Magnavox 32 The TV will come on and within seconds will shut itself off. At first it would shut down and come back on, it did this for about one week. Now when it's turned on it shuts down immediately. Are Magnavox's garbage TV's. I only had this thing for two years!
    Genius:
  • 1,667 Answers
Very often this is caused by failing electroytic capacitors in the power supply and scan circuits. An experienced tech can troubleshoot for these parts and replace them. Most of the cost will be for the labour.
Jerry G.
Posted on Apr 12, 2008
Magnavox television won't stay on
I know this is going to sound strange but I have something to check. If you have LED lights in your house turn them all off. When they are off turn on your TV and see if your TV stays on. Yes, there could be many problems but this one is cropping up quite a bit. If this does not work then you need to take a look at the power supply board.
Feb 15, 2015 | SNK Magnavox 42MF438B/27 42 in. LCD TV
I have a 32 inch lcd magnavox tv. when i try to turn on the tv it goes right back off within 2 to 3 seconds. its fairly new tv like 3 yrs old. any idea?
Check your power supply. Take it apart and see if the compositors are all in good shape. If they are popped, puckered or oozing stuff out of them then you are going to have to replace your power supply. It also could be a bad inverter. Is there a buzzing noise before it shuts down? Has been doing it for a while and now won't come on at all now?
May 28, 2011 | Philips Televison & Video
I have a 32" Magnavox tv purchased in 2005, model
dear User,
pls be informed that supply capacitor are weak.
kindly change the supply capacitor
Feb 26, 2011 | Philips 32MF231D Television
Magnavox 19" TV shuts itself off.....won't stay on
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jun 04, 2009 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox TV turns itself off and on
I had a problem that has not been fixed that i had put glass cleaner on my tv and every time i turn it off it comes back on sooo i do not have a solution so i need more and cheap ways to fix my tv.
p.s. i am 9
May 19, 2009 | Philips Magnavox 32PS55S 32" TV
Magnavox 15inch lcd shuts itself off
Solutions?
Hope this helps
Mar 15, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
36 magnavox tv shuts off by itself
MAGNAVOX TV ONLY. 5-10 SECONDS AFTER TURN ON AUTO TURNS OFF-NO LIGHT STAYS ON-I AM FRUSTRATED BUT IT SEEMS LIKE THE OFF ON SWITCH JUST CLICKS BACK TO OFF-ALSO DOES SAME THING BY REMOTE
Jan 16, 2008 | Philips Magnavox MS3652S 36" TV
My TV shutting itself down
My TV is shutting off after you turn it on.Model #27MT5005D.
The light continue to blink, but thats it.
Dec 09, 2007 | Philips Magnavox 27MS343S 27" TV
Magnavox 32" tv ms3252s431 shutting off
Usually, the L01-1 chassis most common problem = weak
capacitors, such as C2455.Could be C2425......47mf/25v...
Check all caps around horiz drive xformer = an ESR meter
helps on this one + a skilled, experienced technician......T.
Nov 19, 2007 | Televison & Video
Shut down when press
1.Check whether your Remote buttons jammed else on the TV.
2.there might be some problem Remote ir receiver unit in your TV
3. Microprocessor/microcontroller unit on Remote signal receiver board
Dec 28, 2006 | Philips 32PT6441/37 32" TV
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
Electro Med Services...
