Felipe My board doesnt support sata hard drive what can i do
  • 156 Answers
There are seperate adapters that can act as interfaces between SATA and the ordinary ports of the older mother boards.
These are called SATA to IDE adapters,.
see this link
If you have already bought or have some SATA hard drive and like to attach it to *********** board, then these adapters can come in handy
Posted on Apr 12, 2008
Master/slave settings on sp411c samsung drive please SATA
The SATA hard drive did not have master/slave setting at the hard drive
if you want to make the hard drive as master just connect your hard drive to SATA 1 slot at Motherboard
and id you want to make the hard drive as slave just connect your hard drive to SATA 2 slot at *********** board
i hope this helpful
thank you for using fixya
Feb 09, 2011 | Samsung Computers & Internet
Hi my drive doesnt show up in My Computer and you hear the drive running for about ten sec's, it makes a clunk sound and the drive turns off... thanks for any help with this
I suspect the drive is toast. To test it, take the drive out of the external case and attach it to your computer as a slave drive. See if it shows up in My Computer and if you can read from it. If it works there, then you know that the logic board in the external case is bad. To slave it to your computer, the procedure depends on if it is an IDE drive or SATA drive because it is 1TB I am going to assume it is SATA. The easiest way to connect it is to unhook your CD/DVD drive and connect the cables to the hard drive. This assumes that is also a SATA drive. If not then you will have to get a SATA cable and connect the drive to an empty SATA port on the motherboard and hook up a power plug. Then you will have to go into the BIOS setup and turn on that SATA port. If the drive does not work as a slave, then it is probably dead.
Nov 19, 2010 | LaCie (301304U) 1 TB USB 20 hard disk Hard...
My motherboard doesnt have that long prong connector for the cd rom drive so how do i connect the cd rom drive?
What you will going to do is find a nearest computer store in your place and buy the connector for your cd rom drive.
Oct 25, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
The Green Board on the underneiths side of my hard drive has a burn spot on itand doesnt work,can i use a different green board from another hard drive (different brand)i have laying around.
Nope, even on swapping hard drive board with same spec(size, board version) doesn't guarantee success.
Consider how the hard drive is construct on different brand. Initialization, disc number and many things.
It maybe, if it is same spec like size, brand, board version and model batch.
Oct 08, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
How do i reformat C drive and keep my files on sata backup
dis connect the sata cable that attaches the sata hard drive to the pci card and then format c and re install with all the drivers you require for the pci card as well as motherboard drivers, network card drivers etc and then re attach the sata cable that way you dont get confused between which drives its showing if it manages to display the sata drive at boot up.
May 16, 2009 | Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334...
Install sata drives on abit av8 motherboard (vista home)
Right click on my computer, click on manage. Then on Disk Management. See if the drive shows up . If it does you can format it by right clicking and select format.
Sep 28, 2008 | HP xw4600 Workstation Linux Installer...
Hard Drives -ATA and SATA
Yes, they can coexist.
May 17, 2008 | Computers & Internet
Help regarding laptop harddisk
the motherboard for that unit MAY NOT have SATA capability. check for that at the acer site.
Mar 08, 2008 | Acomdata HybridDrive E5 Hard Drive
Sata, ide
Update: SATA II drives do have jumpers to make them backwards compatible with 1.5 Gb/s (SATA II drives are 3.0 Gb/s). So if your system is older and can only handle SATA (first Gen) then you have to add a jumper (Seagate has the jumper setting on the drive but sometimes supplies no jumper i.e. you have to have your own).
Sep 30, 2007 | Computers & Internet
Computers & Internet Logo
116 people viewed this question
David Payne
David Payne
