Question about Lexmark X5150 All-In-One InkJet Printer
Need to find a power cord
Don't know how to get a power cord for my printer x5150
  • Llexy22 Nov 26, 2008
    I have the same problem, Lexmark no longer carries power cords for this model. I have searched all over the internet but have been unable to find the power cord. Any help would be greatly appreciated.
    Genius:
  • 3,587 Answers
Accessories from www.lexmark.com or a variety of online locations.
Posted on May 04, 2008
It will not print onto the paer
I don't know about Lexmark, but I know that with my own printer, the instructions say that if you are getting blank print-outs, try taking out each toner, give it a little tap/shake, then put in back in.
Apr 28, 2012 | Lexmark X5150 All-In-One InkJet Printer
There is no green light on my printer
If you are encountering power problems with your printer, please go through the following checklist:
  • Make sure the power cord is plugged in securely and directly to the power outlet. Power surge protectors can draw power away from the printer.
  • Disconnect the power cord from the power outlet and the back of the printer and then reconnect it.
  • Check the power supply box (if there is one) to see if it is warm or cold, as there could be a defective power supply issue.
  • If there is access to a voltmeter, test the power supply to ensure that it registering the correct amount of voltage (most Lexmark printers have a 30Volt output).
  • Make sure the correct power supply is connected to the printer.
Nov 19, 2011 | Lexmark X5150 All-In-One InkJet Printer
THE POWER CABLE GET VERY HOT AND THE ON/OFF LIGHT BLINKING
Unplug then replug the power adapter of the printer. The power adapter is the rectangular black box behind the printer where the power cord is attached. Make sure to plug printer to a power outlet with the correct power specification. Bypass surge devices or power strips. If problem continues, unplug printer from the power source and contact Lexmark technical support to further investigate the problem. Thanks.
Sep 15, 2010 | Lexmark X5150 All-In-One InkJet Printer
My lexmark x5150 won't turn on. could it be the power cord? It ma
Please follow the instructions given below to troubleshoot the power issue:
1. Connect the printer directly to the power outlet. Surge protectors can actually draw power away from the printer. If this fails, please try multiple power outlets to ensure your specific outlet is not damaged, and make sure the printer is not connected to the PC while testing the unit.
2. When trying to power on the printer, feel the power supply box (if there is one) and note whether or not it is warm. If it is warm, the problem is not in your power supply, but most likely in your printer. If it is cold, the power supply might be defective.
3. Ensure you have the correct power supply connected to the printer.
4. If you have access to a voltmeter, please ensure that the power supply is giving out the correct amount of voltage (most of our printers use 30 volts output).
Apr 13, 2009 | Lexmark X5150 All-In-One InkJet Printer
Hardware error : 0502
  1. Switch off the printer using the power button.
  2. Disconnect the power cable from the back of the Lexmark X5150.
  3. Leave the power cable disconnected for 30 seconds.
  4. Reconnect the power cable and switch the printer on again.
  5. When the printer powers up, you will need to select the desired settings.
Jan 29, 2009 | Lexmark X5150 All-In-One InkJet Printer
File?
you connect it through a USB cord.... at least thats how I hooked up mine..
but what I would do if i were you is remove the printer drivers... uninstall lexmark... then go to www.lexmark.com then click the tab that has to do with driver downloads.. then click "drivers"... then type x5150 in the model .. then select the appropriate version of windows that you have, and run the file.. that's what i had to do to fix mine
Jan 03, 2009 | Lexmark X5150 All-In-One InkJet Printer
No display on screen
I lost de word in the screen, i cant program de printer,
Apr 27, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark x5150 color printing issues
Sometimes ,poor print quality may be due to ink build up in the maintenance station ..
Your ink cartridges stay in the maintenance station when not in use. Depending on the printer model, the maintenance station may be located on the right or left side of the printer. NOTE: You do not need to remove the cover in order to access the maintenance station.
To access the wiper for cleaning purposes:
Unplug the power cord from the back of the printer.
Move the ink cartridge carrier to the left by gripping the top of the rubber carrier belt and gently pulling it across towards the right-hand side of the printer.
Take a warm, damp paper towel or napkin and gently clean the wiper on the right-hand side of the maintenance station.
Mar 03, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
