Question about Brother HL-2040 Laser Printer
Brother 2040 printing watermark
No matter what software I send a print job from, the Brother is printing along the right hand side vertically, a watermark like diamond-shaped envelopes. It covers the print. I've checked Word and printer settings, can't find anything that seems to fix it! Help please!
  • 62 Answers
Does the printer do it from beginning? or after cartridge change?
Posted on Apr 25, 2008
My HL2040 printer is printing black vertical lines along the right-hand side of the page, about 3" or so. A month ago I took it apart and cleaned the roller. Still doing it.
If the lines go all the way down the page, check the position of the corona wire cleaner tab (blue or green) at the top front of the drum unit. if not parked fully to one side it will create a solid black lines where it blocks the laser. Otherwise look for some other foreign object (or torn paper piece) that may be blocking the laser from the drum. If the lines are thin and shark, check for scratches on the drum (not repairable without replacing drum). If the lines are uneven thickness but in a pattern that repeats down the page every few inches, then the film on the drum is probably worn or wearing away and the drum needs to be replaced.
Mar 04, 2015 | Brother HL-2040 Laser Printer
Vertical black lines on right side of page
Remove the printer cartridge and check for any obstructions. Then replace the printer cartridge and attempt to print again. Make sure the cartridge is fitting firmly. Check the printer menu for a cartridge cleaning option. Print a test page by right clicking the printer, selecting Printer Properties and Print Test Page.
You may need to replace the cartridge.
Mar 02, 2011 | Brother HL-2040 Laser Printer
My Brother hl-2040 is just running paper through, even after power cycles, and won't stop. How can I purge its memory to be able to start printing an acutal document again?
disconect the usb from the printer, then power cycle.
cancel all jobs on the computer. reconnect the usb, if you send a job and the problem starts again i'd try a new cable
Mar 23, 2010 | Brother HL-2040 Laser Printer
Brother HL2040 PRINTING DOTS
1- change the drum unit
2- check the fuser unit
Sep 06, 2008 | Brother HL-2040 Laser Printer
Lines on papre
Replace the toner cartridge.
There is probably a flaw in the image drum. Replacing the toner will replace the image drum (they are one piece)
Aug 19, 2008 | Brother HL-2040 Laser Printer
System restarts after printing a job
How are you sending the "Print" order ?
Try Control + P then hit enter
May 28, 2008 | Brother HL-2040 Laser Printer
Brother hl-2040 printing problem
Could be that there are a mark on the drum itself or some dirt, remove the drum unit and inspect the surface , by rotating the drum , becareful not to touch the drum as it will leave marks on the surface
Apr 25, 2008 | Brother HL-2040 Laser Printer
Cancel already sent job
turn off the printer, and disconnect from computer..turn it back on, and clear all jobs from front panel controls
Mar 20, 2008 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
107 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
