Question about HP Pavilion dv4000 Notebook
My disk drive
I dropped my laptop one too many times and the disk drive on the side is broken. It won't open on it's own and if I open it with a paperclip it still won't read the disk.
  • 156 Answers
It should be taken care off easily by the technician..
As there are many possiblities of damage to have occured inside the drive, and none can easily open up and clean or repair the disk drive.. other than the technician himself.
It is better to got to the technician in this case.
If you are still under the warranty period it is better, even if not, i think there is no other way out ...
Posted on Apr 12, 2008
Laptop won'y start up has non-system disk or disk error
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 02, 2012 | HP Computers & Internet
Tip
How to detect if your hard-drive is working or not/hard disk maintenance.
Some times you don't know if your hard drive is working or not. Your external hard disk might drop on the ground, or your desktop/laptop hard drive might not be booting. Which ever the case maybe, here is how to find out the condition of your hard disk:
Put your ear close to your hard disk, if you hear your hard disk make a crackling noise, be prepared to buy another hard disk because such hard disk is damaged and cannot be fixed. Also note that it is difficult to recover files from such hard drive.
But if you don't hear a crackling sound, use your hand(s) to feel the drive, if it vibrates, it means the hard disk is in good condition.
What damages external hard drive most times is if you don't eject (safely remove) it from your computer, when it drops on the ground or hits any hard object etc
If your external hard disk stops working, firstly, check if the hard disk inside the case is in good condition by checking for crackling sounds and vibration. Once you observe that the hard disk is in good condition, this means the hard drive case is defective/the cause of the problem. Get another drive case and your drive will work again without loosing any file/data on it.
For desktop/laptop hard drive maintenance, make sure you always shut down your computer properly, don't remove the CPU's power cord while the computer is turned on. To be on a safer side, always use UPS (uninterrupted power supply) for your desktop computer.
Also, when using your laptop, makes sure its fixed at a position. Avoid any shake as the hard disk might shift from its normal position in the process.
Good luck.
on Oct 21, 2010 | Computers & Internet
CD disk drive won't work or open
you need to replace the disk drive , the optical lens is not working and that way is not spin
Feb 20, 2012 | Computers & Internet
My laptop aspire 5740 is not able to read the dvd & cd...so i am not able to installed any softwares though cd & dvd..please solve the problem..
Try opening your disk tray and cleaning the lens with a tissue and all of the drive from dust. If it still won't read you may have to buy a new optical drive as your current one has broken.
Have fun :)
Aug 21, 2011 | Acer (KV.16X04.007) DVD Drive
Wd my book flashing blue light. sill no power up
Good luck.
Jan 22, 2011 | Western Digital My Book Essential 1TB...
Hard disk tiking when power up.
Good luck.
Jan 11, 2011 | Hitachi HTS542520K9SA00 200 GB SATA Hard...
Dropped my verbatim smartdisk portable hard drive. I'm able to open the disk but when I open the file, it's all gone. what do i do?
What you have listed isn't a hard drive, It's a flash drive and it is practically indestructible by a common drop, If you can plug the drive in and access it then the drive is working correctly. If it does not say something like " Insert disk in drive E: " when you try and open it once again chances are the drive is working fine. The last time you connected it previously to dropping it you might of removed the drive before it was done. Some times Windows does not write the files right away if the computer is also busy, this can cause a delayed write failure to occur when you remove the disk before it has written the file down. If you plug it in and the computer does not see it or you get the stated message I wrote above then it's broken physically. If you can still write new files and read those then chances are you missed a write window.
May 13, 2010 | Verbatim VER95327 USB Hard Drive
Where before the hard disk made a little whirring
the unit may be dropped and something got broken can you open the unit and see if the hard disk got effected? you may need to replace it
Nov 08, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
Disc drive wont open on its own, and doesn't click back in place.
It needs replacing,not really much you can do to fix them.
Jan 15, 2009 | HP Pavilion dv9000z Notebook
Macbook won't accept CD's/DVD's in Disk Drive
do you usually lean or put any pressure on the area above the slot-load optical drive? If you have anything flat and plastic around 1/4" (about 1/2 the width as a USB plug) stick it in the optical drive until you just feel it going past the door, and rotate 90 degrees so it opens it a little. See attached photos if you aren't sure what I am talking about7804560.jpg
Jun 04, 2008 | Apple MacBook PC Notebook
HP Pavilion dv4000 Notebook Logo
20 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
