Tv turns on & off.
Hi I hope someone on here can help me as this problem is driving me nuts.
I have a trio HDTV approx 8 months old. When the tv is on free to air channels it turns itself on & off, some days it doesnt do it at all and others it does it approx every 20 seconds, it only stays off for about 10 seconds before coming back on. I dont have this problem if the tv is on pay television, or when watching a dvd always works fine. Just on free to air channels. I have had a tv repairman out here who said it wasnt the aerial, it was the tv, it has been back to trio twice, they said they replaced everything inside, and tested it for 2 days and it worked fine. As soon as i got it home it is doing it again!.
If anyone can help it would be appreciated.
Cheers,
Mystee
    Genius:
  • Televison & ... Master
  • 1,673 Answers
If you have the set connected to an outside antenna, or directly to a cable service, this may be a grounding issue between the TV and the antenna ground.
This answer is a speculation based on some past experience.
If there is any buildup or intermittancy of a ground leakage from the AC supply back up through the tuner and on to the TV, and then to the antenna or cable service, it may trip some protection circuits that cause a shut down condition.
Jerry G.
Posted on Apr 12, 2008
Tv will not power on
Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this will help...
May 28, 2010 | Element Electronics 26 in. LCD TV
DVD Player stopped working... will not LOAD/PLAY dvds
DVDs will not load / play... problem just started... TV approx 14 months old. Recently DVD was working and the TV just "SHUTOFF"?
Mar 03, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
No picture or sound on LG 42" Plasma
Hi Craig,
Your Tv has a 1 year warranty, you should contact Customer Service as soon as possible. This is the number in the USA 1-800-243-0000
If needed this is the Global Site. www.lge.com/products/category/list/tv.jhtml
Enter your country then click on Support for the Service Number.
If this helps please rate this solution as a FixYa.
Lone99star
Jan 29, 2009 | LG 42LC2D 42 in. LCD HDTV
TV on/off
How long is your TV on before it turns off? Check the fans and make sure they are all working. The TV may be shutting off due to overheating if a fan quit working.
If you think the lamp is still good maybe try replacing the lamp ballast.
Jan 16, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Sony e55a20 tries to turn on then flashes pwr light in sets of 6
Really sorry to say but you need a tv repair man. This unit has something wrong internally. Also there is usually a reset button on the back of the tv. This is your only other option. try resetting the tv, if there is not button on the back hold the power button for at least 1 minute.
Jan 02, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Tv picture is jumping
Unfortunately, JVC service manuals are not usually available outside of Authorized service centers. That being said,anyone that services TVs should have seen similar symptoms on other sets and should be able to "fix" this one even without a schematic. Call around. In the meantime, I'll look into this a bit more.
Dan
Nov 27, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Tv unexpectedly powers off
Hi i has the same probleme..... My tv has 1 years and 6month... since two days.... the tv turn off itself...I have just take 15minute, unplug tv, and i have open in the right side the little panel...And i have clean inside!!! And i have do the same thing with the big panel in the back of the TV...After i have clean the fan...After this clean my tv is number one... and nothing turn off
Apr 21, 2008 | Toshiba 42HM66 42" Projection HDTV
Sony Grand Wega KDF-E050A10
Authorized sony repair center told me the problem was the Q Box. Ever heard of this? Part runs about 300 bucks. TV is out of warrenty as it is 2 years old. Do you think it is worth it to fight sony and get them to replace the part or just fix the TV?
Part Number is A1167541A, service rep called it a Q Box in the diag, however the web says its the b block assmy.
read this if you think it's the same problem
Feb 01, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Jkae it sounds like your hdmi tuner, I had the same problem on mine and thats what it was most likely your's went out like mine.
Hope this helps good luck
Oct 30, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
Televison & Video Logo
173 people viewed this question
Top Televison & Video Experts
Electro Med Services...
