Question about Dishwashers
Plugging the GE quiet power 3 dishwasher return line
Help, my sink is clogged, when i try to plunge it the dishwasher stops me from getting an air tight seal, so it won't plunge. How and where do I plug the dishwasher return line?
    Genius:
  • 1,073 Answers
Remove the drain line and plug off the port on the sink that the dishwasher connected to, to plugit off black electrial tape wrapped arround the hole till it seals off will work
Posted on Apr 12, 2008
GE quiet power 3
First, check the basket that collects junk at the bottom. Another likely problem is a clogged line to the drain that usually plugs into the garbage disposer. You may try to disconnect that hose and plumb it with a coathanger or the like or hook it up to a shopvac to break the clog free.
Apr 25, 2014 | GE Dishwashers
My dishwasher isn't draining. The garbage disposal is hooked up separately.
Is sink drain line clogged?
Disconnect drain line at sink tailpiece and lower down to see if water inside dishwasher drains.
Call serviceman to clear clog in dishwasher hose, or repair dishwasher pump motor.
Oct 13, 2012 | Whirlpool Gold Dishwasher with Quiet...
Water coming into sink from dihwasher air line
there is a drain line that attaches to the sink. if water coming up in sink then sink drain is probably clogged.
Sep 08, 2012 | GE Dishwashers
What would cause my dishwasher not to drain?
not sure if you have posted the model number of your dishwasher.
There are several reasons for dishwasher not to drain.
1. faulty drain pump
2. clogged kitchen sink drain
3. drain cycle is not reached due to faulty dishwasher controller
4. clogged drain hose
5. the wash cycle is not completed due to heater not heating water - (try rinse cycle to confirm)
Happy to help if you can provide some details on when the drain cycle is not working. do you get any alarms on dishwasher..etc.
Feb 25, 2011 | GE Nautilus 24" Built-in Dishwasher
Portable Dishwasher wont drain GE Model #GSC3508K00WW
There's a few things you can look into that won't cost you any money.
First, manually remove as much water as possible and then check the sump area for paper or any other large object clogging the drain. A cup or so of water in the sump area of your dishwasher is normal and it is there to prevent the seals from drying out. The dishwasher will pump this old water out before beginning to wash.
Make sure the door is properly latched as the pump will not drain if the door is not latched properly.
Check the belt, drain line, air gap, drain valve and solenoid assembly, the motor, and the pump. If your dishwasher uses a belt to drive the pump, and it has broken or come off the pulley, replace it.
If you have recently installed a garbage disposer in your home, make sure that the drain plug on the disposer has been removed. It's just a little plastic piece that blocks the hole where you hook the dishwasher drain hose. If your dishwasher drains through the garbage disposer, you need to run the garbage disposer before you run the dishwasher to make sure that the drain is clear.
There is a drain hose between the drain valve or pump and the garbage disposal or drain line. If an obstruction has blocked this, then your dishwasher won't drain. The drain hose is connected by clamps to the drain valve and the disposer or drain pipe. Remove it and visually inspect it for a clog or a kink. Try to remove any debris. If it is in good condition, just put it back on, and if not, purchase a new one to install.
If you don't have an air gap in the drain line, at least use a high drain loop. Making a large loop about 18" off the ground with the drain line can prevent any back flow into the dishwasher from the sink.
If you have one, the air gap will be located on top of the sink. The air gap is there to prevent any siphoning of standing water from the sink. When your dishwasher drains, the air gap diaphragm will form a seal and allow the water to drain properly. If the diaphragm in the air gap is faulty, it’s possible that water can leak onto the cabinet and into the sink area. When this happens, then the air gap must be replaced.
Like the inlet valve, there is also a drain valve on most models. When no power goes to the drain valve it remains closed and prevents water from leaving the machine. When the valve receives power during the drain cycle, the solenoid opens and allows the water to leave the machine. If your drain hose is attached directly to the pump, you don't have a drain valve. The motor simply reverses and the pump sends the water in the opposite direction, which is out of the machine.
If the motor doesn’t turn or work properly, the dishwasher may not drain. Make sure you have power to the unit. If you notice that the motor hums but won't turn, it could be seized, and you probably need to replace it.
if you need to buy any parts, I have had alot of help from http://www.apwagner.com
Small objects can sometimes get stuck in the pump. When this occurs, you’ll need to open the pump and remove any debris buildup. The dishwasher pump is usually mounted directly to the motor and runs off the motor as well. The pump is also attached to the bottom of your dishwasher and pushes the water from the dishwasher.There's a few things you can look into that won't cost you any money.
Oct 26, 2009 | GE 24-7/8" Convertible Portable Dishwasher...
My GE. quiet quiet power plus won't drain
This is normally a pump issue. check the following to combat this further..
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Jun 11, 2009 | GE Dishwashers
Water standing at end of cycle
You probably have a clogged return line to the sink/drain.
If water gushes out from under the overflow cover (next to sink faucet) with the screw cap in place then you have a plug between the overflow and the garbage disposal or drain.
If water isn't gushing from under the cover remove the cover and the screw cap. Look for something plugging the small diameter tube. (Note: If you run the DW with the screw cap off you could have a small gyser.)
If there are no visible plugs in the end of the tube then:
Remove the front cover from under the dishwasher and locate the drain hose. Remove the hose connection from the diswasher (black hose connects to DW discharge hose or housing). Try to blow through the hose, air should easily escape. If it doesn't you have a plug somewhere in the line to the drain.
If the hose is short you can try to clear the clog with a coat hanger, the easiest fix though is to just replace the hose.
1. Find replacement hose
2. cut the hose with a razorblade to leave a 3/8" strip about 4" long.
3. do the same for the replacement hose.
4. using wire sew the two strips together by punching holes in them.
5. wrap the splice in tape and some of the cut hose to make the splice the same size as the original hose.
6. Push the hose under the DW and pull from the drain side to get the new hose in place.
7. Cut-off the splice and attach the new hose to the overflow.
PS> Most of the time the clog in the hose is caked DW detergent and is hard to remove without pulling the hose out.
Hope this helps,
Kal
May 18, 2009 | GE Dishwashers
I have had no problems with my GE dishwasher for the last 3 years. All of a sudden, when its draining, the water is coming up through the extra knob on the sink. I am not sure what it is called, but it...
The drain line between the air gap (thingie next to the sprayer) and the sewer drain piping. If the sink drains fine, the clog is between the air gap and the point at which it connects to the piping under the sink.
Please take the time to give this solution a fix ya rating.
clarkco
Mar 07, 2009 | GE 24 in. GSD4060JSS Built-in Dishwasher
Water still in the bottom of the dishwasher
If there is no air gap (silver cap) located on your sink next to your faucet, you could have a clog in the drain line or at the drain port at the motor/pump assembly. Also, check to see if the drain hose (under sink) has a loop in it before it goes to the disposal or pipe. If there is no loop, water could be backing up into the tub.
Sep 28, 2007 | GE GSD5320DBB Dishwasher
Dishwashers Logo
196 people viewed this question
Top Dishwashers Experts
