Question about Acer Aspire 5100 Notebook
Trying to upgrade my 5100 from 2gb to 4gb ram
I put the two new sticks in and it resgisters 2302mb not closer to 4000mb. What is the problem
  • whosoever1 Apr 12, 2008
    ACER support sucks, this is not good news.
    Thank you for your time in answering my question.
    I appreciate your time.
  • 42 Answers
Many computers claim to be upgradeable to 4 GB of memory. While this may be true, it is also true that in order to reach 4 GB of memory the operating system needs to be 64-bit. I would be sure that the memory is seated properly first. Then I would exchange the memory. But my initial assumption is that it is too much memory for your operating system.
Posted on Apr 12, 2008
My fire stick keeps buffering what can i do?
check you r internet connection stability.
Use 5.0 Ghz connection if possible for no intereference
Oct 14, 2016 | Amazon Fire TV Stick
Won't record to a USB stick, why?
Check the connection and power supply.If it persist then it is faulty, see a closer specialist.
Jul 23, 2016 | Televison & Video
Rod sticking
make sure you have a good enough ground on your work-piece. try putting a chunk or strip of metal on or closer to your work-piece to get better current.
Apr 28, 2013 | Lincoln Electric Welding Tools
Laptop currently has three 4GB RAM sticks, is it possible to use another 8GB stick to upgrade it to 20GB?
It should. But RAM slots have a maximum RAM per slot. Have you checked with manufacturer manual to see what the max ram per slot is? And the max ram per motherboard matters too. Your mobo will only support so much ram.
Dec 07, 2012 | MSI Gt70 0nc-051us
AOD270-1824 can i put a 4gb ram in it
You can add 1GB of ram but that's it. Definately not a 2GB Stick or 4GB stick.
Sep 01, 2012 | Acer Espresso Black 10.1" AOD270-1824...
Why does memory upgrade for biostar k8m800-mam2 motherboard cause memory error beeps?
I would verify that the memory you're using is actually working properly.
Try to boot to the new stick and see if it works.
If not, it doesn't work.
If it does, you may need to replace the original stick with the same stick that you are trying to use now.
Use this site as a guide.
http://www.crucial.com/store/listparts.aspx?model=K8M800%20Micro%20AM2&Cat=RAM
Dec 22, 2011 | Biostar K8M800 Micro AM2 Motherboard
Trying to put transmission fluid in the engine, i need to know where the dip stick and resevoir are
You do not put transmission fluid in the engine, it goes in the trans-look down on the driver side (standing in front of the car hood up), there is a large black cap pretty far down, it is not a dipstick like used on the engine but is a cap with a measuring stick on the other side of this large cap-below the air filter housing, a good 18 inches down from the top of the engine and closer to the firewall
Sep 05, 2011 | 2001 Oldsmobile Aurora
What is better? to put four different rams or one single ram of 4gb in p4p800 vm asus motherboard
I would suggest going with a single piece or 2 identical pieces of RAM for expandability purposes. If you want to upgrade later, you will have the option to add more RAM. From a cost standpoint, you might be better off buying 2x 2GB sticks as a single 4GB stick of RAM might well exceed the cost of 2x 2GB sticks.
Best, Hunter
Mar 03, 2011 | ASUS P4P800-VM Motherboard
Where does the transmisson fluid go?
if its a manual transmission, you have to remove the pan from under the car, and replace the fluid and clean the filter , its a magnet clean the metal slivers with a clean cloth put new fluid in. if its a automatic u will have 2 dip sticks one is oil and one is tranny the oil dip stick is usually yellow or white tranny is red and closer to the back of the motor u need a transmission fluid funnel put the funnel were the dip stick go's u can get it from your local auto store put in the fluid your ower manual calls for and if its a leak add some none leak none slip fluid
Nov 19, 2010 | 1993 Nissan Maxima
Acer Aspire 5100 Notebook Logo
52 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
