Question about Kenmore 3.8 cu. ft. HE4t Front Load Washer
HE2plus Front Loading Washer
We keep getting an sd indicator. We can't find what that means in the manual - What is it and what do we do to fix it?
  • 5,911 Answers
If this is an HE2 Plus washer "Sd" is a Suds lock error, which is an indication of an overload of detergent during the wash cycle. If you are not using HE detergent it is strongly recommended that you do. HE detergent is specially formulated for washing machines that only use about 5-7 gallons of water per wash load (like yours). If you use regular detergent you are, in affect, putting a concentration of detergent in your washer that is formulated for wash tubs that have a 35 gallon capacity. This creates excessive suds which creates air in the drain pump and lines, causing the "Sd" error to occur.
To clear the error, you need to run a RINSE/SPIN cycle, then run a Normal wash cycle with no detergent added. This should clear the problem. You may have to run the cycle a couple of times.
If the problem does not clear:
1. You need to check the drain hose to ensure it is not clogged or kinked.
2. Unplug the washer and check the wiring harness connections to the drain pump, pressure switch and Central Control Unit (CCU).
3. Check and/or clean the drain pump of any foreign objects.
4. Plug washer back in and run a diagnostics test.
To enter diagnostics mode (Washer must be empty and the control must be OFF):
1. Close door.
2. Push POWER
3. Select RINSE/DRAIN & SPIN cycle
4. Push 2nd RINSE 4 times within 5 seconds.
5. Push 2nd RINSE again to advance to the next step of the test procedure.
6. Press STOP to end diagnostics.
If any fault is detected it will be displayed in the Estimated Time Remaining window.
NOTE: Most manufacturer now have a disclaimer explaining the proper use of detergents and the proper upkeep and care of the washer. The warranty can be null and void if it is discovered that you use the wrong detergent, or misuse the appliance. I'm not indicating you are doing so, just wanted to make you aware.
I hope this helps you. Please post back if you need further assistance.
Posted on Apr 12, 2008
My samsung galaxy 2 tablet system ui keeps on stop working how do i fix it
If you mean it shuts down then the battery is most likely failing, if you mean the programs stop running then try doing a memory dump, get rid of all the old data files you can. Transferring as much data to a SD memory card helps as well
Jan 24, 2017 | Samsung Tablets & eReaders
While in the middle of wash load, an error light appears. Sd, what does this mean? kenmore top load washer model 8567165
A code of "SD" indicates the washer has entered its "Suds Routine." That happens when an excessive amount of suds is detected in your washer, and the machine changes operation to remove the suds for proper rinsing of your load. The code will clear itself once the "Suds Routine" has finished.
If it keeps doing this each load, try lightening up on the detergent.
Oct 08, 2013 | Kenmore Oasis HE 27082 Top Load Washer
We are seeing F24 for the first time today on our Kenmore HE2plus front loading washer. What does it mean? How do I solve it?
Hi
F24 is a water temperature sensor error. You have to unplug the washer and check the water temperature sensor and its connections, if that is fine then check the resistance of the heating element and the part that is bad should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 08, 2011 | Kenmore HE2 Plus Front Load Washer
My Kenmore HE2Plus Model 110.47532602 shows F28. Won't power off, door locked and add a garment light on. NOt sure if diagnostcs completes itself-CLEAN WASHER is result. Per manual, check acutators for...
it is for a serial communication error. usually means you have a problem with one or more of the control boards in the washer. hopefully your under and extended wtty with sears. after you get your problem fixed get a surge protector for your washer. its operated by several boards that act like a computer and noone in their rite mind would use a computer with out a surge protector.
Feb 19, 2011 | Kenmore HE2 Plus Front Load Washer
What is 5d or sd? how do i fix it? i dont have a manual
"sd" means that the unit has a sudsing issue, usually. Sometimes a slightly plugged hose to the pressure switch can cause the same fault code. Let it sit to allow any suds to break down and try to drain it out with no tub movement, like in a spin cycle to keep it from sudsing up again. You can add several cups of vinegar as well to help get rid of the suds.
Dec 28, 2010 | Whirlpool Washing Machines
Does not work with 8mb memory card. Why not please? Canon A540. Problem occurs when change a 2mb card for a 8mb card. Have not tried anything to fix problem
The A540 is designed to work with SD cards. Your 8GB card (I assume you really mean gig, not meg) is actually an SDHC card (SDHC stands for Secure Digital High Capacity). While SDHC cards will fit into SD slots, they will not work in SD devices. You need to keep using SD cards, 2GB and smaller.
Aug 23, 2010 | Canon PowerShot A540 Digital Camera
Error codes
Kenmre HE2 Plus front loader has a F 28 error. Whats the problem and how do I fix it?
Jan 19, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore front load washer (HE2Plus)
check to see if you still have a warranty on the washer other than that check the inner door seal if worn or crimped try to fix or replace it
Dec 16, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore (HE2PLUS) front-loading washer leaking out the front door,,,,,,,,C. Pellecer
check the inner door seal it may be damaged that may be why it is leaking
Kenmore 3.8 cu. ft. HE4t Front Load Washer Logo
483 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
