Question about Microwave Ovens
I have a Sanyo CG450 microwave / grill and the internal outlet cover has broken up and fallen off. Can the unit be used without this cover and is it possible to purchase replacement.
  • Microwave Ovens Master
  • 9,098 Answers
I would contact Sanyo about this. They can help.
See http://sanyoservice.com/
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 12, 2008
My Sanyo microwave model EMD993 just stopped working completely. Any suggestions as to what might be the problem? Has this model got an internal fuse? If so where do I find it?
Ray,
There is an internal fuse.
Unplug your microwave and turn it around and remove the screws holding cover on and then remove the cover. Look for where the power cord goes into the back of the unit and follow the black wire from the cord to where it ends. It should stop an either a circuit board or a fuse holder. Make sure that you replace the fuse with the same amperage fuse as what you take out. You will find the amp rating stamped on one of the silver collars on each end of the fuse. Good luck!
Apr 03, 2015 | Sanyo Microwave Oven with Convection and...
Silver card has come off on the inside right,is the microwave safe to use .its a prestige model dse20
this is the waveguide cover it covers the anoide of the magnetron,its not really a good idea to use the unit without it as it does two things it allows the microwaves to pass through it but stop anything from getting onto the magnetron if you know of anywhere that repairs microwaves they may if you take your old cover to they might be able to cut a replacement of if its just fallen out you should be able to slot it back in the corners just sit in the slots in the side panel hope this helps
Dec 09, 2012 | Microwave Ovens
Sanyo EM-SL20 Super Showerwave 900W Powergrill has stopped heating
see the informaton with carefully and use the common sense:
God bless you
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem.
Sep 09, 2012 | Microwave Ovens
My GE JVM1750DM blew an internal breaker or fuse when I attempted to remount a lamp lighting the stove top; it had fallen out of its mount. Where is the internal reset or breaker located, and how do
There are fuses inside the unit. No internal breaker. A lot of the time that damages the main circuit board too. Blowing the trace that supplies the power to the bulb off of the board. will probably need a new baord, or someone to repair that one.
Sep 24, 2017 | GE JVM1750DM Microwave Oven
Need a user manual for a Sanyo Convection and grill model em-d981
Need one too - if anyone has one that is in .pdf format they could send it would be much apreciated
Jun 06, 2010 | Sanyo Microwave Microwave Oven
Microwave oven part fallen off.
There are nylon push-in fasteners that snap into place. If there is a shop that works on microwaves, they will generally have them. Over time these fasteners get brittle and crumble away. Another option is to use nylon screws, if you can find some the right size. I don't recommend metal screws as they may arc in the cooking cavity. Using the microwave without the cover will result in spattered food getting into areas that can't be cleaned.
Feb 23, 2010 | Microwave Ovens
SANYO CG450
After cleaning the inside of the oven,including the removable parts, and trying the microwave no vibrating sounds have recurred.
Sep 23, 2008 | Microwave Ovens
Broken door hook
The plastic cover on the inside of the door is purely push fit.
To force it off I used 2 strong stainless steel dinner knives.
By easing one knife between the internal glass and the plastic cover I managed to spring one corner by using the other knife on the external bottom edge of the plastic cover.
Try concentrating on one end and once this springs out it is easy to free the rest without having to take it off completely.
The hook is simple to do but be careful with the spring.
All in all it took 3 minutes!
Jan 13, 2008 | Neff B7740N0GB Microwave Oven
Microwave Ovens Logo
160 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
