How to get print key to word - Computers & Internet
  • Viv Vek
    Viv Vek May 11, 2010
    Do you mean the "print screen" key's image to be pasted in word?
  • 156 Answers
Got it to work?
Posted on Apr 25, 2008
What keys do I use for print screen
What are the keys to print screen?
Print screen (often abbreviated Print Scrn, Prnt Scrn, Prt Scrn, Prt Scn, Prt Scr, Prt Sc or Pr Sc) is a key present on most PC keyboards. It is typically situated in the same section as the break key and scroll lock key.
Print screen - Wikipedia
https://en.wikipedia.org/wiki/Print_screen Search for: What are the keys to print screen?Copy only the image of the active window
  • Click the window that you want to copy.
  • Press ALT+PRINT SCREEN. Important: The text you see on your keyboard might be PrtSc, PrtScn, or PrntScrn. ...
  • Paste (CTRL+V) the image into a Microsoft Office program or other application.
Copy the window or screen contents - Office Support
https://support.office.com/.../Copy-the-window-or-screen-contents-98c41969-51e5-45e... What keys do use for print screen Google Search
Oct 23, 2017 | Computers & Internet
How to print vertical
Vertical printing is one of the 9 styles of print available. To select a print style:
Hold down the CODE key.
Press the STYLE key once. The display will show the current style.
Still holding down the CODE key, press the STYLE key again. The available style will appear in order as you press the STYLE key.
When the VERTICAL style appears release the CODE key.
Jul 27, 2016 | Brother P-Touch 300 Thermal Printer
How do I get my prtscn to print straight
Instructions
  1. Use PrintKey2000 to Direct Print
    • 1Download and save PrintKey2000 or PrintKeyPro from the "Resources" section. Save the file in a folder named "Printkey" on your "C:" drive. Double click the .exe file and follow the onscreen instructions for a problem-free installation.
    • 2 Access the Print Key program by double-clicking the hand icon in the bottom right hand corner of the task bar.
    • 3 Double click the "Options" tab in the upper right hand corner. Click on "Define Hot-keys." Set a hotkey for printing the full desktop and for printing the active screen you are in.
    • 4 Navigate back to the "Options" tab and select "Direct Print (No Dialog)" so that it has a check mark next to it.
    • 5 Select the "Printer Options" function on the main program screen. Select the printer you want the print jobs sent to.
    • 6 Select a screen to use as a test. Press your hotkey for printing the full desktop and then the hotkey to print the active page. You want to make sure both functions work properly.
    Use the Print Screen Function Without a Plug-in Program
    • 7 Press the "Print Screen" key on the keyboard to print the full desktop. Press the "Alt" key plus the "Print Screen" key to print the active window.
    • 8 Click "Start" in the lower left of the taskbar. Navigate to "Applications" and choose the Microsoft Paint program.
    • 9 Click "Edit" in the program screen and click the "Paste" option. You will now see a copy of your screen capture.
    • 10 Navigate to "File" and save the screen capture as a .jpeg file. Navigate to "File" again and click "Print" to send the job to an installed printer.
    Using the Print Key Function with ScreenShot 2 Print
    • 11 Download and install ScreenShot 2 Print. ScreenShot 2 Print has a free trial option, and as of May 2010, costs $7 for the full version. Configure the program to print to a designated printer from the onscreen commands. The screen captures will print automatically when the required keys are pressed.
    • 12 Hold down the "Control" key (Ctrl) and the "Print Screen" key to capture a screen shot of the full desktop. The image will be sent directly to the designated printer.
    • 13 Hold down the "Shift" key and "Print Screen" key to take a screen shot of the active window, which is sent directly to the printer.
May 21, 2014 | Microsoft Computers & Internet
Magenta toner spots pages
Step 1:
Print out about 10 blank (all white) sheets and see if the spots clean off.
Step 2:
Check to see if the toner is Dell type brand, if not try installing Dell brand and run 10 blank copies then run color test print using menu key.
Press menu, press arrow down key till 'print reports' is displayed, Press 'check key' then press down key till 'color test print' Press check key to print color copy.
