,
 we recommend u to perform the following checks on ur dishwasher,
  1. Test the timer motor
  2. Test the thermostat
  3. Test the heating element
for more details for self test instructions try the link http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
Plz rate this solution.. thank you..
Apr 08, 2009 | Dishwashers
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Dishwashers Logo
2,468 people viewed this question
Top Dishwashers Experts
Owen Barnes
