Question about Toshiba 61H70 61" Rear Projection Television
Convergence problem Hey guys. My convergence is out of whack just like all of these other postings I've read. I want to try the repair myself. Any links on step by steps to replace the chips and which ones do I need? Oh and any recommendations on where to order them? Thanks.
  • Anonymous Jul 06, 2008
    mi problema es que los colores se miran montados uno sobre otro y los numeros de los canales igual
129 dollars for 2 stk packs what kind of @sshole do you take them 4
Posted on Sep 21, 2008
  • 121 Answers
You need 2-STK392-110 ic's located on board at q751 and q752 hooked to 2 heat sinks you can get them plus free online tec support and complete instructions with pictures at the link i gave you I have found this to be a great place for parts and tec support myself
http://servicemanuals.vstore.ca/
Posted on Apr 12, 2008
I have a Mitsubishi WS-65907 that won't turn on
change here the two stk-392-570 convergence chips and one of the two pico fuses connected to them, if you still need help I have instructions for this repair in this set--start to finish.
Nov 27, 2012 | Mitsubishi WS-65907 65" Rear Projection...
Convergence Problem Please Help!
Problem with Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
i want to learn how to do convergence on my tv its a hitachi rear projection i have problums with colors not aligning,could you lead me in the right direction ps: i don't have the remote so i
can't magic focus
Posted by avatar13.jpgejaparks on Mar 03, 2011
AdChoicesMajor Appliance Repair
www.graysoncollinapplianceandac.comResidential/ Commercial, all brands Friendly, knowledgable technicians!
Get $75 of Advertising
www.Google.com/AdWordsPromote Your Business On Google. Claim Your $75 Coupon Now!
Solutions (1)
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jan 06, 2012 | Hitachi 53UWX10B 53" Rear Projection...
How Do I fix the convergence on my 2001 Hitachi Projection Tv
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos aroundimages.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Jan 05, 2012 | Hitachi 53UWX10B 53" Rear Projection...
My convergence on my Toshiba 57'' is out of whack. Only the Blue is an issue where I am unable to repair through the Convegence setting menu. I love the TV and would like to fix this myself without...
did you try to set the convergence adjustment on the remote control? there is a pattern (crosshatch) which you can adjust the convergence of RGB guns,If it cannot be done on earth as it is an heaven... you must open the back cover and look at the liquid coolant at blue gun, that liquid acts as a coolant at the same time as lens, check the level of liquid, usually it leaks and need a repair kit for replacement,make sure not to drop the coolant on the board that's conductor and corrosive.
Aug 27, 2009 | Toshiba 57H82 57" Rear Projection...
Convergence problem ,Help Please
Something is not right here. Is there any possibility that you can get the circuit designation (Rxxx) of the resistors that were "incorrect"? I am not aware of anything like this that can cause the "memory to be erased". The only memory in that area would be the factory convergence settings which can be modified from the service menu. Please try to supply the resistor IDs and I'll check on this.
Thanks,
Dan
Feb 13, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Zenith R49W36 Rear Projection TV Convergence IC problem
Had the same problem with my Zenith TV. Convergence was all out of whack. I purchased a repair Kit from www.TvRepairKits.com. The kit had all the parts and simple step by step photos of the repair. I cant thank them enough for making this possible . At first the repair did not work so I emailed them and within an hour they told me to check two other items. Sure enough they were right! The set is now working perfectly.
Thanks Guys, I will spread the word.
Louis
Jul 27, 2008 | Zenith R49W36 49" Rear Projection HDTV
Zenith R49w36 problem
Had the same problem with my Zenith TV. Convergence was all out of whack. I purchased a repair Kit from www.TvRepairKits.com The kit had all the parts and simple step by step photos of the repair. At first the repair did not work so I emailed them and within an hour they told me to check two other items. Sure enough they were right! The set is now working perfectly. You guys rock!
Louis
May 27, 2008 | Zenith R49W36 49" Rear Projection HDTV
PROBLEM W/ 61H70 CONVERGENCE
You need to re-solder the circuit board that contains the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall, about dead center in the circuit board. You may be able to recreate the problem by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. This is a caused by a minimum effort (a.k.a. minimum cost) solder job, probably done in some 3rd world sweat shop. The "factory" job was good enough for 3-4 years but the heat (and these modules do create a lot of heat) and stress created from repeated use eventually takes it's toll, weakens the pin connections and our problem occurs. take the appropriate cautions working around the high voltage of the set & use a non-conduting piece of wood to push the heat sink when we doing tests.
Best of luck, hope ya fix it.
Jan 30, 2008 | Toshiba 61H71 61" Rear Projection...
Possible convergence problem
You could replace it yourself. I had it done recently and the local repair shop charge $400 to do it (including cost of the chip).
Jan 30, 2008 | Toshiba TP50H50 50" Rear Projection...
Convergence Problem?
Mike, on this set don't bother with the chip changing as the complete convergence amp. board is only 63 bucks. Check it out here: http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=1201%2D001225&search%5Fmodel=PCL545R Good luck
Apr 26, 2007 | Samsung PCL545R 54" Rear Projection...
Open Questions:
Toshiba 61h70 Picture Problems Hello, I have a Toshiba 61h70 TheaterView HD Projection TV, and was recently having some slight convergence issues (red was out of alignment and could not be adjusted). So I researched and found that the IC?s (STK392-110) needed to be replaced. I initially purchased them on eBay, to later find out that they were cheap clones and did not work (they made the convergence worse, actually). I then purchased 100% Sanyo IC?s from a reputable dealer and replaced the IC?s again. Once finished, I then entered the service menu and adjusted the convergence alignment. Once the alignment was perfect, I hooked back up the TV antenna, the DVD player (composite), and the S-video from my computer. The convergence is fine, but now I?m having a totally different issue ? the video is ?scrolling?. The menus will show up fine, however any incoming video inputs will show up okay for a split-second, but will then flash and the picture starts to scroll in different directions. This happens with any of the video inputs. I checked and changed all the service menu items to factory defaults, however this had no effect. I have pasted a link below to a short video that illustrates the issue that I?m having. Please note that the video starts off with a black screen, showing the ?input? menu, and then I selected the ?TV input? and changed the channels. You will see the picture fine for a moment when the channel is first changed, but then the picture will start to scroll. Any ideas of what would be causing this? And how can I correct the issue? I?m not a TV repair expert, so I?m not even sure where to start. Any help would be greatly appreciated. http://s75.photobucket.com/albums/i303/hybrydmike/?action=view₪t=TV_Troubles.flv
Feb 27, 2017 | Toshiba 61H70 61" Rear Projection...
Toshiba 61H70 61" Rear Projection Television Logo
175 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
