Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Convergence PROBLEM pHILLIPS mAGNAVOX 60" rEAR pROJECTION
Our 60" Phillips Magnavox Rear Projection TV model # 60pp9202 is currently at the repair shop for a convergence issue. The repair technician has replaced the normal IC's and chips that are required to fix this problem. The service convergence is now OK, but the manual convergence will still not align and the screen is still sloped. Any solutions??? The repair technician is about to give up!
Comment by Kimmy100, posted on Apr 11, 2008 Our repair tech. said he did this and did not correct the problem. Any other suggestions?
  • Kimmy100 Apr 17, 2008
    The Repair technician that is working on our TV has tried all of the solutions that I have received, but so far has not had any luck. I need some more ideas.
  • Anonymous Mar 20, 2014
    where are they located inside the back.
    Genius:
  • 1,142 Answers
After studying the service manual, schematics and parts lists, I have found that there are actually 12 6.8 ohm resistors in the convergence circuit. The parts list shows them all as the same, but on the board I found two that looked different. I ended up replacing them all with the 6.8ohm 1w as per the parts list and the TV has been working great. I know most of the master techs here say only 1 or 2 go bad, but if you have the board out why not replace them all?
replaced the 6 ret resistors (3155, 3156, 3157, 3158, 3159 and 3160 all RMO 1W 6R8 J) tv will work great.
http://www.partstore.com where u can bring the IC's
www.tigerdirectpartsearch.com where u can bring the resistors
Posted on Apr 17, 2008
  • 4,234 Answers
There is a particular convergence procedure that must be followed in order. If the sequence is not followed, the convergence will not occur. Please list the parts that were replaced. As stated in an earlier post, there are 2 pico fuses that need to be checked. There is also a possibility that the feeder voltage resistor has changed value enough to effect this, but that is extremely rare. Update this with the replacement parts and I'll check the service manual for you.
Dan
  • 563 Answers
Hi there
Have you tried www.tuneupadvisor.com yet ?
  • 2,323 Answers
If the TV is at a repair shop, the tech should know where the power goes into the STK ICs. I would also suggest to check the low values resistors for an open condition.
The other solution could be that the installed ICs might be defective, even if they are brand new.
Let me know if you need more assistance.
    Genius:
  • 3,422 Answers
All i can say is that this is very common.May be it is not the convergence circuit in this case. it is the power supply not giving the convergence circuit the power it needs to run. there are several parts that need to be repalced here.
Or may be the convergence amplifiers need to be replaced. They're on the Small Signal Board (the one with the tuner[s] on it) and the part on the amp's (there are two on them, replace both) start with STK and will be followed by some numbers and pssosibly letters, such as STK392-110.
Goodluck,
Please don't forget to rate the solution.
Posted on Apr 12, 2008
I have a Phillips rear projection tv model number 60PP9202/17F.....it 60
What is the problem of your
Phillips rear projection tv model number 60PP9202/17F?
Jan 10, 2012 | Philips 60PP9202 60" Rear Projection...
I have a Phillips rear projection 60 color lamps off focus
You can't adjust this. Your convergence amplifiers are bad and must be replaced. $250-$350 by repair shop.
Jul 08, 2009 | Televison & Video
Problems with convergence
the convergence Ics have failed. You can get the repair kit for your model which has both ICs and the 12 feed resistors plus step by step instructions on how to do the repair. Heres a link to the repair kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
May 29, 2009 | Philips Magnavox 51MP392H Rear Projection...
MAGNAVOX PROJECTION TV- GOOD PICTURE , BUT NO COLOR
you need the ssm panel. You can get a replacement panel for your model at the following link.Which is the correct board for your model it controls color, convergence and etc.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-ptv900-series-ssm/cName/sale-items
Apr 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
Phillips Magnavox Proj. TV only makes cyclic chirping sound
Most common reason is shorted convergence chips. Goto the site www.TvRepairKits.com and get their "chirping set" repair kit.
Feb 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
Phillips Magnavox 9P6031C103
You can try ebay, they may have them for auction. or you can try the vendor (philips).
I hope this helps
Shuttle83
Jul 07, 2008 | Philips Magnavox 9P6034C 60" Rear...
PHILLIPS MAGNAVOX 60 BIG SCREEN 9P6040C101
no this is what you need...
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
or send it in for repair here
Feb 06, 2008 | Philips Magnavox 9P6034C 60" Rear...
60 inch phillips magnavox projection tv
CRT coolant change and advanced convergence - how to
I documented the procedure I did on a Philips 55" rear projection 55p916
http://tinyurl.com/lmp6eu
CRT coolant change procedure
http://tinyurl.com/l7bd7r
basic and advanced convergence
Dec 24, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
