Question about Brookstone 538744 Remote Control
Codes for palsonic televisions
I have a palsonic television and there are not any codes in the manual for this television can you please tell me one.
Thanks
  • 236 Answers
Hi, that TV is not listed in the code list for your model.. You can try an automatic search by doing the following:
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. The
remote control is in programming mode
3. Press and release power. The POWER INDICATOR flashes once and stays on
indicating the unit is in Power Scan mode.
4. Press CHANNEL + or CHANNEL - repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
If the device responds, the remote control has been
programmed. If the device does not respond, repeat steps 2-5.
For future needs, here is the link to your manual:
Bookstone 538744 remote manual
Posted on Apr 12, 2008
  • Dave MacPhee
    Dave MacPhee Apr 12, 2008
    ** sorry, I meant to say you are right, that code is not listed **
  • Dave MacPhee
    If that doesn't work, it may not be compatible with your tv...
    Scholar:
  • 170 Answers
Sounds like you need to contact brookstone support.
http://www.brookstone.com/service/service.asp?cust_serv_id=200&cmid=hdr_custserv&cm_re=A_Hdr*CS*CS&cm_sp=Exit*NAV*Hdr
but from what i can see they don't support this tv. I have seen a few posts that
One For All 6 URC-7562 Universal Remotemight do the trick with one of these codes...
2811129 Palsonic 0264 0412 0037 0217 0377
but it looks like you'll be getting this from the Australia or UK.
I have a palsonic model no: TFTV492LED and I can't change it off AV1. I want to put it on HDMI I have no remote either.
Try the front panel button labeled Source; it's the second button from the left. (The first button is the Power button.) All of the buttons are on the right hand side of the bottom frame of the TV. Use the Channel Up/Down arrows to navigate through the list of inputs. Try waiting for the selection to take effect. (The documentation says press OK or the Volume Up button. Sometimes, the Source button on the TV functions as an OK button. This isn't clearly identified for the Palsonic.)
If the HDMI input is greyed out, the TV may not be seeing a compatible signal from the source. Try turning on the device when the TV is off, then turn on the TV. I'm not sure if this TV will correctly see the signal from a computer. However, on some laptops, you'll need to enable the external video first. This is disabled to save power. Then turn off the computer. Finally, turn on the TV before turning the computer back on.
Palsonic has the manual available for the TFTV492LED on the product (discontinued) site under the Downloads tab. See http://palsonic.com.au/archive/led-tv/tftv492led.htm . The direct link to the manual is http://palsonic.com.au/customer_service/led-instruct/Palsonic_TFTV492LED_Manual.pdf .
I hope this helps.
Feb 29, 2016 | Televison & Video
I have a Palsonic TV model 4878. It has no av outlets. How do I connect it to my set top box? It appears to have what looks like a SCSI plug...
Please review your Owner's manual. and or your set top box. Ask your cable? supplyer customer service and or your set top box
Owner's manual.
Mar 18, 2015 | Televison & Video
How to program and install my tevionlarge numbered remote control arc 2030 to a palsonic television
Set-up codes to check are 0049 0054 0075 0099. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls.Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Oct 06, 2014 | Televison & Video
I have a Palsonic TV and a Chunghop Universal remote but I can't find the code for pairing the 2. Does Palsonic share codes with another brand.
Palsonic brand TVs have no set-up codes with Chunghop remote control. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the relative post easily.
Aug 15, 2013 | Televison & Video
Need a remote for a PALSONIC 32'LCD TV Model no PLCD32HD Thanks
Universal remote control setup codes to Palsonic brand TVs are 028,019,092,082,045. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and setup instructions to some popular model remote controls are given.
Mar 07, 2013 | Televison & Video
A Universal remote which will work on a PALSONIC television?
It will be very difficult to get a sutable universal remote for this set. You can try. That's all.
May 10, 2012 | Televison & Video
My srp2008b/86 remote control wont connect on a palsonic t.v/dvd combo?
use the code '9999' and keep searching. it took about 8 minutes to find my Palsonic. then release the off/on button!
Jul 11, 2011 | Televison & Video
I have a Palsonic 6568pft TV model and my remot at
i need more information with respect your tv or device, because in internet i dont know look your model of tv
Mar 07, 2010 | Televison & Video
Brookstone 538744 Remote Control Logo
7,648 people viewed this question
Top Brookstone Televison & Video Experts
danoyachtcap
danoyachtcap
Tom Chichester
Are you a Brookstone Televison and Video Expert? Answer questions, earn points and help others