Apr 10, 2013 | Dell 3010cn Laser Printer
I am using Lenovo Y550 laptop. I want to use the Print Screen command but unfortunately there is no Print Screen key in this laptop. Could anyone please help me with regards to this issue. Thanks.
Most laptops do not have a dedicated print screen key, but instead have a function key (lower left of the keyboard, with some abbreviation of the word "function" on a key in a different color than the writing on the rest of the keys). Once you find the function key, look at the writing on the other keys that is the same color as the writing on the function key. One of those "other color" labels will be for print screen, and to use it, you hold down the function key at the same time as you push whatever key says print screen in the other color.
Jun 10, 2011 | Lenovo IdeaPad Y550 (41865GU) PC Notebook
Black ink seems to be clogged even after putting in a new cartridge.
Try thi:
Cleaning the Print Head
  1. Press the Ink, Ink/Reports, Ink Management/Reports or Ink Management key.
  2. Use the up or down navigation key to select CLEANING.
  3. Press Menu/Set to confirm your choice.
  4. Use the up or down navigation key to select the color that is not printing
    -OR-
    Select ALL if more than one color is not printing.
  5. Press Menu/Set to confirm you choice.
  6. The machine should begin cleaning automatically, and the LCD will alternately show "CLEANING" and "PLEASE WAIT". When the machine completes its cleaning cycle, the LCD will display the date and time.
  7. Test by printing the "Print Quality Check Sheet":
    2. Use the up or down navigation key to select TEST PRINT.
    4. Use the up or down navigation key to select PRINT QUALITY.
    5. Press Menu/Set to confirm your choice. Press the Color(Colour) Start key to print the Test Sheet.
If one or more of the ink colors is still missing from the printed page, repeat the print head cleaning steps listed above up to 4 more times. After each cleaning, print the Print Quality Check Sheet to see if there is any improvement.
Jan 17, 2011 | Brother MFC-5840CN All-In-One InkJet...
How to print screen in notebook compaq evo n610c?
press the key "Print Screen" "PrnScr" or whatsoever sounds equivalent. If this key is printed outside of the key in color orange, you need to hold down FN key while pressing the "PrnScr" key
Oct 06, 2009 | Compaq Evo N610C Notebook
I can't find the "FN" key on my wireless logitech S 510 keyboard
buy another keyboard which have FN key... theres a kind of keyboard that are not using FN key...
Jun 16, 2009 | Logitech S 510 (967555) (DH967555)...
Unable to print BLACK
The machine should begin cleaning automatically, and the LCD will alternately show "CLEANING" and "PLEASE WAIT". When the machine completes its cleaning cycle, the LCD will display the date and time. Print the Print Quality Check Sheet and see if all colors are present:
    1. Press the Ink Management key.
    3. Press Set to confirm your choice.
    5. Press Set to confirm your choice. Press the Color(Colour) Start key to print the Test Sheet.
If one or more of the colors is still missing from the printed page, cleaning the print head may resolve this problem. When cleaning the print head, you are given the option to clean BLACK ONLY, three colors at a time (CYAN, YELLOW, and MAGENTA), or all four colors at once. For this issue we recommend cleaning only the affected color. If more than one color is missing then select ALL. Follow the steps listed below to clean the print head:
    -OR-
  5. Press Set to confirm you choice.
I hope it helps!!!
Dec 09, 2008 | Brother DCP 115C All-In-One InkJet Printer
Print in light
1. Check TONER SAVE setting. If this setting is programmed "ON", all
printed documents will be light.
a. Press MENU/SET, 1 (General Setup), then 6 (Toner Save).
b. Press the top or bottom navigation key (keys located above and below
the MENU/SET key) until the display reads "Toner Save: OFF".
c. Press MENU/SET.
d. Press STOP/EXIT.
2. Check the PRINT DENSITY setting. This setting allows you to adjust
the print density from light to dark.
a. Press MENU/SET, 2 (Fax), 1 (Setup Receive), then 6 (Print Density).
b. Press the up navigation key (key above MENU/SET) to make print
darkeror the down navigation key (key below MENU/SET) to make print
lighter.
c. Press MENU/SET.
d. Press STOP/EXIT.
Oct 15, 2008 | Brother IntelliFAX 2800 Laser Fax
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
