Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Bobbin case I can't express to you the level of frustration I feel with this machine. I have had it for three years and it is a piece of cr.ap! My biggest problem is that the bobbin case will NOT stay seated. It continues to pop out, often so violently that it throws the timing of the machine off and I have to have it services. Singer has not offered any solution as to why this keeps happening. Maybe someone else has a suggestion?
Hi Anjulie
Singer has come up with another clip on the bobbin case- you will have to take your machine to a dealer for that.  They also have a boobin cover with two depressions on it to keep the bobbin better in place - ask your dealer for it.
Posted on Apr 17, 2008
I managed to pull apart the bobbin case. I found the spring, but can't figure out where it goes. I know I need it for tension on the piece that I have to pull forward to get the case in place.
Would suggest simply purchasing a new bobbin case. Trying to reinstall a spring that is probably distorted will cost you more in time and frustration than the price of a new one. Plus the new bobbin case will have the tension preset from the factory. Pop it in your machine and sew...
Nov 13, 2017 | Sewing Machines
Complete bobbin case to fix it ?
Hai, First you should learn and try to your old machine how to operate the machine? After you started to operate a new machine. Then first you check the timing and change the bobbin case and needle.
Mar 24, 2014 | Brother LX3125 Sewing Machine
The black plastic piece the bobbin fit in is broken.
You may have a timing problem or bent needle. You will need to replace the bobbin basket if it is damaged.
Jan 28, 2014 | Singer 7466 Mechanical Sewing Machine
Is the Bobbin the right size for the machine? That may keep the bobbin case from latching properly, causing this phenomenon. Shuttle latched in properly? Machine cleaned and oiled per the manual? Make sure bobbin is wound straight and correctly... Post with results or follow up questions
Dec 30, 2013 | White Sewing 2037 Mechanical Sewing...
I have a problem in setting the tension of the machine. The upper thread is too tight although I adjust it to 1 or even 0. I try to clean the bobbin area and re-thread. Occasionally it works. Very...
Yes it can be frustrating, I believe that you have a tension prolem with the bobbin case.
The upper tensions should be 3 to 5 normally on your machine.
When you pull the bobbin thread do you feel any resistance? If not then you may need to check that you are threading the bobbin into the case correctly, re test
if that doesn't work then look for a little screw, turn it clock wise to create some light tension on the bobbin thread. Re test
If that fails take to local tech for repairs.
Best of luck chris
Feb 11, 2011 | Brother XL-3510 Mechanical Sewing Machine
My daughter tried to remove a jammed bobbin on my singer machine. The bobbin holding mechanism fell apart. Is there a diagram to show how the parts fit together?
looking straight on at the area where assembly goes, First clean and oil area, the jam was likely caused by accumulated dust or a small piece of thread . You should have three pieces, four including the bobbin itself. first piece to be replaced has a center post this piece goes into the machine by fitting it to the bobbin area, it will only go in one way so when it fits into place you will know. the next piece is a ring this piece has a small piece of metal attached to the top when looking at it correctly the two screws will be on top and there should be two indentions. first one is at 3 oclock and the other is at 9 oclock fit this piece into machine and there should be a lever on either side that turns around and rests in to indentions. replace your bobbin in the bobbin case ,be sure to thread the case correctly and load into newly assembled bobbin area making sure that it clicks into pplace
Nov 06, 2010 | Singer 1120 Mechanical Sewing Machine
Tension Problem on Pfaff 2034, bobbin loops
Rule of thumb.. Loops on the bottom, problem on the top. Loops on the top, problems on the bottom.
Set your upper tension at 4, and rethread the machine from the top. Just before you thread the needle, but the presser foot down. If the thread pulls right thru easily, then the thread is not thru the tension wheel right. Because, if you can't pull the thread thru with the presser foot down, you have it threaded right.
Apr 24, 2009 | PfaFF Tiptronic 2030
Two Stitch Hang-up
youch!  how frustrating.  It sounds like there is a piece of thread caught in or around the bobbin casing.  take the whole casing out and clean with your brush.
I feel your pain, hope this helps.  If not, please come back and we'll try some other things.
Jan 18, 2009 | Brother XL-5130 Mechanical Sewing Machine
Thread keeps wrapping around bobbin
frustrating huh?  it happens!  even to us that have been sewing for 50+ years, but the solution is very simple.  Top thread tension is the culprit.  pull the spool all the way off and rethread the top, follow the threading path precisely and make sure the thread goes down into the tension discs.
one more thing - when that happens often times the piece has to be removed from the machine by cutting those annoying loops on the bottom.  if this is the case, make sure you have removed all the thread clippings from in and around the bobbin case.  sometimes one little piece of thread will make you want to use swear words.
good luck and happy stitching.
Jan 17, 2009 | Husqvarna Viking 1
Bobbin case is moving out of place
I was having the same problem with my machine and finally the spring broke. I couldn't find any parts for this so my husband made me a new spring out of a coke can! LOL!! Anyway, he messed with it for a while and it kept doing it. He figured out that it was not the spring but the other piece under the spring was not pushed up far enough to keep the bobbin case in place so he took a screw driver and pushed it forward toward the bobbin case and now my bobbin case does not move!! And the machine is sewing perfect! At least for now. Anyway, it's not the spring or the thread adjusting screw!
Jun 06, 2008 | Brother CS6000i Computerized Sewing...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
140 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
