Question about Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic Espresso Machine Saeco Coffee Machine Type SUP 021YDR Display shows Ventilate when I follow instructions and turn the Hot Water and the water knob the water is not coming through. Anything I can do ? I need my coffee please help. Margaret
  • 1 more comment
  • dbwalt Dec 27, 2008
    Saeco Incanto Classic Espresso filter unit does not want to come out.
  • Anonymous Mar 14, 2014
    ventilate/hot water message does not turn off after 1/2 hour+
  • Anonymous Mar 29, 2014
    Will not make coffee water will not flow
  • 40 Answers
Do you get coffee? If it is just no water/steam, could be a blockge in the steam wand, or blockage in water lines. First test easy one - the steam wand. If the steam wand is o.k- then check for blockages in water lines/components ( pump, boiler, steam boiler). If you do not feel confortable with testing all the untis where water flows, contact Saeco USA Inc. to locate a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Posted on Jun 20, 2008
Hot water ventilate problem for Saeco INCANTO DELUXE Espresso Machine 2 signs at a time "hot water" +"ventilate" "
Place a jug under the milk frother and turn the steam knob to allow hot water to flow.
Ventilate will clear after a short time
Jan 27, 2013 | Saeco INCANTO DELUXE Espresso Machine
Coffee maker Ventilate
You need to chck the water reservoir if it in place properly, rmove it and put back in place again. The you need to turn the hot water knob to draw some water out, this will revove the ventilate massage.
Jul 29, 2012 | Saeco Incanto Classic Espresso Machine
Saeco incanto wont work display showing ventilate
<b><span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 12pt">We have a useful tip here in this link which can help you</span></b><br /> <b><span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 12pt"> </span></b><br /> <b><span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 12pt"><a href="http://www.fixya.com/support/r5772014-saeco_gaggia_spidem_ventilate_prime">http://www.fixya.com/support/r5772014-saeco_gaggia_spidem_ventilate_prime</a></span></b><br /> <b><span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 12pt"> </span></b><br /> <b><span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 12pt">Good luck</span></b>
Jul 17, 2010 | Saeco Incanto Classic Espresso Machine
I have saeco incanto deluxe coffee machine,ventilate msg appears
Check the end of the steam nozzle, make sure it is not blocked. If not then with the knob open for hot water cycle push in on the knob if that works then the tap rod assemble or the steam valve needs to be replaced.
Feb 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
I have a Saeco Incanto Classic and the ventilate message will not disappear, even after sending 4 full watertanks through the steam nozzle. The solution posted above does not work.
Having read the other reviews here, I was prepared for the cryptic "VENTILATE" message. (The manual refers to this procedure as "Loading the circuit", which doesn't help to clarify things.) Of course this refers to what Americans would call "priming" the machine. As mentioned in another review, there is a plastic hand pump supplied for priming, but that is only needed in the event that the electric pump fails to self-prime. All I had to do (following the quick-start instructions) was to select the Hot Water function; the internal pump quickly primed itself. i hope this helps Lee Davidian
Jan 17, 2010 | Saeco Incanto Classic Espresso Machine
Machine is a incanto typ sup 021ydr.
Check the tip of the steam wand make sure it is not blocked. If not then press in on the steam knob after opening, if that works then the steam valve assembly needs to be replaced.
Jul 12, 2009 | Saeco Incanto Classic Espresso Machine
Saeco Incanto not grinding
Hi Chris,
The leaking is your steam valve that has to be replaced, you can see this if you open the door and look up in the right corner there you will see water drip.
If not then you have a pipe or boiler leak.
How old is your machine?
How often do you descale the machine?
When you try to make a cup of coffee, starts the grinder for two seconds or is it dead?
Hope this will help you.
Jul 19, 2008 | Coffee Makers & Espresso Machines
Saeco incanto sirius
It can be the touch board or the "water turbine" in the machine
May 25, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Saeco Incanto Classic Espresso Machine Logo
687 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
