Question about Polaroid FLM-3701 Television
Polaroid LCD I have a Polaroid FLM-3701 HDTV. When I press "power" the LED turns blue and the set starts drawing about .2 amps. Screen never lights up. Thanks!
  • jclark52 Apr 12, 2008
    Is PS failures pretty common with these TV's. If the PS is bad would you recommend board level repair, repair/exchange pool or a new power supply?
    Thanks for your help. So that you get credited, I'll go ahead and close this one, but one final question. Is there any chance that the LCD is out and if so, what is the best way to check?
    Thanks again.
  • 2,326 Answers
It looks like your power supply might not be providing enough current to get the LCD to power up. This LCD needs about 3 to 4 amps to work properly.
Posted on Apr 12, 2008
  • Jaime Hernandez Apr 12, 2008
    I would suggest to check the capacitors in the power supply for dry or leaky conditions, specially the one that filter the 5 volts.
    PS failures are common on LCD and Plasmas.
    It seems that is hard to find replacement parts, so I would suggest a board level or component level repair.
    You might also have to check the inverter boards as well for proper functionality but to get to do that you will need to have a working PS.
Diagram where fuse is in the polaroid flm-3701
There is a fuse on the power supply board. It is labelled F1. It is a small cylinder near the AC connector. The F1 fuse is 5A 250V. How ever, capacitors are more likely to fail on this television.
The Polaroid FLM3701 has a problem with capacitors failing on the power supply board. If enough caps go bad, you will get no power. Not even a power light. Any capacitor that is swollen is bad.
May 12, 2014 | Polaroid FLM-3701 Television
Hi, my LCD Polaroid FLM-3701 went through a power outage and now doesn't get power any more. The power led doesn't show any light. I saw a capacitor repair kit available, and four 680 uF capac
The power supply fuse should be next the the ac input plug on the power supply. It should be a long cylinder type fuse, probably a T6.3AH/250V. You will want to replace those caps ASAP
Nov 05, 2012 | Polaroid FLM-3701 Television
I've got a Polaroid FLM-3701 LCD TV. I have had the TV over 4 years and it's worked great. Recently it's starting to shut itself off. I say "shut off", actually the picture goes off, the power...
It may have dying power supply due to bad caps, this is common problem with 3+years TV and monitors.
Please see my basic troubleshooting guide here:
Failed TV and Monitors:
Learn about bad caps:
Capacitors kit: he can make you a set of caps.
Or just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 17, 2010 | Polaroid FLM-3701 Television
Where is the fuse in a 3701 LCD Polaroid TV/Monitor
In the Polaroid FLH-3701, the fuse is located on the power supply board, next to the AC power connector. It is a small black cylinder. It is labelled F1. Value is 5 amp, 250 volts.
A fuse does not blow for no reason. Most commonly a fuse will fail because of a short someplace on the board. I have this same TV. The fuse blew. The reason was transistor Q6 had shorted. There are two identical paired transistors on the output side. Q6 and Q7. They are both Infineon 11N60C3 MOSFET transistors. Check those for a short. There may be a burnt smell.
More commonly, this TV will fail because of bad capacitors on the power supply board.
May 08, 2010 | Polaroid FLM-3701 Television
Have to unplug it after I turn it off to get it to come back on.
Power supply board is dead.Have dead capacitors that bulges up on it top,or puff up on it top.U know basic electronic's and soldering.Replaced these bulges and puff up on it top.Or tries wesite like, to buy a whole refurbish power supply board for the replacement.After the power supply board is fix or replaced,the power LED indicator light on the LCD panel will not flikers anymore and u will have a solid green light all the times and get the power back to normal.
May 05, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
Polariod flat screen tv when powered up power
your right there will be a bad caop in the power supply the can will have a domed or puffed top the value is printed on the side replace it and it will all set to go
Dec 23, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Blue LED light comes on but nothing else happens when turned on
It can be the main board or the power supply, look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
Please post back what you find
Nov 28, 2009 | Polaroid FLM-323B Television
Blue power light flashes No picture on a 37 HDTV/LCD Polaroid -
this might help
Dec 29, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Televison & Video Logo
370 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
