Purple lines on screen from top to bottom 32'' proview
Purple streks have shown up on screen starting at top and running down
  • Anonymous May 03, 2008
    Ours started this tonight after the power flickered several times and went off. The last plasma we had, when it started this, it progressively became worse and ultimately quit.
    Scholar:
  • 72 Answers
You have a defective panel.
Posted on May 03, 2008
Samsung 32" LED TV Purple Line Horizontally across top of screen
Can you please change the input device to some other you know, works? If you do not notice any problem there, look for the aerial cable going close to any power line or has interference from some other transmissions of any kind nearby.
Jul 30, 2012 | Samsung Televison & Video
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
I have a purple line running up and down my 42" sanyo?
Hello; If this purple line goes fully from top to bottom, You have a bad LCD panel. If the line goes only part way down or up the screen, You likely have a cracked LCD panel ( never covered by warranty ) The LCD panel will cost more than the set sold for ! John
Jan 22, 2011 | Televison & Video
I have a ln-s3238d that i got a couple years ago. Last month it started getting a line of pixels running across the top of the screen. over the last month that problem has gron to four lines on top and...
Hi andrew, its not a big problem.. Decent TV. but the pixels are DEAD. that means you have to recover them by fixing the LCD. this would cost you around £40-60 for a 32 inch TV. hope this helps!
Nov 05, 2010 | Samsung LN-S3238D 32 in. LCD HDTV
Purple line running down screen
Hi! Try to uninstall and reinstall video driver in dev manager.If it doesnt work then check if it happens in bios if yes then it might be the video card that you need to replace, if video card is built in then you need to replace the motherboard.Try to use a external monitor and check if your seeing the same thing on the ext monitor if yes then its the monitor, if its under warranty your manufacturer will replace it for you.Hope this helps...
May 25, 2010 | Computers & Internet
Thick purple line scrolling up from bottom of screen continually
if it is a uniform pulsating line, then it is the main board or engine. if it is a fuzzy line it is the light tunnel
Apr 26, 2010 | InFocus IN72 Multimedia Projector
My proview 558 monitor has a 1/2 inch black line at the bottom
ms_biguns, You need to test one or the other, The tower should output and drive a substitute known good monitor, or a known good pc should be able to display the WIN-desktop screen on your Proview 558. Could it also be that the software in pc not set up for driving a Proview558? 12fixlouie
Feb 28, 2010 | Proview Computers & Internet
How do i fix a convergence problem on a dynex 42 lcd ..purple lines are floating from bottom of screen too top
flat screens do not have convergance
if you have have line like you discribe
you LCD screen is failing anf will need to be replace very common
try partsearch.com very hard to find parts for Dynex a bestbuy product
Dec 14, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Only getting extra large picture
Please right click on your monitor desktop
Click on "Properties"
Click on "Settings"
Look for "Screen Resolution" down at the bottom.
see if the resolution is "1024 by 768"
if not then make it "1024 by 768"
Also check "Color Quality" is set to "Highest (32 bit)"
If not then make it "Highest (32 bit)"
Click apply and screen resolution will be changed.
If it does not change then please check your graphic card drivers.
Cheers
Nov 04, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
Green purple and blue bars rolling through screen
It is probably the main total assy needs to be replaced.
Jun 26, 2009 | Samsung LN32A550 32 in. LCD TV
Televison & Video Logo
998 people viewed this question
Top Televison & Video Experts
