Question about Toshiba Satellite A75-S231 Notebook
Unexpected shut down
I had my laptop for about 3yrs now. never had a problem till a few months ago when it started unexpectenly shutting down on me w/o any warning. i tried to download updates but its not allowing me to do that either. i read your most common problems with toshiba and i'm taking a look at it. i'm also looking into download its backup software, i lost its cd for it. any direction on how to get this software? your help its greatly appreciated. thanks
jose
  • 77 Answers
First, you need to find out what is causing the shutdown problem.
Most likely since you have this laptop for 3years now and (i am assuming you havent had this serviced). You might be suffering from overheat problems since you are using a DESKTOP P4 cpu.
Try to dismantle your laptop and remove the Fan and Heat sink. CLEAN them and put new thermal paste to the cpu.
Do that and see if this fixes the problem. If not, let me know again
If i was able to help please rate this solution as a fixya!
thanks
Posted on Apr 11, 2008
(suffering from overheat problems)
Thanks, I have been facing the same unexpected shutdown, due to over heating and I tried dismantling my laptop, but I am not able to dismantle it completely to reach the fan and heat sink to clean it, cud you pls guide me how to? or if you can assist me with the satellite A75-S231 assembly design. Where do I find this thermal paste and how and where to apply it.
Pls help, I like this laptop a lot and I do not wish to sell it that too for a price equivalent to peanuts which I was offered(some of the service guys not being able to find ou the problem advised me to sell it saying it was too old not worth using)
Pls help! pls help!
Thanks
Posted on Oct 29, 2009
My Pryon with Windows 7 occasionally unexpectedly shuts down even though there was no power surge. It reboots alright. What should I do?
I didn't know what a pryon was til I looked it up. Is it a desktop? If so you might have to clean out the inside. Blow out the heat sinks and the power supply( both directions) and any dusty looking areas. If it's a laptop you could try and make sure you aren't covering any of the cooling ports when using it. Like sitting in bed with it on the blankets.
Nov 21, 2014 | Computers & Internet
Samsung Laptop Shuts Down Unexpectedly
It may be overheating. Try using a vacuum cleaner hose on the air vents, that will help to clear the ventilation for the radiator.
Jan 18, 2014 | Samsung Computers & Internet
CHECK THE FANS! The biggest enemy to your laptop is HEAT! You just replaced the display it's very possible you inadvertently disconnected the cooling fan. Clean it while you have it apart dirt and dust prevent proper cooling
Jun 28, 2017 | Samsung Computers & Internet
Lenovo unexpected shut down
I suggest you return it to the supplier for an exchange or repair or refund as it would be still under warranty.
If you try to fix it yourself you will void your warranty.
Mar 07, 2013 | Lenovo IdeaPad U410 437689U Graphite Gray...
Asus u52 shut down unexpectedly
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jun 17, 2012 | ASUS U52F-BBL9 Laptop
Hello, I have a laptop Dell Inspiron 1501. A two days ago I reinstalled Windows Vista, because I've had some problems wih my internet connection and some other. So I installed it and everything is ok,...
Hi!
It is not yet the end for your machine. The error codes refers to a faulty hard drive. You'll need a new hard drive for replacement and that will fix the problem.
Should you have any other questions just leave a message.
All the best!
Musicaddict
Sep 15, 2010 | Computers & Internet
I bought HP Pavilion dv5 6 months ago and fan not working
Your cooling fan sounds to have went out,causing it to overheat and shut down.It also could be something in the fan stopping it from turning.Try cleaning it or blowing it out with it off.But it mostly sounds to have went out.
Aug 05, 2009 | Computers & Internet
Acer Aspire 5000 series that keeps unexpectly shutting
The hard drives ready for failing, back up everything now to avoid loosing data, run chkdsk /f this command will scan the disk for any problems and try to fix any bad sectors, if this doesn't work i'd think about buying a new hard drive
Nov 13, 2008 | Acer Aspire 5000 Notebook
IBM Thnink Pad R52 Shuts Down unexpectedly
it might be the battery, try plugging it in while doing that.
Jul 09, 2008 | IBM ThinkPad R52 Notebook
Shuts down unexpected,
Sounds like an overheating issue, I would suggest using a cooling pad.
325aed8.jpg It's a simple device, you just rest your laptop on it and the fans do the work.
Sometime they overheat when working in a confined space, make sure you have ample room aroung the laptop for ventialtion.
Hope this helps
http://pchelpforanyone.blogspot.com
Mar 07, 2008 | Toshiba Satellite M45-S169 Notebook
Toshiba Satellite A75-S231 Notebook Logo
196 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
