Question about Philips GoGear HDD075/17 MP3 Player
Player not reading music.
When I load up mp3 and go into Genres or any music section none of the music i have synced onto it shows. I have tried formatting it and updating it nothing has helped. Please Help me!!
  • 0369 Apr 13, 2008
    Thanks, I have already sorted the problem but Thanks anyway.
    Music Match Jukebox and Philips DMM both could not detect the Mp3 player.
    I used a program called SPA-PhilipsHDD060 which searches for the Mp3 player but is not very fast when it comes to putting on music. I lost the link but you might want to recommend that program to some other people with problems.
    Yeah all sweet Cya
Yeah thats all great but i have windows vista.
so now what?
Posted on Jul 04, 2008
  • 476 Answers
This problem is usually due to using Windows Explorer or My Computer to transfer files. Although you can use the player as a removable drive, it will not recognise any music tracks transfered in this way. The HDD060 & 070 series have a database of tracks which is read by the player on startup. The player does not scan the drive.
To transfer tracks you need to use the Musicmatch Jukebox software on the product CD. Musicmatch updates the database when transfering music tracks.
This software is not compatible with Windows Vista, or Windows Media Player 11. If you have Media Player 11 you will need to uninstall version 11 to roll back to version 10.
If you are already using Jukebox, the problem may be the way the software is recognising the player. The HDD060 & 070 series show up both as "Removable Drive n:" (Where n can be any drive letter) and "GoGear".
If Musicmatch Jukebox is recognising the player as "Removable Drive n:" then go into the Musicmatch Options, and look for the Devices option or tab. Click the drop down menu next to the "Removable Drive n:" entry and select "GoGear".
The tracks you have already tried to transfer are actually on the player, so you will need to run the Philips Device Manager form the product CD and Restore the player, to free up this space.
Posted on Apr 12, 2008
Windows media wont sync music
Make sure you are not using Windows Media Player 11 - it will work for a while, but eventually will start displaying the symptoms you are describing - you can read the warning on Philips website.
Make sure the hold/lock is not engaged
Try another USB port
Reset the player
If that fails:
Download the newest version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Repair" tab
If still nothing:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
If these methods fail, call Philips to see if you are still in-warranty.
-Tha Mp3 Doctor
Mar 18, 2009 | Philips GoGear HDD6330 MP3 Player
LOADING MUSIC ONTO LG VU
in preferences, more options, there's a connection section. try setting it to music sync
Jan 27, 2009 | LG Vu CU920 Cellular Phone
Syncing with Windows Media Player
Place the music files that you want to transfer into the My Music folder of your computer - Windows will re-read them, and then you can synchronize to your device. Also, make sure the hold/lock switch is not engaged on the mp3 player - it probably isn't, but just check.
-Tha Mp3 Doctor
Dec 25, 2008 | GPX MW-238B MP3 Player
Can't sync music onto MP3
Hi Jollie17,
Try downloading the free version of real player and use this to sync your music files. It helped me. Take care.
Jun 29, 2008 | iLO (2 GB) MP3 Player
MP3 Player wont let me listen to music it says it has on it
If you already formatted the player itself, the songs itself may be in the wrong format. This player doesn't read iTunes files, for instance - it will look like they have transferrred, but you will not be able to play them.
May 26, 2008 | SanDisk Sansa m230 MP3 Player
Music & memory loss
so i guess ur done with it..
May 01, 2008 | Sony NWZ-B103FBLK MP3 Player
Downloading music trouble
After you've downloaded the music files you want from Lime wire put them in your music folder on your computer ,then you need to sync your MP3 player through windows media player. plug in your mp3 player then open windows media player, on the top right there is tab says sync. click on refresh devices and your mp3 player should show up on the right window pane in windows media player. From there you can drag all your music onto it and press sync!
Hope this works
Dan
Feb 22, 2008 | iLO MP3 Player
Music not showing up even when downloaded
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Dec 25, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e280- files added via WMP10 or Windows explorer, but don't show up on player
No limit on the Genres.
If you keep adding music in different modes, Windows Media Player and Windows Explorer will not show the correct free space.
Theres a good chance you have too music music on your device and the device does not have enough free space to create the Database, or the songs, artists, album, etc.
Try deleting a few songs from the device with Windows Explorer and disconnect the player and let it restart.
If that doesnt work, you can FORMAT the device to remove all of the music and start over.
To format in My Computer>Device name (e280)>Right Click and select FORMAT.
Best of Luck.
Nov 14, 2007 | SanDisk Sansa e270 MP3 Player
Sync notice...?
If your using XP, go to the Windows Media Player and load the CD. You will see a Sync Icon. When you click on it will run and then give you a sync complete. Plug in your Sansa to the usb port and load from the Windows Media Player. Myles5@optonline.net
Jun 02, 2007 | SanDisk Sansa m230 MP3 Player
Philips GoGear HDD075/17 MP3 Player Logo
125 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
