Sound my computer does no setect a sound card
  • 76 Answers
Sir
your computer Mother Board compny telme first Anyway see the Instructions below
first you take sound card Drivers cd insert cddrive install compart driver's for your os and model ok by if any problem uday_uday2004@rediffmail.com
Posted on Apr 12, 2008
Scale BFM588 User manual
Although the HealthOMeter.com site no longer posts a user manual for the BFM588DQ-81 scale, they do have a different model scale, BFM955-60, instruction manual that will work for the BFM588 because all the setting buttons are identical. You can download the manual for free at their site. Go to the site, under "Service & Support" setect "Instruction Manuals", then select "Body Fat Scales". Once there, find and select the BFM955-60. It will open as .pdf document and you can save it to your computer and print it out. It worked for my BFM588 scale for which I had lost the user manual.
Nov 16, 2014 | Health-O-Meter Health o Meter BFM588DQ-81...
MY NH92 ADATA External HDD detected very bad and slow some times it doesnt setected i changed my windows and test it on anothers computers but didnt change in it working. please guide me what should i do?
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if this fails to fix the problem
check usb leads for secure dust free seating
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Jul 19, 2012 | Computers & Internet
Trying to hook up a dvd and wii with direct tv and can"t get sound out of wii! HELP Can you show me where to plug cords in?
Your TV has two sets of AV inputs. One on the side and one at the back. The Wii has a 3RCA cable ( Yellow / Red & White ) . Connect these jacks to the corresponding color sockets on the side input of your TV. Select that input on the TV and your Wii sound and picture should come on.
For the DVD player you have to get a 5 RCA component cable. This cable will have 5 colored jacks, connect the White & Red to the Audio in of the TV and then connect the Red/Blue/Green jacks to the component video input of the TV.Do the same at the DVD's end also. Setect that source on the TV and you should hear the DVD sound and picture.bobhifi_31.jpg
Apr 03, 2011 | RCA L32HD41 LCD TV
My grandad has bought a computer and i tryed to show him how to play a dvd but no sound was playing. I found out there was no sound card? I dont actually know what this means but surely a computer should...
If there is no sound card. Probably it was disabled the sound and maybe there is no really sound card was installed. To make it short buy a PCI sound card, turn off your computer and install the card to PCI slot and turn on your computer and your computer will detect that there is a found new hardware. Ignore it and insert the cd installer and install the driver of your sound card. If it's ask you to restart just restart your computer to update its system. In case that there is a built in sound on your computer check your motherboard model and search for the driver from their official website and download and install, if you download the correct driver it will automatically installed your sound and your sound will be working. Have a nice day!
Jan 07, 2011 | Acer (54.AA806.001) Sound Card
How do you format sony ericsson k800i
Hi
This is what to do if you want to format the phone.
go to
Menu > Settings > Master Reset > Reset All
For the memory card you will have to connect it to your pc and delete everything including the main folders (the phone will recreate folders automatically).
Thanks.
Aug 11, 2010 | Sony Ericsson K800i Cellular Phone
How can I set-up two monitors on a SONY VAIO PVC-RS 430G?
just folowing steps
1 go to contorl panel
2 Disply icone
3 on that page settings
4 u will find disply thare is 2 option
1 is 1.plug and play single monitor
2 will show that (defold monitor ) setect this option
u will be able to use 2 monitors
Apr 22, 2010 | Sony VAIO Digital Studio PCV-RS430G PC...
I have build up a new system around DG35EC intel motherboard, i installed drivers everything is fine, but it does not setect the onboard sound card.. pls help me,, i am using xp sp3 32 bit system
Enter bios by pressing F2 at boot it must be enabled in bios depending on the bios version where it is located may vary should look for
Main:
Advanced:
Peripheral Configuration:
Audio: Enable
High Definition Front Panel Audio: Enable
Jun 13, 2009 | Computers & Internet
I was about to install a PCI sound card TM P1018 in my cpu. How will i do it?
Shut down the computer. Unplug machine Disconnect all peripherals from the computer. Remove the cover of the chassis and lay computer on its side if it is a tower. Remove the back panel, if necessary. Locate the existing sound card if there is one already installed. If it is screwed in on the side of the slot hole, unscrew it and pull the card out firmly. 8If the computer doesn't already have a sound card, find an open slot. 9Knock out or unscrew the metal plate on the card's slot holder on the back panel. Step10Insert the sound card gently but firmly into the slot. Rock it into position if necessary, but don't force it. Don't touch any connectors on the card. Step11Connect cables from the CD-ROM drive to the sound card. Step12Replace the back panel and any removed screws. Screw sound card into slot holder if it has a screw hole. Step13Reconnect monitor, keyboard, and mouse. Connect speakers to the sound card's ports. Step14Turn on the speakers and restart the computer. Step15If Windows detects the sound card upon startup, follow instructions to install the card's driver and additional software. If Windows doesn't detect sound card, manually complete the installation using the Add New Hardware control panel. Step16Play music CD to test sound card. Step17Shut down computer. Step18Replace cover of computer. Reboot computer.
Apr 24, 2009 | Computers & Internet
SOUND DRIVERS
in your computer sound card problem. otherwise please check the control pannal in sounds and vedios.
then check the computer wheather the sound card installed or not. if the sound card not installed please installed the sound card drivers.
Aug 16, 2008 | Intel Frontier Design Dakota 24-Bit PCI...
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
