Question about Koss KS3101 System
No power The power light won't come on. The fuse is not blown, though.
  • 1 more comment
  • mommom31 Apr 12, 2008
    It's not the outlet, because the rewinder works in the other outlets I tried.
    There's no power light or response of any type from the machine.
  • mommom31 Apr 16, 2008
    I took it to Radio Shack and they said the fuse was ok, but there's no power. No power light, no response from it; it doesn't work.
    Genius:
  • 3,422 Answers
The only solution to fix this up is to call a tech and get it repaired or get it replaced if it is still under warranty.I believe there is no other home remedy for this.
Goodluck..
Posted on Apr 12, 2008
  • 796 Answers
Are you saying only the power light is not glowing....
is your player working
Will not turn on, no blinking lights, power coming from cord is good
Sounds like the power supply board is dead. Probably has a blown power line fuse on the board. A power surge will sometimes blow the fuse and protect the board from damage. Replacing the fuse will restore the TV if this is the case. Most times though, the supply has a blown part that causes the fuse to blow and your only option then is to replace the board.
Mar 23, 2014 | Panasonic Tc-42px24 42 in. Plasma TV
My husband reversed jumper cables so now my 2002 rav4 starts but won't move out of park and has no radio,back lights power windows etc
Have blown fuses or fusible links or melted
bars under fuse & distribution box-- depending
on what the car has
Mar 13, 2013 | 2002 Toyota RAV4
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
Sep 27, 2012 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
High beam lights flash, but won't stay on.Perhaps a blown fuse?
check the looseness between bulb and connector. blown fuse, lights are totally out.
Aug 17, 2012 | Cadillac Brougham Cars & Trucks
Hitachi lcd led tv won't turn on.
Without more info or seeing the set, the most likely problems are :- the inverter that powers the backlight has failed or the backlight itself has failed The first is the cheapest and easiest to repair the latter could mean the screen needs to be replaced. You don't say if you are getting sound though. if you aren't it may just be that the internal fuse has blown. I hope this points you in the right direction.
May 29, 2012 | Televison & Video
How do find the radio fuse when it is blown
Easy way. With a test light connected to ground ( a test light is a tool that looks like a ice pick with a clear handle with a bulb inside, and a wire coming out the end with a clip on it) Connect the clip on the light to a metal ground under the dash and with the fuse panel where you can see it, touch the pointer to each side of the back of the fuses, with the key on. The light should lght on both sides of a good fuse. If a fuse lights the light on one side and not the other it's blown. For the radio to work three fuses all need to be good as theirs all the time power and key on power and lighting as the dash lights power. The cigar fuse many times provides the all the time power, But if it's blown the radio won't play. Pull one fuse at a time and look at them to see if the bar inside the fuse is good ( they can look good and be bad) back to the test light meathod, Look the fuses up in the owers manul and it'll tell you the location of the fuse but the radio fuse can be good and the radio strill not work as the cigar fuse has to be good too, There;s another fuse panel under the hood that has the main fuses near the battery, Again the test light is fastest and easiest as any fuse blown even though it's not the radio fuse can make the radio not play. Aftermarket radios can have inline fuses instlled by the radio installer and some have fuses right on the back of the radio.
Jun 24, 2011 | 1999 Mercury Grand Marquis
Radio, dome lights and EVIC power problem
I found a paritally blown fuse. When the fuse blew metal pieces ended up partially making contact. After replacing the fuse everything worked great.
Jan 07, 2009 | 1994 Jeep Grand Cherokee
Koss KS3101 System Logo
59 people viewed this question
Top Koss Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Steven Wander
Steven Wander
Steve K
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
