Question about Compaq Evo N600c Notebook
Replace CCFL lamp
Hello, My n600c lcd is dark, i can see an image but the screen does not light. Can you please help with how to change the ccfl lamp and where it is. I have it pulled apart at the moment and the LCD out on bench dont want to go further as i need instructions the screen is a Hitachi SXGA+ 1400 x 1050.
It could also be the inverter, i dont know if there is a simple test for these?
  • Chaddles Apr 12, 2008
    Thanks, Yes it could be the Inverter, I thought that i should have a look at the ccfl lamp to see if it is dark on the ends or if there was an indication before i purchased an inverter.
  • snuttis68 Oct 21, 2008
    Same problem here.
    A very vague image is seen if you look real close, or hold a light sideways to the screen.
    Genius:
  • 1,027 Answers
You may not need to replace the ccfl lamps, usually the problem is the inverter that supplies the voltage to the lamps
Posted on Apr 11, 2008
Dull laptop screen back light
You may have a faulty CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight or a faulty inverter that supplies high voltage to the CCFL lamp. Usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.lcdparts.net
Dec 30, 2009 | Dell Latitude C610 Notebook
My compuetr screen does light up when power is connected it dark
You may have a faulty inverter or defective CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
www.ladparts.net
Dec 14, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
The backlight on my Aspire 4315 has gone out. I am pretty proficient on computers and beleive that I can fix it. The one problem I m having is..Where exactly is the component located and where are the...
www.ladparts.net
The CCFL lamp is located at the bottom of the LCD screen, the lamp is a mini fluro lamp, it is the width of the LCD screen and approx. 1.5 mm dia.
The inverter is located between the screen hinges and below the bottom edge of the LCD screen.
Dec 11, 2009 | Acer Aspire 4315 Notebook
Unite powers up, but screen stays dark. Unite is 11 months old, and used daily.
www.ladparts.net
Dec 08, 2009 | Acer Aspire 5610 Notebook
My ibm a21m turns on with the little light as well but nothing happens the screen is blank the hard drive powers up still nothing need help please
www.ladparts.net
Nov 30, 2009 | IBM ThinkPad A21m 2628 Notebook
The screen of my XPS M 1330 notebook is dark. I can see my screen in the back ground and the computer works fine, I need a flash light to see the screen
You have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
www.ladparts.net
Nov 19, 2009 | Dell XPS M1330 Notebook
Hello dear sir i have an old samsung labtop
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
www.lcdparts.net
Oct 02, 2009 | Computers & Internet
Light bulb bad?????
You may have a faulty inverter or a faulty CCFL lamp.
A defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
Sep 06, 2009 | Gateway HD2200 LCD Monitor
Evo N600C, display is 'dim' and mainly 'red'
There is one CCFL lamp on the bottom edge of the LCD screen.
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Check out
www.lcdparts.net
Sep 04, 2009 | HP Compaq Evo Notebook N600c
Replace CCFL lamp
here's exactly how to do it
Jun 27, 2008 | Computers & Internet
Compaq Evo N600c Notebook Logo
363 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
