Question about Symphonic WF-719 19 in. TV/VCR/DVD Combo
Symphonic b-19wm I BOUGHT THIS TV NEW AND THE REMOTE WORKED FINE UNTIL I MOVED THE TV INTO A DIFFERENT ROOM. IT IS IN THE REMOTE SENSOR BECAUSE THE SAME REMOTE THAT CAME WITH IT WILL WORK ON ANOTHER TV I HAVE. WHERE IS THE REMOTE SENSORY ON THIS MODEL AND CAN IT BE REPAIRED? THANKS. vandamcintosh@yahoo.com
    Genius:
  • 1,689 Answers
It can be the remote sensor, or the circuitry that works with it. I don't know its exact location for your model, but you can usualy find it, because at its location it looks like a little black or dark red window in front of it.
The sensor and its related circuitry are servicable. To find the exact fault will require using a DVM and an oscilloscope to trace down where the signal is stopping from the sensor. The sensor feeds the main uPC controler via a number of components on the circuit board. An experienced service tech should be able to troubleshoot this for you, and replace the defective parts. On rare occasions the fault can be with the uPC itself.
It is also possible that there is a cold solder connection on the circuit board that is stopping the remote sensor from getting the remote signals to the uPC.
Jerry G.
Posted on Apr 12, 2008
Remote not working as i moved tv into another room
If the remote control you've bought is a universal remote control, you have to set it with your TV, by TVs setup codes. The setup code list will be attached to the new remote controls' packing. If you wish to get more details, check the sites linked here. Set-up code list, and Set-up procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide, can be selected by the drop-down list, by the top left of the display window, will make surf easy
Nov 06, 2013 | Grundig GU22DVDPX 22 in. LCD TV
My remote was working fine until i moved. I have Direct Tv and the remote from Direct Tv works on guide. I bought a new remote from Magnavox but it doesn't work my tv. what should I try? '
You have to program the remote control to synchronize with TV. If you wish to get moredetails; codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 17, 2013 | Televison & Video
I HAVE A SYMPHONIC 19 IN B-19WM AND I DONT HAVE THE ORIG. REMOTE..I HAVE TRIED TO PROGRAM IT WITH RCA RCU704 SERIES UNIVERSIAL REMOTE AS WELL AS A ATLAS OCAP 5 DEVICE UNIVERSAL REMOTE AND NONE OF THE CODES...
Hello
You just buy one Philips Universal Remote control [MODEL NUMBER CL 034]. Symphonic is listed in its codes. Codes are: 0906 0520
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
OK.
Feb 17, 2011 | Symphonic ST419B 19" TV
I have two Samsung HD ready series LCD TVS in two different rooms. Both have their own Samsung remote. TV1 works fine. TV2 works fine BUT when TV@ remote switches TV2 on it also switches TV! off! How can...
Hi, To change one of your TV with another brand is not a wise decision indeed. Well, Your TV has a remote sensor in the front side. Try to places both TV on opposite position. Otherwise use the used batteries on both of your TV remote commander. This will reduce its signal.
Regards
Jan 17, 2011 | Samsung TV Remote Control
I bought a new Sony ex4/40 tv and programmed my DISH Network remote control for it. Everything works fine when the all the lights are on in the room. Can't change the channels or go to the guide function...
Hello, the problem that you are having is fairly simple to solve. The tv is causing interference with the remote. It sounds like you're at TV1, and TV1 remote is an IR remote. You need to get a UHF remote, and that will stop the interference so that you can continue to enjoy your tv! You can e-mail me at becki.barned@dishnetwork.com if you have any questions or concerns.
Becki Barned
DISH Network Customer Service
Nov 03, 2010 | DISH Network IR Remote Control
My verizon fios remote control stop to control the 65" cinema series toshiba tv.the remote seems to be ok.The oryginal tv remote doesnt control it also.I think that there is something wron with the tv...
Yes, most likely the sensor is at fault - more precisely it's connections to the motherboard are iffy. You must take the back cover off the tv and reseat them. While you are there check their soldering points - with age they tend to melt and get loose.
Jul 28, 2010 | Televison & Video
Comcast remote does not work after dark, works just find in day
I have had the same problem I have two bell receivers one in the bedroom and one in the living room, in low light the remote in the living room would work much like yours, but if I took the same remote into the bedroom it worked fine in low light, the second remote responded exactly the same, the problem in my situation was the TV had a light sensor that adjusts the picture depending on the light in the room, with this option turned off. The remote works just fine in low light situation.
Oct 20, 2009 | DISH Network IR Remote Control
Dish IR Remote 20.0 has problems after sunset.
The problem for me was the TV giving off IR signals that interfered with DISH's poorly designed remote. When the TV's room ambient light sensor was turned on and it became dusk outside the DISH remote would stop working. Moving the receiver away from the TV helps but the problem is not eliminated until the light sensor is turned off.
Until DISH corrects this poor design there may be no other viable solution.
Jul 09, 2009 | DISH Network IR Remote Control
Remote not working
this s gizmofreak
the solution to the above problem
this s because of the sensor in the remote control, check the batteries n the remote because battery doesn't works its difficult for the sensors to retrieve power from it.
please do me rating.
Feb 04, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Symphonic WF-719 19 in. TV/VCR/DVD Combo Logo
736 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
