Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Dc17 -too much pet hair around the belt gears
I have had my dc17 for 8 months from Best Buy. It has been in the shop for 2 months cuz of loud noise (sounds like a jet). They have replaced the beeter bar assembly and motor. Got it home after the 2nd repair and the beater bar stops and goes. The repairman now says the gear assembly has too much pet hair around it. I have talked to Dyson directly and they say go to a DC14 which has an enclosed belt and gear assembly. But all the reports I read on the 17 is how people with lots more dogs then my Golden Retriever have had no problems such as this. They say I can continue to use the 17 but will have to clean the gears each time after I vacuum. Any advise?
  • sbetts Nov 25, 2008
    I have the exact same problem. I can't even vacuum one room without having to take the faceplate off and cut the hair off the roller...then I have to cut the hair away from around the belt. The unit is totally clean before I start and I have to clean it again before I can finish one room. I spend more time taking the unit apart then I do vacuuming!
  • 51 Answers
Go to a DC14 there is a reason why Dyson calls it the Animal. It's ment for all the pet hair and things like that, listen to what Dyson recommends you, they know their products well.
Posted on Apr 16, 2008
Y Shark "Professional" model 540 26 is making a terribly loud noise and not picking up dirt. t also gets HOT
Check( 'beater bar',suction tube to canister) for accumulation of hair,carpet fiber,pet hair,etc....cut hair,etc,with scissors,clean...might also be hair stuck in belt that drives beater bar
May 08, 2017 | Shark Vacuums
The beater bar is making a loud noise, and the dog hair is wrapping around the bar. Why would that be happening?
You probably have dirt or garbage wrapped around your beater bar. Loose carpet strings as well as pet hair will do this. If you see dog hair on the carpet its best to pick it up with your fingers as it will make a mess of a vac. Check your drive belt as it could be on its last legs as well causing the loud noise. Probably should be taken apart and belt replaced and a good cleaning as well. You should give a good cleaning once a year.
Nov 07, 2016 | Vacuums
My brush roller stopped spinning so I had to take it off and clean out all the hair that had gotten wound around it. I replaces it and now it is make a lound noise, but only when the brush is on. Could it...
Could very well be the belt. When cleaning the brush it is a good idea to add some WD40 at the ends where the plastic pieces are that hold the brush in the vacuum. The brush needs to be able to move freely around the plastic pieces. Add the WD40 and rotate the plastic pieces around the brush until they move freely. Reassemble making sure the belt is put in correctly so the brush moves in the right direction.
Please provide a Thumbs Up if this solution is of help to you. Paul
Oct 10, 2010 | Bissell Upright Vacuum - The Pet Hair...
Dyson vacuum DC17 beater bar won't turn
sounds like the brushroll motor has gone bad. disassemble the head and check the continuity on the brushroll motor
Feb 26, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
My dyson DC17 makes a loud noise when i tip the handle down to make the brush spin on the floor?
Loud noises are usually caused by worn belts, unbalanced roller brush or debris in the roller brush. Check these things. Here is a link to the belt you need:
Dyson DC17 Replacement Belt
Nov 28, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Getting hair out of gears
Best way is with a screw driver and needle nose pliers. remove belt and brush first.
Aug 24, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
The beater bar makes a horrible clunking noise when I turn it on
I just came from the repair shop. There is a recurring problem with a bearing coming out. Repair guy turned it on & said that loud noise is a symptom of that exact problem. This is a warranty item, as is the belt & on/off switch. Dyson comes with a 5 year warranty, so call their 800 number to get the name & address of an authorized repair shop.
Jun 08, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
I was having the same trouble and it was driving me nuts.  I tried cleaning and it did not work.  Then I tore the brush assembly off and looked up into where the little tooth gear is.  I saw something that did not look right.  There was a silver roller bearing laying down below the assembly.  I got some tweezers and found it was not attached to any thing.  I then cleaned out the pet hair and saw a spot where this roller goes that takes the slack out of the brush. It is a pain and takes alot of trying with pliers and prodding  with a screw driver, but I got the roller back where it goes.  It does not attach very solidly, but I put every thing back together and it works great so far.  It is a definite design flaw.  I found that you have to keep the main unit on  the floor when the brush is running.  Do not do stairs or pick it up and do couch cushions, that is when the bearing breaks loose.  Dyson needs to figure out a better design for this.  I was lucky to figure it out, but it is very hard to get to.  Again never pick up the unit when the brushes are engaged.
Jun 05, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
250 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
