Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
MOTOROLA W385 HOW CAN I CONNECT MY BLUETOOTH H700 ON MY PHONE?
    Brigadier General:
  • 7,752 Answers
Press and hold the power key for 10sec on the headset and make you r phone BT visible for the phone o paired with it after which it will ask or the pcode 0000
Posted on Jun 09, 2008
My motorola h700 won't turn purple to connect to my motorola i576
Make sure the battery is good in your H700.Make sure your Bluetooth is enabled on your i576. To do this, go to Contacts>More>Bluetooth>Setup>Power> then select On. Back up one level and select Link To Devices. If everything is correct, they will find each other.
Dec 20, 2009 | Motorola Mobility H700 Wireless Headset
I have a blackberry storm and im trying to pair my bluetooth h700 with it. it found the headset but it keeps saying connection successful the 2 seconds later itll say connection terminated. all my...
Hold down the connect button on headset until steady purple light comes on, then open the boom.
Search for Bluetooth devices on the phone. When asked for a pin, use "0000". Now the H700 will show up in the Bluetooth device list, but it will not connect. Put the headset in pairing mode again, this time go to the h700 listed on the phone and select connect. Now the devices will work as normal. When you open the boom on the h700, it will connect to the phone.
Jan 18, 2009 | Motorola Mobility H700 Wireless Headset
Motorola bluetooth pairing
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H700 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
Motorola H700 Bluetooth connection problem
Tips:
Apr 01, 2008 | Motorola Mobility Bluetooth...
Bluetooth
removing the bluetooth is as simple as this:
menu, settings, connectivity, bluetooth, my devices, press down to get to the device you want to delete, press options, then delete.
h700:
menu, settings, connectivity, bluetooth, my devices, (should have at the top: search for new devices scrolling). Click that:
h700 bluetooth should be in pairing mode:
hold the center button down and wait for it to turn solid blue: the go back and search for new devices on the phone, when it finds the bluetooth, enter 4 0000 zeros for the passcode. The click if you want it to automatically connect or not.
Your done!
Clint Cartee
Feb 26, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Reg: H700 connection with sony ericsson 580i
You may have to get a bluetooth headset specifically used with Ericson or change bluetooth setting on your cell to handsfree
Jan 08, 2008 | Motorola Mobility H700 Wireless Headset
H700 will pair, but won't connect.
To successfully pair the Motorola 700 with the Centro:
Select Bluetooth from the Home screen.
Select "On".
Under "Visibility", select "Visible".
Now click "Setup Devices".
Click "Hands-free Setup"
On the Motorola earpiece, with the flip-out mouthpiece in the closed position, press and hold the multi button until ring around it glows purple. Flip open the mouthpiece.
Now click "Next" on the Centro's screen.
The Centro should find the Motorola. Hold the Motorola to the right side of the phone if you have difficulty getting the Centro to find it.
Once found, click the Motorola H700 listed in the window and click "OK".
The Centro will ask for the device password. Enter 0000. Be sure that the checkbox for "Add to trusted device list" is checked. Click OK.
The two devices should now be paired to work together and the Motorola's multi button should rapidly blink blue; NOW click "Done".
You will be taken to the Trusted Devices screen.
You will see your Motorola in the list of Trusted Devices. Click on it to highlight it, if it is not already highlighted.
Click the menu drop-down key (located to the right of the ALT key).
You will now see a drop-down at the top of the screen that says "Connect". Click the "palm" center button on your Centro.
NOW the two devices are connected. The phone name will now be bold, and a small Bluetooth icon will appear to the right of it.
When you click the Phone key on your Centro, you will see a tiny blue headphone symbol now at the top right of the screen where the Bluetooth icon used to be.
To use the earpiece:
Flip it open and hang it on your ear.
Dial the number you want to call on the phone.
Press the multi button once and now you should be connected via the earpiece.
To receive a call, when your Centro rings, press the multi button once.
It took me a few hours to figure it out. Hopefully you can do it in a few seconds.
Dec 28, 2007 | Motorola Mobility H700 Wireless Headset
Motorola h700
5 Steps
First, CLOSE your boom
Second, Hold the talk button( about 5 secs it should turn to purple color)
Third, DO NOT release the button while opening your boom
Fourth, your BT should be in discover mode( show the steady light not flashing )
Fifth, open your phone bluetooth and search for device. Choose your bluetooth that appeared on the list ( pair code normally "0000" ).
Dec 13, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
57 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
